I have Ubuntu 24.04.1 LTS on a Dell XPS 9320 (not dual-boot). Since I upgraded from 22.04 last month, my internal speakers have not worked. In Settings, Sound Output lists "No Output Devices". I do get sound via USB devices (speakers or earbuds). I've tried many suggestions from many related questions (see below), but none have worked. Now I'm reaching out for help (please and thank you). From my reading of the related questions, here's relevant information for my case.
Based on remarks of V1del, a forum moderator at archlinux. I tried the following 4 commands to diagnose:
$ sudo fuser -v /dev/snd/*
USER PID ACCESS COMMAND
/dev/snd/controlC0: jim 2555 F.... wireplumber
/dev/snd/seq: jim 2549 F.... pipewire
$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sofsoundwire [sof-soundwire], device 2: Speaker () []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: sofsoundwire [sof-soundwire], device 5: HDMI 1 () []
Subdevices: 1/1
card 0: sofsoundwire [sof-soundwire], device 6: HDMI 2 () []
Subdevices: 1/1
card 0: sofsoundwire [sof-soundwire], device 7: HDMI 3 () []
Subdevices: 1/1
$ pactl list cards
Connection failure: Connection refused
pa_context_connect() failed: Connection refused
$ sudo pactl list sinks
I guess the two "Connection failure" are a problem, but I don't know what they mean.
Based on my research the past few weeks, the following also seem relevant to diagnosing my problem.
$ lspci | grep -i audio
00:1f.3 Multimedia audio controller: Intel Corporation Alder Lake PCH-P High Definition Audio Controller (rev 01)
and
$ inxi -A
Audio:
Device-1: Intel Alder Lake Imaging Signal Processor driver: N/A
Device-2: Intel Alder Lake PCH-P High Definition Audio
driver: sof-audio-pci-intel-tgl
API: ALSA v: k6.8.0-48-generic status: kernel-api
Server-1: PipeWire v: 1.0.5 status: active
I don't see a sound problem in that output (the Device-1 line makes sense, as my camera doesn't work (Cheese, Skype); but that is not my focus here). I do see a problem from the next command I tried
$ sudo dmesg | grep -i snd
[ 4.672746] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 4.672907] snd_hda_intel 0000:00:1f.3: SoundWire enabled on CannonLake+ platform, using SOF driver
[ 6.313507] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 6.313627] snd_hda_intel 0000:00:1f.3: SoundWire enabled on CannonLake+ platform, using SOF driver
[ 7.384054] SDW0-Capture: ASoC: error at snd_soc_link_prepare on SDW0-Capture: -61
[ 7.393206] SDW0-Capture: ASoC: error at snd_soc_link_prepare on SDW0-Capture: -61
… repeated 20+ times
[ 77.199398] SDW0-Capture: ASoC: error at snd_soc_link_prepare on SDW0-Capture: -61
[ 77.207304] SDW0-Capture: ASoC: error at snd_soc_link_prepare on SDW0-Capture: -61
When I google "SDW0-Capture: ASoC: error at snd_soc_link_prepare on SDW0-Capture: -61" I see many posts (often Archlinux) that talk about downgrading the kernel. I don't know what that is, and it sounds bad (like a duct-tape fix, a patch not a fix). But maybe useful to note my kernel:
$ uname -r
6.8.0-48-generic
Please note that pipewire seems fine:
$ systemctl --user status pipewire
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
Active: active (running) since Sun 2024-11-10 08:43:39 EST; 2h 36min ago
TriggeredBy: ● pipewire.socket
Main PID: 2549 (pipewire)
Tasks: 3 (limit: 18626)
Memory: 3.4M (peak: 3.8M)
CPU: 77ms
CGroup: /user.slice/user-1001.slice/user@1001.service/session.slice/pipewire.service
└─2549 /usr/bin/pipewire
Nov 10 08:43:39 xps-13plus-xps-9320 systemd[2530]: Started pipewire.service - PipeWire Multimedia Service.
I think wireplumber's only problem is with the camera:
$ systemctl --user status wireplumber
● wireplumber.service - Multimedia Service Session Manager
Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset: enabled)
Active: active (running) since Sun 2024-11-10 08:43:39 EST; 2h 37min ago
Main PID: 2555 (wireplumber)
Tasks: 6 (limit: 18626)
Memory: 4.3M (peak: 5.5M)
CPU: 348ms
CGroup: /user.slice/user-1001.slice/user@1001.service/session.slice/wireplumber.service
└─2555 /usr/bin/wireplumber
Nov 10 08:43:39 xps-13plus-xps-9320 systemd[2530]: Started wireplumber.service - Multimedia Service Session Manager.
Nov 10 08:43:40 xps-13plus-xps-9320 wireplumber[2555]: SPA handle 'api.libcamera.enum.manager' could not be loaded; is it installed?
Nov 10 08:43:40 xps-13plus-xps-9320 wireplumber[2555]: PipeWire's libcamera SPA missing or broken. libcamera not supported.
Maybe this info about pipewire-pulse is relevant?
$ systemctl --user status pipewire-pulse
○ pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; disabled; preset: enabled)
Active: inactive (dead)
TriggeredBy: ○ pipewire-pulse.socket
I got changes, but no fix, with the following:
$ systemctl --user restart wireplumber pipewire-pulse pipewire
In Settings (Sound Output), this turned "No Output Devices" to "Dummy Output" in the Output of Sound. It also changed the cards and sinks listings, as follows:
$ pactl list cards
Card #46
Driver: alsa
Owner Module: n/a
Properties:
api.acp.auto-port = "false"
api.acp.auto-profile = "false"
api.alsa.card = "0"
api.alsa.card.longname = "Intel Soundwire SOF"
api.alsa.card.name = "sof-soundwire"
api.alsa.path = "hw:0"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1 = "Audio0"
device.api = "alsa"
device.bus = "pci"
device.bus_path = "pci-0000:00:1f.3-platform-sof_sdw"
device.description = "Alder Lake PCH-P High Definition Audio Controller"
device.enum.api = "udev"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_00_1f.3-platform-sof_sdw"
device.nick = "sof-soundwire"
device.plugged.usec = "5766876"
device.product.id = "0x51c8"
device.product.name = "Alder Lake PCH-P High Definition Audio Controller"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sof_sdw/sound/card0"
device.vendor.id = "0x8086"
device.vendor.name = "Intel Corporation"
media.class = "Audio/Device"
factory.id = "14"
client.id = "34"
object.id = "46"
object.serial = "46"
object.path = "alsa:pcm:0"
alsa.card = "0"
alsa.card_name = "sof-soundwire"
alsa.long_card_name = "Intel Soundwire SOF"
alsa.driver_name = "snd_soc_sof_sdw"
alsa.mixer_name = "Intel Alderlake-P HDMI"
alsa.components = "HDA:8086281c,80860101,00100000 cfg-spk:4 cfg-amp:2 spk:rt1316 mic:rt715-sdca"
alsa.id = "sofsoundwire"
device.string = "0"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
pro-audio: Pro Audio (sinks: 4, sources: 1, priority: 1, available: yes)
Active Profile: off
and
$ pactl list sinks
Sink #39
State: SUSPENDED
Description: Dummy Output
Driver: PipeWire
Sample Specification: float32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 49808 / 76% / -7.15 dB, front-right: 49808 / 76% / -7.15 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: auto_null.monitor
Latency: 0 usec, configured 0 usec
Flags: DECIBEL_VOLUME LATENCY
Properties:
node.name = "auto_null"
device.description = "Dummy Output"
audio.rate = "48000"
audio.channels = "2"
audio.position = "FL,FR"
media.class = "Audio/Sink"
factory.name = "support.null-audio-sink"
node.virtual = "true"
monitor.channel-volumes = "true"
factory.id = "18"
clock.quantum-limit = "8192"
client.id = "36"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "39"
object.serial = "39"
Formats:
pcm
Thank you in advance to any kind soul who can help me restore my speaker sound. And I'd be happy to share more info if it would help ...
PS If it helps, here is a sampling I other questions I've looked at for help:
Fixing No Sound (Dummy Output) Issue in Ubuntu 24.04 From the top answer there, I used sudo gedit to create /etc/modprobe.d/audiofix.conf and put in the lines
options snd-hda-intel dmic_detect=0
options snd-hda-intel model=laptop-amic enable=yes
After rebooting, no change.
No sound output devices listed after upgrade from 21.10 to 22.04 looks relevant, but it is about pulseaudio and 24.04 uses pipewire.
Fixing No Sound (Dummy Output) Issue in Ubuntu 24.04 suggests to downgrade the kernel, but that sounds bad to me. And my sound problem is "No Output Devices", not "Dummy Output"
I see several unanswered questions that may be about the same as mine, with no speaker-sound in 24.04; e.g. lenovo M90a, Ubuntu 24.04, missing sound on speakers, earphones ok
In my case aplay lists a sound card, so my problem differs from many other dealing with no sound in 24.04, such as No sound after upgrade from Ubuntu 22.04 to Ubuntu 24.04.
No sound in internal Speakers in Ubuntu 24.04 sounded promising, but the fix there was to disable fast-boot in Windows (I don't have Windows).
=== Here's more info,
tail "/etc/modprobe.d/alsa-base.conf"
options snd-usb-usx2y index=-2
# Ubuntu #62691, enable MPU for snd-cmipci
options snd-cmipci mpu_port=0x330 fm_port=0x388
# Keep snd-pcsp from being loaded as first soundcard
options snd-pcsp index=-2
# Keep snd-usb-audio from beeing loaded as first soundcard
options snd-usb-audio index=-2
# options snd-hda-intel model=auto -- tried & failed for audio
fix 27Oct2024
# blacklist snd_soc_avs
options snd-hda-intel model=dell-headset-multi
As suggested by heynnema, here are two more pieces of info
$ uname -r
6.8.0-48-generic
and
$ ls -al /boot
total 188920
drwxr-xr-x 4 root root 4096 Nov 1 07:53 .
drwxr-xr-x 24 root root 4096 Oct 27 09:24 ..
-rw-r--r-- 1 root root 287493 Sep 27 13:21 config-6.8.0-47-generic
-rw-r--r-- 1 root root 287459 Sep 27 08:22 config-6.8.0-48-generic
drwx------ 4 root root 4096 Dec 31 1969 efi
drwxr-xr-x 5 root root 4096 Nov 1 07:53 grub
lrwxrwxrwx 1 root root 27 Nov 1 07:52 initrd.img -> initrd.img-6.8.0-48-generic
-rw-r--r-- 1 root root 72110854 Oct 27 09:24 initrd.img-6.8.0-47-generic
-rw-r--r-- 1 root root 72097106 Nov 1 07:52 initrd.img-6.8.0-48-generic
lrwxrwxrwx 1 root root 27 Nov 1 07:52 initrd.img.old -> initrd.img-6.8.0-47-generic
-rw-r--r-- 1 root root 142796 Apr 8 2024 memtest86+ia32.bin
-rw-r--r-- 1 root root 143872 Apr 8 2024 memtest86+ia32.efi
-rw-r--r-- 1 root root 147744 Apr 8 2024 memtest86+x64.bin
-rw-r--r-- 1 root root 148992 Apr 8 2024 memtest86+x64.efi
-rw------- 1 root root 9061992 Sep 27 13:21 System.map-6.8.0-47-generic
-rw------- 1 root root 9063891 Sep 27 08:22 System.map-6.8.0-48-generic
lrwxrwxrwx 1 root root 24 Nov 1 07:52 vmlinuz -> vmlinuz-6.8.0-48-generic
-rw------- 1 root root 14956936 Sep 27 14:47 vmlinuz-6.8.0-47-generic
-rw------- 1 root root 14952840 Sep 27 08:26 vmlinuz-6.8.0-48-generic
lrwxrwxrwx 1 root root 24 Nov 1 07:52 vmlinuz.old -> vmlinuz-6.8.0-47-generic
I updated my bios to the most recent (from 2.10 to 2.16.1) but that seems not to have affected anything.
video card seems to be Intel
$ lspci | grep VGA.
00:02.0 VGA compatible controller: Intel Corporation Alder Lake-P GT2 [Iris Xe Graphics] (rev 0c)
As suggested by @hynnema, I used Mainline to change kernels to 6.5.11 and added "options snd-hda-intel model=dell-headset-multi" to alsabase.conf and rebooted (kernel 6.5.11) but still No Output Devices in Sound Settings. But now pipewire has a problem:
Active: active (running) since Thu 2024-11-21 16:12:25 EST; 9min ago
Main PID: 2932 (pipewire)
Tasks: 3 (limit: 18609)
CPU: 88ms
└─2932 /usr/bin/pipewire
Nov 21 16:12:25 xps-13plus-xps-9320 systemd[2911]: Started pipewire.service - PipeWire Multimedia Service.
Nov 21 16:12:25 xps-13plus-xps-9320 pipewire[2932]: mod.jackdbus-detect: Failed to receive jackdbus reply: org.freedesktop.DBus.Error.ServiceUnknown: The receive jackdbus reply: org.freedesktop.DBus.Error.ServiceUnknown: The name org.jackaudio.service was not provided by any .service files
I plan use Dell's system restore, but first I need to back up my data and my legacy software programs.
