I have upgraded my computer operating system from Ubuntu 22.04 to Ubuntu 24.04. I have no sound on the computer after the upgrade. Everything worked fine before. I have read various forums on the subject but have not been able to solve the problem. Below is some information that may be helpful.
uname -all
Linux agold163858 5.14.0-1054-oem #61-Ubuntu SMP Fri Oct 14 13:05:50 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
aplay -l aplay: device_list:277: no soundcards found...
lspci | grep -i Audio 00:1f.3 Audio device: Intel Corporation Tiger Lake-LP Smart Sound Technology Audio Controller (rev 20)
sudo dmesg | grep -i audio
[ 0.204508] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio) [ 4.365212] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380 [ 4.374340] sof-audio-pci-intel-tgl 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver [ 4.375723] sof-audio-pci-intel-tgl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040380 [ 4.566359] sof-audio-pci-intel-tgl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915]) [ 4.911926] sof-audio-pci-intel-tgl 0000:00:1f.3: use msi interrupt mode [ 4.933067] sof-audio-pci-intel-tgl 0000:00:1f.3: hda codecs found, mask 5 [ 4.933070] sof-audio-pci-intel-tgl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now [ 4.933074] sof-audio-pci-intel-tgl 0000:00:1f.3: DMICs detected in NHLT tables: 4 [ 4.933463] sof-audio-pci-intel-tgl 0000:00:1f.3: Direct firmware load for intel/sof/sof-tgl.ri failed with error -2 [ 4.933466] sof-audio-pci-intel-tgl 0000:00:1f.3: error: request firmware intel/sof/sof-tgl.ri failed err: -2 [ 4.933469] sof-audio-pci-intel-tgl 0000:00:1f.3: you may need to download the firmware from https://github.com/thesofproject/sof-bin/ [ 4.933471] sof-audio-pci-intel-tgl 0000:00:1f.3: error: failed to load DSP firmware -2 [ 4.933860] sof-audio-pci-intel-tgl 0000:00:1f.3: error: sof_probe_work failed err: -2
I would greatly appreciate any help with this issue.
Thanks, Alex
ALEX
I was facing the same issue, in setting app shows no playback device. And eventually fixed by reinstalling ubuntu-desktop package.
sudo apt install --reinstall ubuntu-desktop^
Thank you for your reply. By default in my system kernel 5.14.0-1054-oem is selected. I noticed that if in the Adavanced Ubuntu menu during startup I select kernel 6.11.0-061100-generic then sound works well...
ALEX
I solved it this way:
sudo apt install linux-modules-extra-$(uname -r)
sudo apt install sof-firmware
systemctl --user restart pulseaudio
sudo usermod -a -G audio $USER
echo "options snd-intel-dspcfg dsp_driver=1" | sudo tee /etc/modprobe.d/intel-dspcfg.conf
echo "options snd_hda_intel power_save=0 power_save_controller=N" | sudo tee -a /etc/modprobe.d/audio_disable_powersave.conf
I hope this could be of some help.
zx485
  • 2,865
