Sometimes the pulseaudio service stops and it doesn't restart itself when I open an audio file with banshee or totem.
How I can make pulseaudio start again without having to logout?
I solved my problem.
Check if any pulseaudio instance is running:
pulseaudio --check
It normally prints no output, just exit code. 0 means running.
Mine were not running, so I just advanced to step 3.
If any instance is running, kill it:
pulseaudio -k
Finally, start pulseaudio again as a daemon:
pulseaudio -D
Start banshee again and enjoy!
Pulseaudio is a user service, so:
systemctl --user restart pulseaudio.service
Also there is this:
systemctl --user restart pulseaudio.socket
For checks replace restart with status.
In a standard setup running pulseaudio -k restarts the daemon. Nothing else to do.
In case pulseaudio is not running typing pulseaudio without further options will start the daemon using defaults in /etc/pulse/daemon.conf and /etc/pulse/default.pa.
User-defined settings in ~/.pulse/ or ~/.config/pulse/ will override system-wide settings. In case of issues it will often help to delete these directories before restarting pulseaudio.
For details see PulseAudio Wiki.
Use the service command (Ubuntu 14.04 or older only):
sudo service pulseaudio restart
Run the following commands:
pulseaudio --check
pulseaudio --kill
pulseaudio --start
Here's how to do it in Ubuntu 15.10:
pulseaudio -k to kill the running daemon. You will get an error only if no daemon was running, otherwise no messages will appear.pulseaudio --check to check that Pulseaudio is running. A clean exit (no message) from the check command indicates that the daemon has started successfully. Otherwise, run pulseaudio --start to launch the daemon. If you recently changed your configuration file and the daemon fails to start, check your file for errors and check the syslog (with the SystemLog app) for any messages from Pulseaudio.If the pulseaudio failing to work is related to S3 sleep (Suspend to RAM), the real cause may be audio hardware problem and then you have to do heavy-handed full reset:
pulseaudio -k && sudo alsa force-reload && sleep 2 && pulseaudio -k && sudo alsa force-reload
Yeah, it needs to be done twice with small delay. I don't know why but this seems to work every time.
If you have multiple desktop environments in parallel (fast user switching)
sudo killall pulseaudio && sudo alsa force-reload && sleep 2 && sudo killall pulseaudio && sudo alsa force-reload
You would run this command to restart PulseAudio in Ubuntu 2020 releases:
I'd like to add my penny's worth to my namesake @rolf's systemDanswer.
The scenario:
Pulseaudio is locked up tight
You've tried:
systemctl --user stop pulseaudio.service pulseaudio.socket
systemctl --user reset-failed pulseaudio.service
Still stubbonly it shows:
● pulseaudio.service - Sound Service
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Sun 2022-08-07 17:43:39 CEST; 8min ago
TriggeredBy: ● pulseaudio.socket
Process: 6598 ExecStart=/usr/bin/pulseaudio --daemonize=no --log-target=journal (code=exited, status=1/FAILURE)
Main PID: 6598 (code=exited, status=1/FAILURE)
Aug 07 17:43:39 pc1 systemd[1063]: pulseaudio.service: Failed with result 'exit-code'.
Aug 07 17:43:39 pc1 systemd[1063]: Failed to start Sound Service.
Aug 07 17:43:39 pc1 systemd[1063]: pulseaudio.service: Scheduled restart job, restart counter is at 5.
Aug 07 17:43:39 pc1 systemd[1063]: Stopped Sound Service.
Aug 07 17:43:39 pc1 systemd[1063]: pulseaudio.service: Start request repeated too quickly.
The key here is that the restart counter has been exceeded.
If you manually run:
pulseaudio -vvvv
You may find the final lines say:
E: [pulseaudio] pid.c: Daemon already running.
E: [pulseaudio] main.c: pa_pid_file_create() failed.
Here, you need to find your user id's /run/user/1000/pulse directory, where the number 1000 is my user id number
Get your uid from the command: id
In the the pulse run directory is a file called pid
, delete it!
Try starting pulseaudio -vvvv again, only to discover that it's bound to the Dbus or the bind Address already in use
E: [pulseaudio] main.c: D-Bus name org.PulseAudio1 already taken.
or
E: [pulseaudio] socket-server.c: bind(): Address already in use
So: ps -ef | grep pulseaudio to find any process still running it and kill it with
kill -15 pid number from grep
Now you can restart pulseaudio:
systemctl --user start pulseaudio.service pulseaudio.socket
or:
You could logout and log back in again :)
