20
I installed newest cinnamon 24.04, and while in previous version everything worked just fine, in this version I have a 'ghost monitor', to which the cursor can wander, but which cannot be turned off in Display settings.
If I open nvidia settings, I see this:
dialog with two display options, of which the selected one is PRIME 1920x1080
So there is some prime display, which cannot be controlled. I tried a recommendation to add a kernel parameter
initcall_blacklist=simpledrm_platform_driver_init
but this just makes the OS unbootable.
I guess this was induced by upgrading lenovo firmware, which I probably can downgrade back. But is there any better solution? How to get rid of this PRIME display, which is rather sub-prime, since it does not display anything and just makes your work harder.
Zanna
  • 72,312
The work around can be found in @ maarallez's answer in this Reddit thread: Weird second display: nvidia PRIME Display (some formatting added by me):
You can disable the ghost screen by writing a short config file.
First, open a terminal and run xrandr to identify your screens. Take note of the name of the ghost device (e.g. HDMI-0, DP-0, etc.); mine was None-1-1.
Then create your config file:
sudo gedit /etc/X11/xorg.conf.d/10-monitor.conf
Paste the following, making sure to replace the VGA1 with the name you identified in the previous step:
Section "Monitor"
Identifier "VGA1"
Option "Ignore" "true"
EndSection
Save the file and reboot.
amar
  • 2,140
