As the title, my login background is split into 2 (1 horizontal and 1 vertical) while I'm on the login screen. Are there any solutions to temporarily disable the vertical monitor and then re-enable it after logging in?
I check the vertical with xrandr and it seems it is the DP-2
xrandr
Screen 0: minimum 8 x 8, current 7424 x 4096, maximum 32767 x 32767
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 connected 2304x4096+0+0 right (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.95 + 144.01* 120.00 99.95
1920x1080 119.88 100.00 60.00 59.94 50.00
1440x900 59.89
1440x576 50.00
1440x480 59.94
1280x1024 75.02 60.02
1280x720 59.94 50.00
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
640x480 75.00 72.81 59.94
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 connected primary 5120x2880+2304+549 (normal left inverted right x axis y axis) 600mm x 340mm
2560x1440 164.96*+ 143.97 120.00 99.95 59.95
1024x768 60.00
800x600 60.32
720x480 59.94
640x480 59.94 59.93
DP-5 disconnected (normal left inverted right x axis y axis)
None-1-1 connected (normal left inverted right x axis y axis)
1024x768 60.00 +
I tried to disable it with xrandr --output DP-2 --auto but it did not work.
