I have a System76 Thelio with an NVidia RTX 3060 video card. I was running Ubuntu 20.04 with no issues.
I upgraded to 22.04, and now get an error message "Could not switch the monitor configuration" popup before logging in. If I dismiss the popup, everything seems to work as expected.
In trying to track this down, I noticed that xrandr -q displays a mysterious 3rd output. This also shows up in the Display section of System Settings.
I do have a third output on the video card, but nothing is plugged in, and I did not have this problem with 20.04.
Here is what is displayed by xrandr --verbose (just the ghost output, which shows up at the end):
None-1-1 connected (normal left inverted right x axis y axis)
Identifier: 0x204
Timestamp: 14563613
Subpixel: unknown
Clones:
CRTCs: 4
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
PRIME Synchronization: 1
supported: 0, 1
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 35
supported: 35
non-desktop: 0
range: (0, 1)
1920x1200 (0x206) 138.240MHz +preferred
h: width 1920 start 1920 end 1920 total 1920 skew 0 clock 72.00KHz
v: height 1200 start 1200 end 1200 total 1200 clock 60.00Hz
I have tried xrandr --auto, and xrandr --output None-1-1 --off in an effort to "disconnect" this output.
The nvidia-settings program only displays the two outputs that are connected (HDMI-0 and DP-0).
I don't have an xorg.conf file. ~/.config/monitors.xml looked "reasonable" to me, but I haven't tried removing it yet.
Here is xrandr --current:
Screen 0: minimum 8 x 8, current 5760 x 2160, maximum 32767 x 32767
HDMI-0 connected 3840x2160+0+0 (normal left inverted right x axis y axis) 697mm x 392mm
3840x2160 60.00*+ 59.94 50.00 30.00 29.97 25.00 23.98
2560x1440 59.95
2048x1280 60.00
2048x1080 24.00
1920x1080 60.00 59.94 50.00 25.00 23.98
1600x1200 60.00
1600x900 60.00
1280x1024 75.02 60.02
1280x720 59.94 50.00
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.94 59.93
DP-0 connected primary 1920x1200+3840+389 (normal left inverted right x axis y axis) 518mm x 324mm
1920x1200 59.95*+ 59.88
1920x1080 60.00 59.94 50.00 23.98
1600x1200 60.00
1280x720 60.00 59.94 50.00
1152x864 75.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
1920x1200 60.00 +
I would like to "disconnect" this output so that I don't get the error.
Any ideas?
