I installed Ubuntu 12.04 from USB from inside Windows. When I restarted the PC there was no grub menu. How to fix this?
Asked
Active
Viewed 9,656 times
You're probably missing the file below when you installed Ubuntu.
/boot/grub/core.img
So you need to use chroot to have it fixed. Take a look at this site
Mitch
- 109,787
I believe what you said was that you used a Wubi installer and afterwards you are unable to select Ubuntu as your operating system.
The answer has been provided here: No boot option after Ubuntu install
Yes this is also happened to me you can take a look on Can I install Ubuntu inside Windows?
you can try this where d is your iso image drive and run this command
D:\wubi.exe --force-wubi
Arsalan Shah
- 583
