I was unable to open Settings within Ubuntu, or from right-clicking the desktop. Understandably I was missing gnome-control-center, however it turns out I am missing several dependencies, which are missing further dependencies.
Doing sudo apt-get update and sudo apt-get upgrade returns no packages installed.
$ gnome-control-center
Command 'gnome-control-center' not found, but can be installed with:
sudo apt install gnome-control-center
However, apt install gnome-control-center returns me broken packages. Doing a reinstall also nets the same error messages.
$ sudo apt install gnome-control-center
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies: gnome-control-center : Depends: gnome-control-center-data (< 1:3.37) but 1:3.38.5-1ubuntu2 is to be installed Recommends: gnome-online-accounts (>= 3.25.3) but it is not going to be installed Recommends: network-manager-gnome (>= 0.9.8) but it is not going to be installed Recommends: gnome-control-center-faces but it is not going to be installed Recommends: rygel but it is not going to be installed or rygel-tracker but it is not going to be installed E: Unable to correct problems, you have held broken packages.
$ apt policy gnome-control-center gnome-control-center: Installed: (none) Candidate: 1:3.36.5-0ubuntu4 Version table: 1:3.36.5-0ubuntu4 500 500 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages 1:3.36.1-1ubuntu5 500 500 http://archive.ubuntu.com/ubuntu focal/main amd64 Packages
The packages can't be installed:
$ sudo apt install gnome-control-center-data
gnome-control-center-data is already the newest version (1:3.38.5-1ubuntu2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ apt policy gnome-control-center-data gnome-control-center-data: Installed: 1:3.38.5-1ubuntu2 Candidate: 1:3.38.5-1ubuntu2 Version table: *** 1:3.38.5-1ubuntu2 100 100 /var/lib/dpkg/status 1:3.36.5-0ubuntu4 500 500 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages 500 http://archive.ubuntu.com/ubuntu focal-updates/main i386 Packages 1:3.36.1-1ubuntu5 500 500 http://archive.ubuntu.com/ubuntu focal/main amd64 Packages 500 http://archive.ubuntu.com/ubuntu focal/main i386 Packages
Something similar is encountered for the others:
$ sudo apt install gnome-online-accounts
The following packages have unmet dependencies: gnome-online-accounts : Depends: libgoa-1.0-0b (= 3.36.1-0ubuntu1) but 3.38.1-1ubuntu1.1 is to be installed Depends: libgoa-backend-1.0-1 (= 3.36.1-0ubuntu1) but 3.38.1-1ubuntu1.1 is to be installed Depends: python3-macaroonbakery but it is not going to be installed Recommends: gnome-control-center (>= 3.6.1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
$ apt policy gnome-online-accounts gnome-online-accounts: Installed: (none) Candidate: 3.36.1-0ubuntu1 Version table: 3.36.1-0ubuntu1 500 500 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages 3.36.0-1ubuntu1 500 500 http://archive.ubuntu.com/ubuntu focal/main amd64 Packages
Here is more system info:
$ uname -a
Linux <username> 5.14.0-1054-oem #61-Ubuntu SMP Fri Oct 14 13:05:50 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
I have consulted these pages but to no avail. In fact some of the autoremove made more dependencies break.
  1. https://serverok.in/ubuntu-20-04-settings-wont-open
  2. System Settings won't start, Ubuntu 16.04
  3. gnome-control-center install error
  4. gnome-control-center appearance tab broken
  5. Unable to open gnome-control-center in Ubuntu 18.04
  6. Reporting: I can't open settings in ubuntu 20.04 LTS
gnome-control-center can be successfully installed thanks to this post, however it does not launch at all. The cursor goes into a loading state, and returns back to the pointer after a few minutes.
apt policy gnome-control-center now gives
  Installed: 1:3.36.5-0ubuntu4
  Version table:
 *** 1:3.36.5-0ubuntu4 500
Attempting to launch gnome-control-center from terminal returns me this error
gnome-control-center: symbol lookup error: /usr/lib/x86_64-linux-gnu/samba/libsamdb-common.so.0: undefined symbol: ldb_msg_element_add_value, version LDB_2.2.3
However, apt cache policy is unable to find the package. Not sure if the samba matters so i added it in as well, but it is the same result.
apt-cache policy libsamdb-common.so.0
N: Unable to locate package libsamdb-common.so.0
N: Couldn't find any package by glob 'libsamdb-common.so.0'
N: Couldn't find any package by regex 'libsamdb-common.so.0'
apt-cache policy samba/libsamdb-common.so.0 N: Unable to locate package samba/libsamdb-common.so.0 N: Couldn't find any package by glob 'samba/libsamdb-common.so.0' N: Couldn't find any package by regex 'samba/libsamdb-common.so.0'
I saw on another post to try running the ldd command, which gave me this.
ldd /usr/lib/x86_64-linux-gnu/samba/libsamdb-common.so.0
    linux-vdso.so.1 (0x00007ffdfcfcb000)
    libsamba-hostconfig.so.0 => /lib/x86_64-linux-gnu/libsamba-hostconfig.so.0 (0x00007f787c5ba000)
    libreplace.so.0 => /usr/lib/x86_64-linux-gnu/samba/libreplace.so.0 (0x00007f787c5b5000)
    libndr-samba.so.0 => /usr/lib/x86_64-linux-gnu/samba/libndr-samba.so.0 (0x00007f787c45e000)
    libcli-ldap-common.so.0 => /usr/lib/x86_64-linux-gnu/samba/libcli-ldap-common.so.0 (0x00007f787c454000)
    libsamba-sockets.so.0 => /usr/lib/x86_64-linux-gnu/samba/libsamba-sockets.so.0 (0x00007f787c439000)
    libflag-mapping.so.0 => /usr/lib/x86_64-linux-gnu/samba/libflag-mapping.so.0 (0x00007f787c432000)
    libsamba-errors.so.1 => /lib/x86_64-linux-gnu/libsamba-errors.so.1 (0x00007f787c2e7000)
    libsamba-util.so.0 => /lib/x86_64-linux-gnu/libsamba-util.so.0 (0x00007f787c274000)
    libsamba-security.so.0 => /usr/lib/x86_64-linux-gnu/samba/libsamba-security.so.0 (0x00007f787c252000)
    libndr.so.1 => /lib/x86_64-linux-gnu/libndr.so.1 (0x00007f787c235000)
    libsocket-blocking.so.0 => /usr/lib/x86_64-linux-gnu/samba/libsocket-blocking.so.0 (0x00007f787c230000)
    libtevent-util.so.0 => /lib/x86_64-linux-gnu/libtevent-util.so.0 (0x00007f787c227000)
    libsamba-debug.so.0 => /usr/lib/x86_64-linux-gnu/samba/libsamba-debug.so.0 (0x00007f787c21c000)
    libsys-rw.so.0 => /usr/lib/x86_64-linux-gnu/samba/libsys-rw.so.0 (0x00007f787c217000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f787c1f5000)
    libtalloc.so.2 => /lib/x86_64-linux-gnu/libtalloc.so.2 (0x00007f787c1e6000)
    libldb.so.2 => /lib/x86_64-linux-gnu/libldb.so.2 (0x00007f787c1b2000)
    libtevent.so.0 => /lib/x86_64-linux-gnu/libtevent.so.0 (0x00007f787c19b000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f787bfaf000)
    libserver-role.so.0 => /usr/lib/x86_64-linux-gnu/samba/libserver-role.so.0 (0x00007f787bfaa000)
    libgnutls.so.30 => /lib/x86_64-linux-gnu/libgnutls.so.30 (0x00007f787bdad000)
    libtdb.so.1 => /lib/x86_64-linux-gnu/libtdb.so.1 (0x00007f787bd93000)
    libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007f787bd7b000)
    libndr-nbt.so.0 => /lib/x86_64-linux-gnu/libndr-nbt.so.0 (0x00007f787bd4f000)
    libasn1util.so.0 => /usr/lib/x86_64-linux-gnu/samba/libasn1util.so.0 (0x00007f787bd46000)
    libndr-standard.so.0 => /lib/x86_64-linux-gnu/libndr-standard.so.0 (0x00007f787b9e3000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f787b9c7000)
    libiov-buf.so.0 => /usr/lib/x86_64-linux-gnu/samba/libiov-buf.so.0 (0x00007f787b9c2000)
    libinterfaces.so.0 => /usr/lib/x86_64-linux-gnu/samba/libinterfaces.so.0 (0x00007f787b9bb000)
    libnsl.so.1 => /lib/x86_64-linux-gnu/libnsl.so.1 (0x00007f787b99f000)
    libtime-basic.so.0 => /usr/lib/x86_64-linux-gnu/samba/libtime-basic.so.0 (0x00007f787b99a000)
    libgenrand.so.0 => /usr/lib/x86_64-linux-gnu/samba/libgenrand.so.0 (0x00007f787b995000)
    libicuuc.so.66 => /lib/x86_64-linux-gnu/libicuuc.so.66 (0x00007f787b7af000)
    libsystemd.so.0 => /lib/x86_64-linux-gnu/libsystemd.so.0 (0x00007f787b6f7000)
    libicui18n.so.66 => /lib/x86_64-linux-gnu/libicui18n.so.66 (0x00007f787b3f8000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f787b3f1000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f787c62f000)
    libp11-kit.so.0 => /lib/x86_64-linux-gnu/libp11-kit.so.0 (0x00007f787b2b8000)
    libidn2.so.0 => /lib/x86_64-linux-gnu/libidn2.so.0 (0x00007f787b296000)
    libunistring.so.2 => /lib/x86_64-linux-gnu/libunistring.so.2 (0x00007f787b112000)
    libtasn1.so.6 => /lib/x86_64-linux-gnu/libtasn1.so.6 (0x00007f787b0fc000)
    libnettle.so.8 => /lib/x86_64-linux-gnu/libnettle.so.8 (0x00007f787b0b6000)
    libhogweed.so.6 => /lib/x86_64-linux-gnu/libhogweed.so.6 (0x00007f787b06e000)
    libgmp.so.10 => /lib/x86_64-linux-gnu/libgmp.so.10 (0x00007f787afeb000)
    libmd.so.0 => /lib/x86_64-linux-gnu/libmd.so.0 (0x00007f787afde000)
    libicudata.so.66 => /lib/x86_64-linux-gnu/libicudata.so.66 (0x00007f787951b000)
    libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f7879302000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f78791b4000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f7879199000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f787918e000)
    liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007f7879161000)
    libzstd.so.1 => /lib/x86_64-linux-gnu/libzstd.so.1 (0x00007f7879094000)
    liblz4.so.1 => /lib/x86_64-linux-gnu/liblz4.so.1 (0x00007f7879074000)
    libcap.so.2 => /lib/x86_64-linux-gnu/libcap.so.2 (0x00007f7879069000)
    libgcrypt.so.20 => /lib/x86_64-linux-gnu/libgcrypt.so.20 (0x00007f7878f46000)
    libffi.so.8 => /lib/x86_64-linux-gnu/libffi.so.8 (0x00007f7878f3a000)
    libgpg-error.so.0 => /lib/x86_64-linux-gnu/libgpg-error.so.0 (0x00007f7878f10000)
sudo ubuntu-drivers autoinstall gives this output. As far as I know, my NVIDIA graphics card should be using driver-470, so it is odd that the others are even included.
WARNING:root:_pkg_get_support nvidia-driver-525-server: package has invalid Support PBheader, cannot determine support level
WARNING:root:_pkg_get_support nvidia-driver-515: package has invalid Support PBheader, cannot determine support level
WARNING:root:_pkg_get_support nvidia-driver-515-open: package has invalid Support PBheader, cannot determine support level
WARNING:root:_pkg_get_support nvidia-driver-510: package has invalid Support PBheader, cannot determine support level
WARNING:root:_pkg_get_support nvidia-driver-525-open: package has invalid Support PBheader, cannot determine support level
WARNING:root:_pkg_get_support nvidia-driver-525: package has invalid Support PBheader, cannot determine support level
WARNING:root:_pkg_get_support nvidia-driver-515-server: package has invalid Support PBheader, cannot determine support level
The following additional packages will be installed:
  dctrl-tools dkms libnvidia-cfg1-525 libnvidia-common-525
  libnvidia-compute-525 libnvidia-compute-525:i386 libnvidia-decode-525
  libnvidia-encode-525 libnvidia-extra-525 libnvidia-fbc1-525 libnvidia-gl-525
  libxnvctrl0 nvidia-compute-utils-525 nvidia-kernel-common-525
  nvidia-kernel-source-525-open nvidia-prime nvidia-settings nvidia-utils-525
  screen-resolution-extra xserver-xorg-video-nvidia-525
Suggested packages:
  debtags menu nvidia-driver-525
Recommended packages:
  libnvidia-decode-525:i386 libnvidia-encode-525:i386 libnvidia-fbc1-525:i386
  libnvidia-gl-525:i386
The following packages will be REMOVED:
  libnvidia-compute-470
The following NEW packages will be installed:
  libxnvctrl0 nvidia-compute-utils-525 nvidia-dkms-525-open
  nvidia-driver-525-open nvidia-kernel-common-525
0 upgraded, 22 newly installed, 1 to remove and 5 not upgraded.
Need to get 338 MB/339 MB of archives.
After this operation, 884 MB of additional disk space will be used.
How to install/launch gnome-control-center, with multiple broken dependencies?
