40
Title says it all.
I did sudo apt-get upgrade and sudo apt-get autoremove and all that stuff, but System Settings still won't open.
I tried opening it from a Terminal, and it returned Bus error (core dumped)
Any help would be appreciated!
Zencha
  • 409
Try this,
sudo apt-get remove unity-control-center
sudo apt autoremove
sudo apt-get install unity-control-center
It worked for me.
54
And if you are trying to do this with Ubuntu 18.04, try this:
sudo apt-get remove gnome-control-center
sudo apt autoremove
sudo apt-get install gnome-control-center
This is because Ubuntu decided to switch their user interface from Unity to Gnome.
I had a similar issue in Ubuntu 20.04 and I run the following command,
dconf reset -f /org/gnome/control-center/
Note: If this works for you, that's great!!! Honestly, I don't know what does it do in behind the scenes.
JPG
  • 285
With NVIDIA graphics I had to install proprietary nvidia-driver-430.40
I added repositories:
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo add-apt-repository ppa:oibaf/graphics-drivers
and ran
sudo ubuntu-drivers autoinstall
and reboot
The problem was solved.
If does not work for you. To remove the PPAs run:
sudo ppa-purge ppa:graphics-drivers/ppa
sudo ppa-purge ppa:oibaf/graphics-drivers
Vijay
  • 8,556
