When opening the appearance tab in gnome-control-center, it crashes.
Then it won't open again, until in dconf-editor I overwrite the value org.gnome.control-center.last-panel from "ubuntu", which is apparently the value for the appearance tab, to something else like "", "wifi" or "network". This would probably be easier in terminal.
Anyone got an idea what is going on here? Could I have accidentally uninstalled something that is required for this tab?
I really don't need this tab, but it is still kinda annoying when I accidentally click on it.
This appeared in /var/log/syslog after a crash:
Apr  1 15:18:57 qu gnome-control-c[8051]: Settings schema 'org.gnome.gedit.preferences.editor' is not installed
Apr  1 15:18:57 qu kernel: [ 5373.136060] Rekeying PTK for STA 5c:83:8f:8e:43:8e but driver can't safely do that.
Apr  1 15:18:57 qu kernel: [ 5387.602416] traps: gnome-control-c[8051] trap int3 ip:7f21bdfb966f sp:7fff358a6830 error:0 in libglib-2.0.so.0.6800.4[7f21bdf7a000+8d000]
Apr  1 15:18:57 qu systemd[1252]: app-gnome-gnome\x2dcontrol\x2dcenter-8051.scope: Deactivated successfully.
Apr  1 15:18:57 qu systemd[1252]: app-gnome-gnome\x2dcontrol\x2dcenter-8051.scope: Consumed 2.459s CPU time.
This after another crash:
Apr  1 15:25:27 qu gnome-control-c[8530]: Settings schema 'org.gnome.gedit.preferences.editor' is not installed
Apr  1 15:25:27 qu kernel: [ 5777.251051] traps: gnome-control-c[8530] trap int3 ip:7f35ab17d66f sp:7ffe0480cf90 error:0 in libglib-2.0.so.0.6800.4[7f35ab13e000+8d000]
Apr  1 15:25:27 qu systemd[1252]: app-gnome-gnome\x2dcontrol\x2dcenter-8530.scope: Deactivated successfully.
  • Version: Ubuntu 21.10 x86_64
  • PC: HP Pavilion Power Laptop 15-cb0xx
  • CPU: Intel i5-7300HQ
  • GPU: NVIDIA GeForce GTX 1050 Mobile
Do I need gedit for the appearance tab work?
Apparently you do. If gedit is installed, then you may have a broken common package. It can be reinstalled like this:
sudo apt-get install --reinstall gedit-common
Otherwise, you may need to reinstall the entire gedit package
matigo
  • 24,752
  • 50
  • 79
