28
Messages in my terminal are displayed using Russian language by default, which is my native one.
For just a moment I want them to be in English (eg. to paste in forums), then switch back to the default language.
How can I do the switch and switch back using bash?
jrg
  • 61,707
takeshin
  • 2,932
There are several environment variables available for changing language settings. You can view your current locale settings by executing the locale command. To change all locale settings to English, use LANG=C. This C locale is always available without installing additional language packs. (In order to temporarily change to non-English locales, see @mklement0's post.)
Examples:
Executing a command with the default language settings and print the current locale settings:
$ /nonexistent
bash: /nonexistent: Bestand of map bestaat niet
$ locale
LANG=nl_NL.UTF-8
LANGUAGE=
LC_CTYPE="nl_NL.UTF-8"
LC_NUMERIC="nl_NL.UTF-8"
LC_TIME="nl_NL.UTF-8"
LC_COLLATE="nl_NL.UTF-8"
LC_MONETARY="nl_NL.UTF-8"
LC_MESSAGES="nl_NL.UTF-8"
LC_PAPER="nl_NL.UTF-8"
LC_NAME="nl_NL.UTF-8"
LC_ADDRESS="nl_NL.UTF-8"
LC_TELEPHONE="nl_NL.UTF-8"
LC_MEASUREMENT="nl_NL.UTF-8"
LC_IDENTIFICATION="nl_NL.UTF-8"
LC_ALL=
Temporarily override the language for one program and show that it is really temporary:
$ LANG=C ls /nonexistent
ls: cannot access /nonexistent: No such file or directory
$ ls /nonexistent
ls: kan geen toegang krijgen tot /nonexistent: Bestand of map bestaat niet
Change the locale for all commands executed in the current shell and include proofs again:
$ LANG=C
$ ls /nonexistent
$ locale
LANG=C
LANGUAGE=
LC_CTYPE="C"
LC_NUMERIC="C"
LC_TIME="C"
LC_COLLATE="C"
LC_MONETARY="C"
LC_MESSAGES="C"
LC_PAPER="C"
LC_NAME="C"
LC_ADDRESS="C"
LC_TELEPHONE="C"
LC_MEASUREMENT="C"
LC_IDENTIFICATION="C"
LC_ALL=
Lekensteyn
  • 178,446
12
Lekensteyn's helpful answer works great if you want to switch to US English on demand, as the OP requested, but if you want to switch to a different language on demand, more work is needed.
Before starting, you must install message tables with sudo apt-get install language-pack-<lang-tag>, where <lang-tag> is a simple RTF 5646 language subtag, such as es for Spanish.
Background info
GNU gettext-based utilities give precedence to the nonstandard LANGUAGE environment variable[1] over POSIX-defined locale environment variables LC_ALL, LC_MESSAGES, and LANG (in that order).
Given that LANGUAGE is set by default on Ubuntu systems[2], namely to a substring of the LANG value that reflects either a simple language tag (e.g., es for Spanish) or a language-region tag (e.g., de_DE for the Germany variant of German), you must unset or override LANGUAGE in order for a different language's messages to take effect.[3]
Option 1: Set LANGUAGE
Example: Switch to Spanish (es) messages ad-hoc:
$ LANGUAGE=es ls NoSuchFile
ls: no se puede acceder a NoSuchFile: No existe el archivo o el directorio
Note: A simple language tag such as es is sufficient, but you may add a region identifier (e.g., es_AR for Argentina), and even a charset suffix (e.g., es_AR.UTF-8).
However, localized messages may only exist at the language level, and the fallback is to use messages that match the language part (es, in this case).
Option 2: Unset LANGUAGE and set LC_ALL
This alternative solution undefines LANGUAGE first, and then uses POSIX locale environment variable LC_ALL to implicitly set LC_MESSAGES[4]:
$ LANGUAGE= LC_ALL=es_ES.UTF-8 ls NoSuchFile
This solution has the advantage of setting all localization aspects to the specified locale (such as LC_TIME for date/time formats) and by (implicitly) setting LC_MESSAGES also informs non-GNU programs of the desired language.
Note how LC_ALL requires the exact, full locale name, including charset suffix, to be effective (es_ES.UTF-8) (unlike LANGUAGE, for which a simple language tag is sufficient (like es)). The same applies to setting LC_MESSSAGES and LANG. Specifying an invalid / non-installed locale name causes fallback to the POSIX locale and therefore US English.
Footnotes
[1] The reasons that Lekensteyn's answer works even _without_ unsetting / overriding `LANGUAGE` is an _exception_: if the (effective) `LC_MESSAGES` value (typically set indirectly via `LANG` or `LC_ALL`) is either `C` or (its synonym) `POSIX`, that value is respected, irrespective of the value of `LANGUAGE`, if any. Conversely, if the (effective) `LC_MESSAGES` value is any other, _specific_ locale, `LANGUAGE` takes precedence. [2] This applies to [Ubuntu proper](https://www.ubuntu.com/), but not necessarily to [other flavors](https://www.ubuntu.com/about/about-ubuntu/flavours); Lekensteyn states that [Kubuntu](https://kubuntu.org/) does _not_ set `LANGUAGE`. Arguably, `LANGUAGE` should _not_ be set by default, given that in its absence the `LC_MESSAGES` value implied by the `LANG` value (which determines the current locale), is respected. [3] You can also use this approach to switch to [US] English by assigning either `LANGUAGE=C` or `LANGUAGE=POSIX` (as an alternative to, `LANG=C` / `LANG=POSIX`), though I'm unclear whether that is actively recognized or simply a _fallback_ mechanism, given that these values don't start with a _language_ tag; perhaps the better choice would be `en_US`. [4] There's an _edge_ case where this approach doesn't work: Trying to invoke an executable with a _path_ - whether relative or absolute - does NOT switch to the specified language, whereas a _mere filename_ does: `LANGUAGE= LC_ALL=es_ES.UTF-8 /path/to/no_such_utility` does _not_ work (outputs a message in the current locale), whereas `LANGUAGE= LC_ALL=es_ES.UTF-8 no_such_utility` does (outputs a Spanish error message). If anyone knows why and whether there's a good reason for this, do let us know.
mklement0
  • 257
