When I was installing MTS Mblaz crossplatformui.deb for MTS data connect, its installed partial and shows error, and So I tried to uninstall "crossplatformui" but every time it showed following error.
installArchives() failed: perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = "en_IN.ISO8859-1"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
LANGUAGE = (unset),
LC_ALL = (unset),
LANGUAGE = (unset),
LC_ALL = (unset),
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 205769 files and directories currently installed.)
Removing crossplatformui ...
ztemtvcdromd: no process found
dpkg: error processing crossplatformui (--remove):
subprocess installed post-removal script returned error exit status 1
No apport report written because MaxReports is reached already
crossplatformui
Setting up firmware-b43-installer (4.150.10.5-5) ...
--2012-06-01 14:11:21-- http://mirror2.openwrt.org/sources/broadcom-wl-4.150.10.5.tar.bz2
Resolving mirror2.openwrt.org... 46.4.11.11
Connecting to mirror2.openwrt.org|46.4.11.11|:80... failed: Connection refused.
dpkg: error processing firmware-b43-installer (--configure):
subprocess installed post-installation script returned error exit status 4
