I want to run a Baka-MPlayer (a QT application) with another language (Dutch). I tried doing LANG=nl_NL.UTF-8 ./baka-mplayer, but it didn't work. My current LANG variable is set to en_GB.UTF-8 When I type in LANG=nl_NL.UTF-8 locale, it gives an error that the locale isn't installed.
wb9688
  • 1,477
  • 17
  • 30
Some qt applications use (incorrectly) the LC_NUMERIC locale category to pick the display language. Hence you may want to try:
LC_NUMERIC=nl_NL.UTF-8 ./application
Or, if that doesn't work either, try:
LC_ALL=nl_NL.UTF-8 ./application
Edit:
When seeing the additional info after you edited the question, it looks like you haven't installed the Dutch language. You'd better do so using Language Support.
