Following upgrading from 20.04 to 22.04, networking doesn't work until I issue
sudo nmcli networking off && sudo nmcli networking on
This is true of both ethernet/wired and wifi and ping from the terminal. I'm running Ubuntu 22.04 on a Lenovo X230 laptop.
Perhaps relevant: when using Ubuntu 20.04 networking would work on boot but when I swapped from wired to wifi or vice versa, I needed to restart NetworkManager with the above command. Under 22.04 networking doesn't work on boot until it's restarted and I need to restart when switching.
I could hack it by adding it to login but I'm sure it'll bite me later if I don't find the root cause.
Here's the result of sudo journalctl -b 0 -u NetworkManager after boot when networking isn't working. This is using a wired connection with wifi turned off, confirmed by sw rfkill:
Aug 23 11:13:19 lenovo-x230u systemd[1]: Starting Network Manager...
Aug 23 11:13:19 lenovo-x230u NetworkManager[1248]: <info>  [1661249599.3132] NetworkManager (version 1.36.6) is starting... (for the first time)
Aug 23 11:13:19 lenovo-x230u NetworkManager[1248]: <info>  [1661249599.3139] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 10-dns-resolved.conf, 20-connectivity-ubuntu.conf, no-mac-addr-change.conf) (run: 10-globally-managed-devices.conf) (etc: default-wifi-powersave-on.conf, wgpia.conf)
Aug 23 11:13:19 lenovo-x230u NetworkManager[1248]: <info>  [1661249599.3384] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
Aug 23 11:13:19 lenovo-x230u systemd[1]: Started Network Manager.
Aug 23 11:13:19 lenovo-x230u NetworkManager[1248]: <info>  [1661249599.3524] manager[0x556e30144030]: monitoring kernel firmware directory '/lib/firmware'.
Aug 23 11:13:19 lenovo-x230u NetworkManager[1248]: <info>  [1661249599.3525] monitoring ifupdown state file '/run/network/ifstate'.
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1036] hostname: hostname: using hostnamed
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1036] hostname: static hostname changed from (none) to "lenovo-x230u"
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1081] dns-mgr[0x556e3011e2a0]: init: dns=systemd-resolved rc-manager=unmanaged (auto), plugin=systemd-resolved
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1107] rfkill2: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.1/0000:03:00.0/ieee80211/phy0/rfkill2) (driver iwlwifi)
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1111] rfkill1: found WWAN radio killswitch (at /sys/devices/platform/thinkpad_acpi/rfkill/rfkill1) (platform driver thinkpad_acpi)
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1170] manager[0x556e30144030]: rfkill: Wi-Fi hardware radio set disabled
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1192] manager[0x556e30144030]: rfkill: WWAN hardware radio set enabled
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1292] Loaded device plugin: NMTeamFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/1.36.6/libnm-device-plugin-team.so)
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1364] Loaded device plugin: NMBluezManager (/usr/lib/x86_64-linux-gnu/NetworkManager/1.36.6/libnm-device-plugin-bluetooth.so)
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1373] Loaded device plugin: NMWwanFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/1.36.6/libnm-device-plugin-wwan.so)
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1393] Loaded device plugin: NMWifiFactory (/usr/lib/x86_64-linux-gnu/NetworkManager/1.36.6/libnm-device-plugin-wifi.so)
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1414] Loaded device plugin: NMAtmManager (/usr/lib/x86_64-linux-gnu/NetworkManager/1.36.6/libnm-device-plugin-adsl.so)
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1419] manager: rfkill: Wi-Fi enabled by radio killswitch; disabled by state file
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1421] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1423] manager: Networking is enabled by state file
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1510] settings: Loaded settings plugin: ifupdown ("/usr/lib/x86_64-linux-gnu/NetworkManager/1.36.6/libnm-settings-plugin-ifupdown.so")
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1511] settings: Loaded settings plugin: keyfile (internal)
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1511] ifupdown: management mode: managed
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1512] ifupdown:       interface-parser: parsing file /etc/network/interfaces
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1512] ifupdown:       interface-parser: finished parsing file /etc/network/interfaces
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1718] dhcp-init: Using DHCP client 'internal'
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1719] device (lo): carrier: link connected
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1723] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1747] manager: (enp0s25): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.1784] device (enp0s25): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.4234] device (wlp3s0): driver supports Access Point (AP) mode
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.4245] manager: (wlp3s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.4273] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.4338] manager: rfkill: Wi-Fi now disabled by radio killswitch
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.4612] modem-manager: ModemManager available
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.6117] manager: (D0:3F:AA:1D:31:62): new Bluetooth device (/org/freedesktop/NetworkManager/Devices/4)
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.6154] device (D0:3F:AA:1D:31:62): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Aug 23 11:13:20 lenovo-x230u NetworkManager[1248]: <info>  [1661249600.6208] device (D0:3F:AA:1D:31:62): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Aug 23 11:13:23 lenovo-x230u NetworkManager[1248]: <info>  [1661249603.9315] device (enp0s25): carrier: link connected
Aug 23 11:13:23 lenovo-x230u NetworkManager[1248]: <info>  [1661249603.9323] device (enp0s25): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Aug 23 11:13:23 lenovo-x230u NetworkManager[1248]: <info>  [1661249603.9342] policy: auto-activating connection 'Wired connection 1' (83d94562-7e3b-3ed8-a967-ecbb1533efd1)
Aug 23 11:13:23 lenovo-x230u NetworkManager[1248]: <info>  [1661249603.9355] device (enp0s25): Activation: starting connection 'Wired connection 1' (83d94562-7e3b-3ed8-a967-ecbb1533efd1)
Aug 23 11:13:23 lenovo-x230u NetworkManager[1248]: <info>  [1661249603.9358] device (enp0s25): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Aug 23 11:13:23 lenovo-x230u NetworkManager[1248]: <info>  [1661249603.9367] manager: NetworkManager state is now CONNECTING
Aug 23 11:13:23 lenovo-x230u NetworkManager[1248]: <info>  [1661249603.9372] device (enp0s25): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Aug 23 11:13:23 lenovo-x230u NetworkManager[1248]: <info>  [1661249603.9392] device (enp0s25): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Aug 23 11:13:23 lenovo-x230u NetworkManager[1248]: <info>  [1661249603.9405] dhcp4 (enp0s25): activation: beginning transaction (timeout in 45 seconds)
Aug 23 11:13:30 lenovo-x230u NetworkManager[1248]: <info>  [1661249610.0654] dhcp4 (enp0s25): state changed new lease, address=109.41.187.122
Aug 23 11:13:30 lenovo-x230u NetworkManager[1248]: <info>  [1661249610.0697] device (enp0s25): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Aug 23 11:13:30 lenovo-x230u NetworkManager[1248]: <info>  [1661249610.0748] device (enp0s25): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Aug 23 11:13:30 lenovo-x230u NetworkManager[1248]: <info>  [1661249610.0752] device (enp0s25): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Aug 23 11:13:30 lenovo-x230u NetworkManager[1248]: <info>  [1661249610.0757] manager: NetworkManager state is now CONNECTED_LOCAL
Aug 23 11:13:30 lenovo-x230u NetworkManager[1248]: <info>  [1661249610.0763] manager: NetworkManager state is now CONNECTED_SITE
Aug 23 11:13:30 lenovo-x230u NetworkManager[1248]: <info>  [1661249610.0764] policy: set 'Wired connection 1' (enp0s25) as default for IPv4 routing and DNS
Aug 23 11:13:30 lenovo-x230u NetworkManager[1248]: <info>  [1661249610.0775] device (enp0s25): Activation: successful, device activated.
Aug 23 11:13:30 lenovo-x230u NetworkManager[1248]: <info>  [1661249610.0783] manager: NetworkManager state is now CONNECTED_GLOBAL
Aug 23 11:13:30 lenovo-x230u NetworkManager[1248]: <info>  [1661249610.0792] manager: startup complete
Aug 23 11:13:31 lenovo-x230u NetworkManager[1248]: <info>  [1661249611.5250] manager: (tun0): new Tun device (/org/freedesktop/NetworkManager/Devices/5)
Aug 23 11:13:31 lenovo-x230u NetworkManager[1248]: <info>  [1661249611.5372] device (tun0): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
Aug 23 11:13:31 lenovo-x230u NetworkManager[1248]: <info>  [1661249611.5379] device (tun0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
Aug 23 11:13:31 lenovo-x230u NetworkManager[1248]: <info>  [1661249611.5387] device (tun0): Activation: starting connection 'tun0' (701076b1-8a64-43a5-afbe-e8f74c5d1988)
Aug 23 11:13:31 lenovo-x230u NetworkManager[1248]: <info>  [1661249611.5389] device (tun0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
Aug 23 11:13:31 lenovo-x230u NetworkManager[1248]: <info>  [1661249611.5392] device (tun0): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
Aug 23 11:13:31 lenovo-x230u NetworkManager[1248]: <info>  [1661249611.5394] device (tun0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
Aug 23 11:13:31 lenovo-x230u NetworkManager[1248]: <info>  [1661249611.5397] device (tun0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
Aug 23 11:13:31 lenovo-x230u NetworkManager[1248]: <info>  [1661249611.5450] device (tun0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Aug 23 11:13:31 lenovo-x230u NetworkManager[1248]: <info>  [1661249611.5453] device (tun0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
Aug 23 11:13:31 lenovo-x230u NetworkManager[1248]: <info>  [1661249611.5459] device (tun0): Activation: successful, device activated.
Aug 23 11:13:31 lenovo-x230u NetworkManager[1248]: <info>  [1661249611.5806] device (tun0): state change: activated -> unmanaged (reason 'unmanaged', sys-iface-state: 'removed')
Aug 23 11:13:32 lenovo-x230u NetworkManager[1248]: <info>  [1661249612.7841] agent-manager: agent[4b5f25c2c3ee9b06,:1.66/org.gnome.Shell.NetworkAgent/120]: agent registered
Aug 23 11:13:42 lenovo-x230u NetworkManager[1248]: <info>  [1661249622.1267] manager: (cdc-wdm2): new Broadband device (/org/freedesktop/NetworkManager/Devices/6)
Aug 23 11:13:42 lenovo-x230u NetworkManager[1248]: <info>  [1661249622.1269] device (cdc-wdm2): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Aug 23 11:13:42 lenovo-x230u NetworkManager[1248]: <info>  [1661249622.1272] device (cdc-wdm2): modem state 'failed'
Aug 23 11:13:42 lenovo-x230u NetworkManager[1248]: <info>  [1661249622.1274] modem-broadband[cdc-wdm2]: failed to retrieve SIM object: No SIM object available
Aug 23 11:13:43 lenovo-x230u NetworkManager[1248]: <info>  [1661249623.6756] agent-manager: agent[f9c25a7fcc12b782,:1.105/org.gnome.Shell.NetworkAgent/1000]: agent registered
And here's what gets added to journalctl when restarted and networking works:
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.1751] manager: disable requested (sleeping: no  enabled: yes)
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.1751] device (wlp3s0): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.1761] device (D0:3F:AA:1D:31:62): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.1765] device (cdc-wdm2): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.1768] manager: NetworkManager state is now ASLEEP
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.1772] audit: op="networking-control" arg="off" pid=3691 uid=0 result="success"
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.1772] device (enp0s25): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.2051] device (enp0s25): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.2290] dhcp4 (enp0s25): canceled DHCP transaction
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.2290] dhcp4 (enp0s25): activation: beginning transaction (timeout in 45 seconds)
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.2291] dhcp4 (enp0s25): state changed no lease
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.2605] device (enp0s25): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.3726] manager: enable requested (sleeping: no  enabled: no)
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.3726] device (enp0s25): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.5898] device (wlp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.5913] device (D0:3F:AA:1D:31:62): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.5919] device (cdc-wdm2): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.5922] device (cdc-wdm2): modem state 'failed'
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.5922] manager: NetworkManager state is now DISCONNECTED
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.5925] audit: op="networking-control" arg="on" pid=3701 uid=0 result="success"
Aug 23 11:21:04 lenovo-x230uu NetworkManager[1248]: <info>  [1661250064.5927] device (D0:3F:AA:1D:31:62): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Aug 23 11:21:07 lenovo-x230uu NetworkManager[1248]: <info>  [1661250067.9398] device (enp0s25): carrier: link connected
Aug 23 11:21:07 lenovo-x230uu NetworkManager[1248]: <info>  [1661250067.9401] device (enp0s25): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Aug 23 11:21:07 lenovo-x230uu NetworkManager[1248]: <info>  [1661250067.9412] policy: auto-activating connection 'Wired connection 1' (83d94562-7e3b-3ed8-a967-ecbb1533efd1)
Aug 23 11:21:07 lenovo-x230uu NetworkManager[1248]: <info>  [1661250067.9417] device (enp0s25): Activation: starting connection 'Wired connection 1' (83d94562-7e3b-3ed8-a967-ecbb1533efd1)
Aug 23 11:21:07 lenovo-x230uu NetworkManager[1248]: <info>  [1661250067.9418] device (enp0s25): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Aug 23 11:21:07 lenovo-x230uu NetworkManager[1248]: <info>  [1661250067.9421] manager: NetworkManager state is now CONNECTING
Aug 23 11:21:07 lenovo-x230uu NetworkManager[1248]: <info>  [1661250067.9423] device (enp0s25): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Aug 23 11:21:07 lenovo-x230uu NetworkManager[1248]: <info>  [1661250067.9427] device (enp0s25): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Aug 23 11:21:07 lenovo-x230uu NetworkManager[1248]: <info>  [1661250067.9446] dhcp4 (enp0s25): activation: beginning transaction (timeout in 45 seconds)
Aug 23 11:21:13 lenovo-x230uu NetworkManager[1248]: <info>  [1661250073.3108] dhcp4 (enp0s25): state changed new lease, address=109.41.187.122
Aug 23 11:21:13 lenovo-x230uu NetworkManager[1248]: <info>  [1661250073.3141] device (enp0s25): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Aug 23 11:21:13 lenovo-x230uu NetworkManager[1248]: <info>  [1661250073.3180] device (enp0s25): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Aug 23 11:21:13 lenovo-x230uu NetworkManager[1248]: <info>  [1661250073.3182] device (enp0s25): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Aug 23 11:21:13 lenovo-x230uu NetworkManager[1248]: <info>  [1661250073.3186] manager: NetworkManager state is now CONNECTED_LOCAL
Aug 23 11:21:13 lenovo-x230uu NetworkManager[1248]: <info>  [1661250073.3190] manager: NetworkManager state is now CONNECTED_SITE
Aug 23 11:21:13 lenovo-x230uu NetworkManager[1248]: <info>  [1661250073.3191] policy: set 'Wired connection 1' (enp0s25) as default for IPv4 routing and DNS
Aug 23 11:21:13 lenovo-x230uu NetworkManager[1248]: <info>  [1661250073.3198] device (enp0s25): Activation: successful, device activated.
Aug 23 11:21:13 lenovo-x230uu NetworkManager[1248]: <info>  [1661250073.3202] manager: NetworkManager state is now CONNECTED_GLOBAL
Aug 23 11:21:19 lenovo-x230uu NetworkManager[1248]: <info>  [1661250079.5315] manager: (tun0): new Tun device (/org/freedesktop/NetworkManager/Devices/7)
Aug 23 11:21:19 lenovo-x230uu NetworkManager[1248]: <info>  [1661250079.5457] device (tun0): state change: unmanaged -> unavailable (reason 'connection-assumed', sys-iface-state: 'external')
Aug 23 11:21:19 lenovo-x230uu NetworkManager[1248]: <info>  [1661250079.5463] device (tun0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external')
Aug 23 11:21:19 lenovo-x230uu NetworkManager[1248]: <info>  [1661250079.5472] device (tun0): Activation: starting connection 'tun0' (636e9827-baab-4be7-a7c2-5a85705cb915)
Aug 23 11:21:19 lenovo-x230uu NetworkManager[1248]: <info>  [1661250079.5474] device (tun0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external')
Aug 23 11:21:19 lenovo-x230uu NetworkManager[1248]: <info>  [1661250079.5477] device (tun0): state change: prepare -> config (reason 'none', sys-iface-state: 'external')
Aug 23 11:21:19 lenovo-x230uu NetworkManager[1248]: <info>  [1661250079.5479] device (tun0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external')
Aug 23 11:21:19 lenovo-x230uu NetworkManager[1248]: <info>  [1661250079.5482] device (tun0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external')
Aug 23 11:21:19 lenovo-x230uu NetworkManager[1248]: <info>  [1661250079.5573] device (tun0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external')
Aug 23 11:21:19 lenovo-x230uu NetworkManager[1248]: <info>  [1661250079.5575] device (tun0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external')
Aug 23 11:21:19 lenovo-x230uu NetworkManager[1248]: <info>  [1661250079.5582] device (tun0): Activation: successful, device activated.
I can't see the reason for one working and the other not.
When it's not working ping www.google.com results in ping: www.google.com: Name or service not known
/etc/network/interfaces contains
# The loopback network interface
auto lo
iface lo inet loopback
/etc/network/interfaces.d is empty
When working output from sudo ifconfig enp0s25 is
enp0s25: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.1.122  netmask 255.255.255.0  broadcast 192.168.1.255
        inet6 fe80::d674:d367:b557:214  prefixlen 64  scopeid 0x20<link>
        ether 3c:97:0e:ce:42:5f  txqueuelen 1000  (Ethernet)
        RX packets 7241  bytes 4999361 (4.9 MB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 6657  bytes 1431722 (1.4 MB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device interrupt 20  memory 0xf1500000-f1520000
And when not working (previously been working hence packet count):
        RX packets 37277  bytes 34292203 (34.2 MB)
        RX errors 0  dropped 2  overruns 0  frame 0
        TX packets 25441  bytes 6275182 (6.2 MB)
uname -a gives
Linux lenevo-x230u 5.15.0-46-generic #49-Ubuntu SMP Thu Aug 4 18:03:25 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
rfkill list all gives
0: tpacpi_bluetooth_sw: Bluetooth
    Soft blocked: no
    Hard blocked: no
1: phy0: Wireless LAN
    Soft blocked: yes
    Hard blocked: no
2: tpacpi_wwan_sw: Wireless WAN
    Soft blocked: no
    Hard blocked: no
3: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
The yes for wifi is expected as I'm currently testing with wired. If I switch wifi back on, rfkill behaves as expected and network issue remains.
I'm using kernel 5.15.0-46 so it's not this issue
Package backport-iwlwifi-dkms isn't installed so its not this issue
Any help much appreciated
For me the issue seemed to be the VPN kill switch. I use Proton VPN.
Josh
  • 41
I have experienced the same issue, and restarting nmcli as you suggested is the only way I could make it work again. No idea why. Edit: Reports of problems after an update (My network options were not showing either)
dotHello
i had exactly same output on terminal and symtomps. I had to reboot my modem +--+-> Router ----Ethernt to my PC_ubuntu. It worked, right away, after wasting my 4 hours of troubleshooting.
