18
I just installed ubuntu 22.04LTS since it has been release, and right off the bat, I notice my Wifi is extremely slow, it only downloads at 500Kbps, and I tried to download pycharm ~500mbs, it fails each time.
I know it's WiFi issue, because, on connecting an ethernet, the wifi speed bumps upto 5mbps for the same file download, I also checked my internet connection if fine using other devices ( downloaded the same file on my mac)
The output of lspci state:
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
02:00.0 Network controller: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter (rev 01)
which should mean my drivers are installed, right?
The overall experience of ubuntu is better, but, the wifi is having issue. It turns off intermittently, doesn't let me download large files, streaming is also difficult. Is anyone facing this as well?
Should I just downgrade the entire OS? Or is there a way to fix this? (e.g. Can I use the part of the system that handles the networking stuff from previous version of the distro?)
juztcode
  • 369
9 Answers9
16
UPDATE: latest version of ubuntu 22.04 does not have this problem, just install updates. Original answer follows, then detail of which version fixed it for me.
I think it is likely that you are hitting a bug with the 5.15 kernel (linked below) that is used by Ubuntu 22.04. If so you can only fix the problem today by changing to another kernel version without that bug (this can be done without changing anything else). The fix is already available in the kernel sources for 5.15, but downgrading until it is available in the ubuntu 5.15 packages is a reasonable workaround.
Based on dates and schedule only (the upstream fix was committed 28-Mar, after the previous ubuntu kernel commit deadline but before the start of current cycle), I am hopeful that the next scheduled Ubuntu kernel release on 09-May will fix your problem. Source: https://kernel.ubuntu.com/
My experience
I had exactly the same issue with 22.04 - everything else fine, but I had slow wifi that would regularly silently disconnect. I was dual-booting with an existing Ubuntu 21.10 installation which continued to show no similar problems, so I knew that the problem was specific to the updated OS.
This was with a "TP-LINK TL-WDN4800 N900" PCI-e wireless card, with Qualcomm Atheros driver.
I then saw exactly the same wifi behaviour when using the 5.15 kernel in manjaro. The smoking gun here - in my view - is the exact same BAD WIFI behaviour newly occurring over two linux distributions where pretty much the only thing they had in common was kernel version. I've tested each of these:
  • 5.17.1-3 with manjaro - GOOD
  • 5.15.32-1 with manjaro - BAD WIFI
  • 5.15 with ubuntu 22.04 - BAD WIFI
  • 5.13 with ubuntu 21.10 - GOOD
  • 5.10.109-1 with manjaro - GOOD
I know wifi issues can have many causes, and my answer is not perfect - particularly since I haven't reinstalled ubuntu 22.04 and installed a different kernel to verify the fix, but this setup has been rock-solid over many operating systems over the past few years, and this was the first time I've seen behaviour exactly as you did. Since it took me a while to track down, I thought I'd share. Hope it helps. I'll try 22.04 again after the next kernel update - if you're still interested, let me know and I'll let you know the results.
Update with confirmed fix
Using ubuntu's kernel version numbers, the original was 5.15.0.25.27 with broken wifi. On 13 May, the update to 5.15.0.30.33 also had broken wifi. Now on 20 May an update to 5.15.0.33 was offered and it definitely fixes the wifi problems I was having.
Above version numbers are those reported by "Software Updater". For the first fixed version uname -r reports 5.15.0-33-generic
Links
I believe these are what you are seeing:
  • The kernel bug "ath9k frequent connection problems after kernel upgrade": https://bugzilla.kernel.org/show_bug.cgi?id=215703 - notice "The same change that affects 5.16.15 was also incorporated into the 5.15 tree: 5.15.28 works, whereas 5.15.29 and 5.15.30 don't."
  • Discussion of behaviour on arch forum: https://bugs.archlinux.org/task/74187?project=1 - notice "Last night's push of 5.17.1-arch1-1 clearly fixed all the problems I was having with my Qualcomm Atheros AR93xx Wireless card". Different kernel version (5.17.1) but same module, and the same bug exists in 5.15 as shown in previous link.
Updating to kernel 5.17.5 makes stable wifi on Ubuntu 22.04. Warning: a system may not start after updating kernel when secure boot is on.
So, turn off secure boot in BIOS, download kernel (for example in ~/Downloads) and install it, then reboot, example below.
cd ~/Downloads
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.17.5/amd64/linux-headers-5.17.5-051705_5.17.5-051705.202204271406_all.deb
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.17.5/amd64/linux-headers-5.17.5-051705-generic_5.17.5-051705.202204271406_amd64.deb
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.17.5/amd64/linux-image-unsigned-5.17.5-051705-generic_5.17.5-051705.202204271406_amd64.deb
wget -c https://kernel.ubuntu.com/~kernel-ppa/mainline/v5.17.5/amd64/linux-modules-5.17.5-051705-generic_5.17.5-051705.202204271406_amd64.deb
sudo dpkg -i *.deb
Pilot6
  • 92,041
Because there is a bug in kernel 5.15 as mentioned by @lain haslam, you can use an older version of the kernel by holding the SHIFT button while booting to enter GRUB then go to Advanced options for ubuntu then you can use ubuntu with an older kernel
From My Experience I have downgraded the kernel from 5.15 to 5.13 and it works
The other solutions listed here did not work for me. The only way to solve the problem was for me to install Ubuntu 22.10!
Andrea Araldo
  • 198
Just installed 22.04 LTS, in hope to say good bye to Windows, which comes with this kernel Linux 5.15.0-25-generic, then did an upgrade, not on purpose to update the kernel but it has been updated to Linux 5.19.0-43-generic, then I noticed the internet problem! It's discouraging, really.
I tried different options to solve this. like disableing IP6, setting wifi.powersave from 3 to 2 or adding 11n_disable=8 to the end of /etc/modprobe.d/iwlwifi.conf, none of these helps.
So I tried to upgrade to kernel 6.3, which also doesn't work but I noticed I have also 5.15 version, so I tried that, which seems works fine, it has been a couple hours now. So I shall remove the new versions in my system.
Happy ubuntu again!
Harry
  • 151
since the Ethernet connection is working, you should be able to find a solution from link, however, not recommended to attempt anything that involves disabling network manager. I bricked my machine trying
couple of easily reversible solutions you can try from the link:
1.sudo nano /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
Then changed the value from 3 to 2, save changes and reboot. if not working, switch back to 3.
2.sudo nano /etc/gai.conf
look for the line with precedence ::ffff:0:0/96 100 and removed the # character that preceded it. save changes and reboot. if not working add # back.
you need to use the ctrl key to save, exit, etc.. from the conf screen if you are not aware. And i just tried these two changes to make sure there are no repercussions.
  1. Selecting proprietary wireless driver, which is the last answer posted in the link. However, looking at the driver info you posted, you probably don't have that option. No harm checking tho.
ManOnTheMoon
  • 1,512
I can confirm at the moment the best and easiest way to have working wifi on 22.04 is kernel 5.13. But my suggestion is first to be installed 21.10 (about 25 min) and then this Ubuntu version to be upgraded to 22.04 (sudo do-release-upgrade -m desktop - again about 25 min). Then after installation of GRUB Customizer(easiest way) kernel 5.13 to be set as the main system kernel. Kernel 5.15.0-33 (or probably above) to be kept. As to the others, they can be cleaned.
EDIT: After kernel update up to 5.15.0-35 the wifi issue is solved and now it is possible clean Ubuntu 22.04 installation
BlB
Very recently I had asked this question too, and in my case adding 11n_disable=8 to /etc/modprobe.d/iwlwifi.conf helped. Here is the link: Wifi speed significantly slower on ubuntu 22.04 than on windows
-1
A bit different problem that still qualifies as "wifi issues" in ubuntu 22.04 lts: I could use wifi during installation, but after installation, I could not find my network. It did not see only my wifi! The networks other than mine were still shown!
I repeated the installation without "use 3rd-party software" and "download and install updates" (these are two checkboxes on one of the screens), and my wifi network appeared in the list. (In my case, it was "clear the disk and install" both times, on some old Lenovo notebook). Later I downloaded and installed updates, wifi was still ok. So I believe the cause of the problem was the "3-rd party software" option.
Hope this helps someone.
