On my first hard reboot after upgrading my laptop to 22.04, I noticed problems accessing the internet using either wired or wifi connections.
Unlike other users ( Broken network configuration after upgrade to 22.04 and Network Problems after upgrading to 22.04.1 ), my pings to localhost / 128.0.0.1 succeed 100%, as do pings to my router (192.168.1.1), and I am able to log in to my router from a browser to verify that everything seems fine on the router end. My phone is still able to access the internet via wifi.
Results of ping -c 10 2001:4860:4860::8888: (Ipv6 to google.com)
PING 2001:4860:4860::8888(2001:4860:4860::8888) 56 data bytes
--- 2001:4860:4860::8888 ping statistics ---
10 packets transmitted, 0 received, 100% packet loss, time 9211ms
Results of ifconfig:
enx803f5d0e2b8f: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.23 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::d1f9:5e5d:2b3b:807d prefixlen 64 scopeid 0x20<link>
ether 80:3f:5d:0e:2b:8f txqueuelen 1000 (Ethernet)
RX packets 64 bytes 10712 (10.7 KB)
RX errors 0 dropped 22 overruns 0 frame 0
TX packets 47 bytes 9636 (9.6 KB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
ipv6leakintrf0: flags=195<UP,BROADCAST,RUNNING,NOARP> mtu 1500
inet6 fdeb:446c:912d:8da:: prefixlen 64 scopeid 0x0<global>
inet6 fe80::47e9:ccfd:4704:eb42 prefixlen 64 scopeid 0x20<link>
ether fa:7f:7d:d6:b3:7e txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 23 bytes 3578 (3.5 KB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 117 bytes 9577 (9.5 KB)
TX packets 117 bytes 9577 (9.5 KB)
wlp1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.20 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::8f2a:29b2:2493:7888 prefixlen 64 scopeid 0x20<link>
ether 00:28:f8:6c:82:39 txqueuelen 1000 (Ethernet)
RX packets 18 bytes 4672 (4.6 KB)
TX packets 35 bytes 6534 (6.5 KB)
I tried disabling wired and using only wifi, and also tried disabling wifi and using only wired. Same results.
