I have just installed Ubuntu 22.04 LTS.
It works fine but after I suspend the session, the screen remains black after restarting the session.
How can I solve it?
Got an update from the launchpad. There is a work around for Nividia 510 using the solution from Nividia 470.
Disable NVIDIA systemd services
sudo systemctl stop nvidia-suspend.service
sudo systemctl stop nvidia-hibernate.service
sudo systemctl stop nvidia-resume.service
sudo systemctl disable nvidia-suspend.service
sudo systemctl disable nvidia-hibernate.service
sudo systemctl disable nvidia-resume.service
Remove NVIDIA systemd script
sudo rm /lib/systemd/system-sleep/nvidia
Reboot and you should be able to suspend and resume properly with driver 510 for 22.04 for both x11 and wayland
The original workaround was for 470. However, I've tested it and the solution works for 510 on 22.04 with x11 and wayland.
Original solution with details can be found here by contributor "humblebee". And bug report on launchpad can be found here
In may case downgrading nvidia driver from 510 to 470, via Additional Drivers , solved the issue
It's more of a workaround, but i am able to resume the GUI session after a black screen caused by a suspend by switching to a virtual console (ctrl+alt+F1 to F7 depending on your computer) and then reverting to GUI session (ctrl+alt+FX, again, the FX depending of your computer, F2 for me).
Works for me with nvidia driver 515 and cuda 11.7
Upgrading Nvidia Driver to version 525 solved this problem for me on Ubuntu 22.04 with graphic card model GeForce GTX 1060 (via "Software & Updates"). Note that a user of Linux Mint with the same graphic card had the same problem 10 months ago.
I was having this exact same problem on my HP Pavilion 14 on Ubuntu 22.04. It worked fine a few days ago but I encountered this problem after an update. Lots of stack answers pointed to some problems with Nvidia drivers, but I don't have Nvidia graphics. I have an integrated AMD Radeon along with AMD Ryzen 7.
What worked for me:
Installing amdgpu-install and installing the AMD graphic cards components[1] after checking the secure boot support[2]:
amdgpu-install --usecase=graphics
Also, check this launchpad issue[3].
[1]https://amdgpu-install.readthedocs.io/en/latest/install-overview.html
[3]https://bugs.launchpad.net/ubuntu/+source/linux-signed-hwe-5.19/+bug/2008774
I'm using AMD CPU, and after wakeup, the screen keeps blank.
I fixed it by pressing Ctrl + Alt + F1.
Sometimes I have to keep pressing Ctrl + Alt + F1, but once it gives output to the screen, if I suspend the PC again, it will automatically wake up with the display output properly.
[update]
Finally, I found a permanent solution, and the problem is HDMI. If I connect it to a VGA cable, the screen lights up as normal.
[update]
It seems my monitor is missing the proper information to wake up from the PC, so I tried to change my HDMI cable, and yes, it works. Before, I was using a cheap $1.7 HDMI cable.
For me on a Debian 12 machine with NVIDIA GP107 [GeForce GTX 1050 Ti]
here is the workaround.
I install nvidia driver for my card from debain unstable(sid) repository.
Remove all previous nvidea drivers Installed from current repository or By nvidia website script.
sudo apt purge nvidia-*
Reboot the system to use embedded Intel Graphic card.
deb http://deb.debian.org/debian sid main non-free-firmware non-free contrib
sudo apt update
sudo apt -d -u -t sid install nvidia-driver
sudo apt -t sid install nvidia-driver
After that you can remove sid line from source.list then update source.
sudo apt update
After above steps here is info.
$ nvidia-settings
$ lspci -nn | egrep -i "3d|display|vga"
00:17.0 SATA controller [0106]: Intel Corporation Device [8086:43d2] (rev 11)
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] [10de:1c82] (rev a1)
$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 12 (bookworm)
Release: 12
Codename: bookworm
nvidia-detect
Detected NVIDIA GPUs:
Checking card: NVIDIA Corporation GP107 [GeForce GTX 1050 Ti] (rev a1)
Your card is supported by all driver versions.
Your card is also supported by the Tesla drivers series.
Your card is also supported by the Tesla 470 drivers series.
It is recommended to install the
nvidia-driver
package.
$ nvidia-smi
Sun Mar 10 15:32:51 2024
| NVIDIA-SMI 525.147.05 Driver Version: 525.147.05 CUDA Version: 12.0 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... On | 00000000:01:00.0 On | N/A |
| 45% 32C P0 N/A / 75W | 322MiB / 4096MiB | 5% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 875 G /usr/lib/xorg/Xorg 187MiB |
| 0 N/A N/A 1410 G xfwm4 1MiB |
| 0 N/A N/A 5389 G ...b/firefox-esr/firefox-esr 129MiB |
$ screenfetch
,met$$$$$gg. esmaeel@system
,g$$$$$$$$$$$$$$$P. OS: Debian 12 bookworm
,g$$P"" """Y$$.". Kernel: x86_64 Linux 6.1.0-18-amd64
,$$P' $$$. Uptime: 29m ',$$P ,ggs.$$b: Packages: 2263
`d$$' ,$P"' . $$$ Shell: bash 5.2.15
$$P d$' , $$P Resolution: 1920x1080
$$: $$. - ,d$$' DE: Xfce
$$; Y$b. ,d$P' WM: Xfwm4
Y$$. ."Y$$$$P"' WM Theme: Default
$$b "-.__ GTK Theme: Xfce [GTK2]Y$$ Icon Theme: Tango
Y$$. Font: Sans 10$$b. Disk: 76G / 440G (19%)
Y$$b. CPU: Intel Core i5-10400 @ 12x 4.3GHz [46.0°C]"Y$b. GPU: NVIDIA GeForce GTX 1050 Ti
`"""" RAM: 10337MiB / 31947MiB
My Laptop is having NVIDIA 3050 MOBILE, nothing worked except this
sudo apt update
sudo apt install nvidia-prime
sudo prime-select intel
Verify using - prime-select query
