I am new to Linux. Immediately encountered the problem of very weak wifi signal, that i haven't on windows. I've already seen the solutions for HP laptops, and none of them worked for me. Tried to change kernel as well (I heard that 5.15 version is kinda buggy in this context), but still nothing. I got following output for lshw -C network command:
  *-network
       description: Wireless interface
       product: Cannon Lake PCH CNVi WiFi
       vendor: Intel Corporation
       physical id: 14.3
       bus info: pci@0000:00:14.3
       logical name: wlo1
       version: 10
       serial: 8c:c6:81:dc:69:82
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=5.17.13-051713-generic firmware=46.fae53a8b.0 9000-pu-b0-jf-b0- ip=192.168.6.154 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:16 memory:a441c000-a441ffff
  *-network
       description: Ethernet interface
       product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
       vendor: Realtek Semiconductor Co., Ltd.
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: enp3s0
       version: 15
       serial: d4:5d:64:64:3c:48
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.17.13-051713-generic firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=twisted pair
       resources: irq:16 ioport:3000(size=256) memory:a4204000-a4204fff memory:a4200000-a4203fff
And for lspci it is
00:14.3 Network controller: Intel Corporation Cannon Lake PCH CNVi WiFi (rev 10)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
I thought that updating WiFi driver would help, but saddly there's no version I can update for.
I would be incredibly grateful if someone could help
UPD 1. Result of the terminal command: nmcli device wifi list is following. Where Androidha is my phone on which I turned on the hotspot and I literally placed my phone on the laptop, and it's still, not even close to "strong signal", the phone itself is connected to one of these other WiFi. Two other routers are in adjacent room.
IN-USE  BSSID              SSID       MODE   CHAN  RATE        SIGNAL  BARS  SECURITY
*       BA:C0:86:C4:F2:55  Androidha  Infra  1     117 Mbit/s  54      ▂▄__  WPA3
        AC:22:05:7B:A6:B3  ANM19      Infra  1     130 Mbit/s  29      ▂___  WPA1 WPA2
        38:A6:59:D6:DC:67  T-U3E4cU   Infra  36    540 Mbit/s  29      ▂___  WPA1 WPA2
