I have a problem with the nvidia driver. Did a apt update and the machine powered off in the night. After power on I get the blinking cursor. Even did a complete reinstall on a spare disk (with update during installation on) and have the same situation. nvidia-340 fails to build.
ubuntu-drivers autoinstall
Reading package lists...
Building dependency tree...
Reading state information...
0 upgraded, 0 newly installed, 0 to remove and 305 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up nvidia-340 (340.108-0ubuntu2) ...
dpkg: error: version '-' has bad syntax: revision number is empty
update-initramfs: deferring update (trigger activated)
INFO:Enable nvidia-340
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
Removing old nvidia-340-340.108 DKMS files...
Deleting module version: 340.108 completely from the DKMS tree.
Done. Loading new nvidia-340-340.108 DKMS files... Building for 5.8.0-36-generic Building for architecture x86_64 Building initial module for 5.8.0-36-generic ERROR: Cannot create report: [Errno 17] File exists: '/var/crash/nvidia-340.0.crash' Error! Bad return status for module build on kernel: 5.8.0-36-generic (x86_64) Consult /var/lib/dkms/nvidia-340/340.108/build/make.log for more information. dpkg: error processing package nvidia-340 (--configure): installed nvidia-340 package post-installation script subprocess returned error exit status 10 Processing triggers for libc-bin (2.31-0ubuntu9) ... Processing triggers for initramfs-tools (0.136ubuntu6.2) ... update-initramfs: Generating /boot/initrd.img-5.8.0-36-generic Errors were encountered while processing: nvidia-340 E: Sub-process /usr/bin/dpkg returned an error code (1)
nvidia-340.0.crash -> https://controlc.com/fb556872 make.log -> https://controlc.com/5bf2520a
Uhura
Revert back to an older kernel other than 5.8.0-36-generic.
Hold down shift while powering up. Choose an older kernel and boot up.
From there you will have a working machine and can research how to remove the bad kernel.
Keep in mind that until you remove the bad kernel and heading it will try to use it at every re-boot.
I'm going through this right now as well. Seems a lot of people have been affected.
Yes, boot a 5.4 kernel.
If you need to reboot often, you can always use grub-customizer unitil the bug is fixed:
https://bugs.launchpad.net/ubuntu/+source/linux-hwe-5.8/+bug/191113
LarsAamo
  • 445
