I am experiencing weird freeze of Ubuntu 20.04. I cannot move the cursor, audio stops and I have to hard reboot with the power button. I have a Dell Inspiron 15 7501 (+8GB ram installed by myself) since a month or so, and I installed Ubuntu 20.04 with Win10 Home in dual boot as soon as I received the laptop. Everything in Win10 works fine, and also on Ubuntu since yesterday. I have not installed anything in the past few days.
Initially It happened 3 times when having 1 Mozilla tab with Overleaf, some pdfs (2 or 3) and a python3 shell used as a calculator, running nothing. The fourth time I had 3 Mozilla tab and 1 pdf.
I already tried to increase the swap memory from 2Gb to 8Gb as suggested here Ubuntu 20.04 random freeze ups but it didn't work. I post here the link to the system log files retrieved with the command cat /var/log/syslog of the third and fourth freeze:
3rd - https://drive.google.com/file/d/14mukUNN1VoGJjiKXhw29WHauxNjkjspY/view?usp=sharing
4th - https://drive.google.com/file/d/1CBTFliwg8RA96UpeMGsGuuJ3ZBKBdM73/view?usp=sharing
Sorry for the google drive link, I have no idea on how to share this kind of terminal output in a simple way.
Thank you for your help
Francesco
Edit as requested:
free -h
total used free shared buff/cache available
Mem: 15Gi 1,5Gi 12Gi 220Mi 1,4Gi 13Gi
Swap: 8,0Gi 0B 8,0Gi
sysctl vm.swappiness
vm.swappiness = 60
sudo lshw -C memory
PCI (sysfs)
-firmware
description: BIOS
vendor: Dell Inc.
physical id: 0
version: 1.3.0
date: 08/18/2020
capacity: 24MiB
capabilities: pci pnp upgrade shadowing cdboot bootselect edd int5printscreen int9keyboard int14serial int17printer acpi usb smartbattery biosbootspecification netboot uefi
-cache:0
description: L1 cache
physical id: 700
slot: L1 Cache
capacity: 256KiB
capabilities: synchronous internal write-back unified
configuration: level=1
-cache:1
description: L2 cache
physical id: 701
slot: L2 Cache
capacity: 1MiB
configuration: level=2
-cache:2
description: L3 cache
physical id: 702
slot: L3 Cache
capacity: 8MiB
configuration: level=3
-memory
description: System Memory
physical id: 1000
slot: System board or motherboard
-bank:0
description: SODIMM DDR4 Synchronous 3200 MHz (0,3 ns)
vendor: 000000003180
physical id: 0
serial: 00000000
slot: Motherboard
width: 64 bits
clock: 3200MHz (0.3ns)
-bank:1
product: CT8G4SFRA32A.C4FE
vendor: 859B00000000
physical id: 1
serial: E3742A1E
slot: DIMM B
width: 64 bits
-memory UNCLAIMED
description: RAM memory
product: Comet Lake PCH Shared SRAM
vendor: Intel Corporation
physical id: 14.2
bus info: pci@0000:00:14.2
version: 00
width: 64 bits
clock: 33MHz (30.3ns)
capabilities: pm cap_list
configuration: latency=0
resources: iomemory:600-5ff iomemory:600-5ff memory:6023120000-6023121fff memory:6023128000-6023128fff
grep -i swap /etc/fstab
/swapfile none swap sw 0 0
ls -al /var/crash
totale 4028
drwxrwsrwt 2 root whoopsie 4096 nov 24 18:45 .
drwxr-xr-x 14 root root 4096 lug 31 18:35 ..
-rw-r----- 1 francesco whoopsie 4108506 nov 24 18:45 _usr_bin_seahorse.1000.crash
-rw-r--r-- 1 francesco whoopsie 0 nov 24 18:45 _usr_bin_seahorse.1000.upload
-rw------- 1 whoopsie whoopsie 37 nov 24 18:45 _usr_bin_seahorse.1000.uploaded
sudo dmidecode -s bios-version
1.3.0
