I have a Dummy Output appearing in my Output Devices and no sound works. I already read lots of questions on this site, but no proposed soltion worked for me persistently.
Diagnostics
lspci -nnk | grep -A3
06:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:1637]
Subsystem: Lenovo Device [17aa:5082]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
06:00.5 Multimedia controller [0480]: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor [1022:15e2] (rev 01)
Subsystem: Lenovo Raven/Raven2/FireFlight/Renoir Audio Processor [17aa:5084]
Kernel driver in use: snd_rn_pci_acp3x
Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x
06:00.6 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller [1022:15e3]
Subsystem: Lenovo Family 17h (Models 10h-1fh) HD Audio Controller [17aa:5082]
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: Generic [HD-Audio Generic], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: Generic [HD-Audio Generic], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: Generic_1 [HD-Audio Generic], device 0: ALC257 Analog [ALC257 Analog]
Subdevices: 1/1
fuser -v /dev/snd/*
USER PID ACCESS COMMAND
/dev/snd/controlC0: jonas 1176 F.... pulseaudio
/dev/snd/controlC2: jonas 1176 F.... pulseaudio
find /lib/modules | grep snd | grep hda | grep intel
/lib/modules/5.4.0-52-generic/kernel/sound/soc/sof/intel/snd-sof-intel-hda.ko
/lib/modules/5.4.0-52-generic/kernel/sound/soc/sof/intel/snd-sof-intel-hda-common.ko
/lib/modules/5.4.0-52-generic/kernel/sound/soc/intel/boards/snd-soc-skl_hda_dsp.ko
/lib/modules/5.4.0-52-generic/kernel/sound/pci/hda/snd-hda-intel.ko
/lib/modules/5.4.0-52-generic/kernel/sound/hda/snd-intel-dspcfg.ko
/lib/modules/5.8.0-25-generic/kernel/sound/soc/sof/intel/snd-sof-intel-hda.ko
/lib/modules/5.8.0-25-generic/kernel/sound/soc/sof/intel/snd-sof-intel-hda-common.ko
/lib/modules/5.8.0-25-generic/kernel/sound/soc/intel/boards/snd-soc-skl_hda_dsp.ko
/lib/modules/5.8.0-25-generic/kernel/sound/pci/hda/snd-hda-intel.ko
/lib/modules/5.8.0-25-generic/kernel/sound/hda/snd-intel-dspcfg.ko
Here is what I tried:
1. pulseaudio -k && sudo alsa force-reload
If I issue this command often enough (roughly around 3-7 times), then eventually my speakers appear as an output device and sound works. However, after rebooting, this does not work again.
How can I make this consistent?
Typical output of this command looks like
Unloading ALSA sound driver modules: snd-soc-dmic snd-acp3x-rn snd-acp3x-pdm-dma snd-soc-core snd-compress snd-hda-codec-hdmi snd-pcm-dmaengine snd-hda-codec-realtek snd-hda-codec-generic snd-hda-intel snd-seq-midi snd-seq-midi-event snd-intel-dspcfg snd-hda-codec snd-rawmidi snd-hda-core snd-seq snd-hwdep snd-pcm snd-seq-device snd-rn-pci-acp3x snd-pci-acp3x snd-timer (failed: modules still loaded: snd-soc-dmic snd-soc-core snd-compress snd-pcm-dmaengine snd-hda-codec-realtek snd-hda-codec-generic snd-hda-codec snd-hda-core snd-hwdep snd-pcm snd-timer).
Loading ALSA sound driver modules: snd-soc-dmic snd-acp3x-rn snd-acp3x-pdm-dma snd-soc-core snd-compress snd-hda-codec-hdmi snd-pcm-dmaengine snd-hda-codec-realtek snd-hda-codec-generic snd-hda-intel snd-seq-midi snd-seq-midi-event snd-intel-dspcfg snd-hda-codec snd-rawmidi snd-hda-core snd-seq snd-hwdep snd-pcm snd-seq-device snd-rn-pci-acp3x snd-pci-acp3x snd-timer.
Sometimes, the failed: modules still loaded part does not appear. But I did not recognize any different outcome.
This slightly changes aplay -l to
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 1/1
Subdevices: 0/1
so for card 1 it now is Subdevices: 0/1 instead of Subdevices: 1/1.
2. adding lines to /etc/modprobe.d/alsa-base
According to the solution in this question I added the line
options snd-hda-intel model=generic
to /etc/modprobe.d/alsa-base. This actually replaces the Dummy output by HD-Audio Generic Digital Stereo (HDMI). I guess this enables the HDMI audio output? I can't test this, but the speaker does not work.
This changed the output of aplay -l
card 0: Generic [HD-Audio Generic], device 3: Generic Digital [Generic Digital]
Subdevices: 1/1
Subdevices: 1/1
The other two proposed lines
options snd-hda-intel dmic_detect=0
blacklist snd_soc_skl
don't have any effect that I recognized.
3. Timidity
Some people had problems with the program timidity, but it's not installed on my system.
I'm pretty clueless, what to do now. Any help would be appreciated :)
