13
My Kubuntu updated from kernel 5.4.0-42 to kernel 5.4.0-47 and my laptop's keyboard stops working (except brightness keys). Booting back to 5.4.0-42 solved the problem.
Keyboard also works perfectly on Windows 10 (I have dual boot).
Keyboard also works in GRUB (2.04). But it does not in kernels 5.4.0-47 and above.
Updating to Kubuntu 20.10 (beta) does not help either (kernel 5.8.0-20 same problem).
My problem is similar to this one: Keyboard on HP notebook stops working under kernel 5.4.0-45-generic
And yes, I've seen this on launchpad: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1894017
So what's the problem and why is it not fixed in whole range of kernels 5.4.0-47 - 5.8.0-20?
Zanna
  • 72,312
The solution was found here: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1894017
I just blacklisted intel_vbtn kernel module in /etc/modprobe.d/blacklist.conf and rebooted. Author mentioned that somehow intel_vbtn thinks my laptop is in tablet mode (WHAT?!) and disabled keyboard/touchpad.
How to blacklist
To implement this, you can either create a new file in /etc/modprobe.d with the suffix .conf or use the main blacklist.conf file. The former may be preferable, since you can then just delete the file when it is no longer required (i.e. when the bug is fixed):
sudoedit /etc/modprobe.d/blacklist-intel_vbtn.conf
Add a line to the file, optionally with a comment explaining why you are doing this
# bug in module breaks keyboard, so don't load it
blacklist intel_vbtn
Save the file, exit and reboot.
P.S. After mailing with Mr. Hans de Goede from RedHat I got following answer:
This should be fixed by this upstream commit, which landed in Linus' tree a couple of hours ago: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit/drivers/platform/x86?id=8169bd3e6e193497cab781acddcff8fde5d0c416
Igor, if you do:
cat /sys/class/dmi/id/chassis_type
On your laptop, and the output is NOT "31" or "32" then this fix should work for you.
If the output actually is "31" or "32 (which I do not expect), then please let me know, because then we need a different fix.
P.P.S. On my system (Intel Celeron N2940) chassis_type returns 10
Zanna
  • 72,312
This seems to be libinput that receives a SW_TABLET_MODE event from one of the laptops input devices. I don't know why they disable the keyboard and touchpad when receiving that event, but I would guess it was to avoid button presses on laptops you can flip the screen all the way around so the keyboard/touchpad is underneath the touch screen.
However, some laptop models emit this event even when the keyboard is not flipped around. Dell Precision 5760 has an "Intel HID switches" input device which triggers this event when the laptop is moved. So every time I triggered the accelerometer the internal keyboard and touchpad stopped working for some time. Before it went back to laptop mode. This bug seems to have been [fixed a few weeks ago][1], so hopefully it gets rolled out in a stable release soon.
Others have suggested blacklisting intel_vbtn, but that didn't work for me. Probably because of a different driver in use. But I found a different workaround, which is a solution in libinput for this exact problem; register a quirk for the input device triggering tablet mode: ModelTabletModeSwitchUnreliable.
First you need to figure out which input device is triggering the SW_TABLET_MODE event. Install libinput-tools to help you debug the problem:
$ sudo apt install libinput-tools
Now record all input events with sudo libinput debug-events. Start it, and try to trigger the SW_TABLET_MODE event. It should look something like this:
-event27  SW_TABLET_MODE  .....
That means it is /dev/input/event27 which is triggering the tablet mode. It is probably a different number for others. Let's list the input devices to find out it's name:
$ sudo libinput list-devices
Look for the event number you got earlier and note down the device name:
Device:           Intel HID switches
Kernel:           /dev/input/event27
Now we need some identifiers for your computers modalias:
$ cat /sys/class/dmi/id/modalias
dmi:bvnDellInc.:bvr1.4.1:bd09/08/2021:br1.4:svnDellInc.:pnPrecision5760:pvr:sku0A5E:rvnDellInc.:rn0FW9DW:rvrA00:cvnDellInc.:ct10:cvr:
It doesn't really matter what part of it you pick, but I chose svnDellInc.:pnPrecision5760: since it includes the manufacturer and model of my computer.
As root, create a file /etc/libinput/local-overrides.quirks
[QUIRKS DESCRIPTION]
MatchName=*DEVICE NAME*
MatchDMIModalias=dmi:*PART OF MODALIAS*
ModelTabletModeSwitchUnreliable=1
For my Dell Precision 5760 it looks like this:
[Precision 5760 Disable Tablet Mode]
MatchName=*Intel HID switches*
MatchDMIModalias=dmi:*svnDellInc.:pnPrecision5760:*
Save the file. To verify the quirk matches the device, try:
$ libinput quirks list /dev/input/event27
It should output the ModelTabletModeSwitchUnreliable quirk.
Reboot your computer, and the SW_TABLET_MODE events should be ignored.
gregers
  • 201
