I recently installed Ubuntu (20.04 LTS) on my laptop (Asus ZenBook 13 OLED UX325). It works for the most part but I realized that whenever I use the power off option, the keyboard will not work upon restart. Basically, I need to (from another question)
sudo apt-get install xserver-xorg-input-all
or
sudo apt-get --purge autoremove xserver-xorg-input-all
after using the Screen Keyboard to log in. I also have to be careful to push Restart instead of Power Off after written the commands in the terminal.
Needless to say, I wish to not have to do this tedious (and temporary) routine every time I Power Off my computer. Surely there must be a permanent solution?
Edit 1: It also appears to work if I log in using the Screen Keyboard after Power Off and then just Restart again. No real need for the commands above. Power Off is the prime suspect.
Edit 2: I do not really have to log in. After Power Off, I can just Restart before logging in, and then the keyboard works afterward. Power Off must be the perpetrator, no?
I had the same issue with my ASUS Zenbook 13 UM325S. (Kubuntu 20.04.3) I tried to follow the same steps as you but had no success.
I found that there is some issue with the latest kernel version. I just reinstall Kubuntu 18.04.5 and the issue is solve.
It's not a 100% solution but I do not want to restart every time.
I hope this will help you also.
Thanks
Nirav
  • 116
Finally, this solution works for me.
I am using ASUS Zenbook 13 OLED UM325S with Kubuntu 20.04
Edit file: /etc/default/grub
Replace bellow line
GRUB_CMDLINE_LINUX=""
WITH
GRUB_CMDLINE_LINUX="i8042.reset i8042.nomux i8042.nopnp i8042.noloop"
Update bootloader
sudo update-grub
Nirav
  • 116
