[edit: Wasn't able to solve this, using a different distro now. Don't bother commenting on the question. Thank you guys for all your help.]
I have installed Ubuntu 18.04 on an HP Chromebook 15. (Not through Crouton or anything, really installed Ubuntu.) No audio is output through my internal speakers, nor external, nor headphones. The only output device in my list is 'dummy Output'. Any help would be much appreciated. Please tell me if you need any hardware info, I'd be happy to provide it. While I am aware that this question has been asked before, none of the answers I found helped.
Here are a couple links to solutions I've already tried:
Fix no sound dummy output issue
Sound card shown as dummy output in ubuntu 18 04
Ubuntu 18.04 dummy output and sound disappeared
Persistent dummy output
Dummy output instead of audio device on debian 9
Restarting ALSA didn't help, and attached is a picture of what happens when I run 'alsamixer' in the terminal. Image
The output of pacmd list-cards is as follows:
    index: 0
    driver: <module-alsa-card.c>
    owner module: 7
    properties:
        alsa.card = "0"
        alsa.card_name = "HDA Intel PCH"
        alsa.long_card_name = "HDA Intel PCH at 0xd112c000 irq 126"
        alsa.driver_name = "snd_hda_intel"
        device.bus_path = "pci-0000:00:1f.3"
        sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
        device.bus = "pci"
        device.vendor.id = "8086"
        device.vendor.name = "Intel Corporation"
        device.product.id = "9d71"
        device.product.name = "Sunrise Point-LP HD Audio"
        device.form_factor = "internal"
        device.string = "0"
        device.description = "Built-in Audio"
        module-udev-detect.discovered = "1"
        device.icon_name = "audio-card-pci"
    profiles:
        output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5400, available: no)
        output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 300, available: no)
        output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 300, available: no)
        output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5200, available: no)
        output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 100, available: no)
        output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 100, available: no)
        output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5200, available: no)
        output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 100, available: no)
        output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 100, available: no)
        output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5200, available: no)
        output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 100, available: no)
        output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 100, available: no)
        output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5200, available: no)
        output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 100, available: no)
        output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 100, available: no)
        off: Off (priority 0, available: unknown)
    active profile: <off>
    ports:
        hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
            properties:
                device.icon_name = "video-display"
        hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
            properties:
        hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
            properties:
        hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
            properties:
        hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
            properties:
Is this a lost cause? Should I just reinstall ChromeOS?
Try running modprobe --show-depends snd_hda_intel, if it says
modprobe: FATAL: Module snd_hda_intel not found in directory /lib/modules...
then you're missing the linux-modules-extra package containing these. I think it was introduced somewhere between kernel 4 and 5. If so, then this might help
sudo apt install linux-modules-extra-$(uname -r)
