Question
I am using Ubuntu 18.04.4. There is no sound.
As suggested here, audio device information obtained using sudo lspci -v is as follows:
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
Subsystem: Dell Sunrise Point-LP HD Audio
Flags: bus master, fast devsel, latency 32, IRQ 146
Memory at d1228000 (64-bit, non-prefetchable) [size=16K]
Memory at d1200000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [50] Power Management version 3
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl
Tested methods
Following are the questions that I have looked into.
Q1 Following is the output of systemctl command
$ systemctl --user status pulseaudio.socket
pulseaudio.socket - Sound
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.socket; enabled; vendor preset: enabled)
Active: inactive (dead)
Listen: /run/user/1000/pulse/native (Stream)
After this, as suggested I used the command systemctl --user enable pulseaudio.
Q2 As suggested here, I checked pactl list short sinks. Following is the outcome. It shows the device is suspended.
0 alsa_output.pci-0000_00_1f.3.analog-stereo module-alsa-card.c s16le 2ch 48000Hz SUSPENDED
Then, I used pactl set-default-sink alsa_output.pci-0000_00_1f.3.analog-stereo. The suspended status did not change. Hence, I searched for another solution.
Q3 As suggested here, I reinstalled pulseaudio and alsa-base. Following is output:
sudo apt-get remove --purge alsa-base pulseaudio
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
libwebrtc-audio-processing1
Use 'sudo apt autoremove' to remove it.
The following packages will be REMOVED:
alsa-base* pulseaudio*
0 to upgrade, 0 to newly install, 2 to remove and 0 not to upgrade.
After this operation, 4,588 kB disk space will be freed.
Do you want to continue? [Y/n]
(Reading database ... 426510 files and directories currently installed.)
Removing alsa-base (1.0.25+dfsg-0ubuntu5) ...
Removing pulseaudio (1:11.1-1ubuntu7.7) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
(Reading database ... 426290 files and directories currently installed.)
Purging configuration files for pulseaudio (1:11.1-1ubuntu7.7) ...
Purging configuration files for alsa-base (1.0.25+dfsg-0ubuntu5) ...
Processing triggers for dbus (1.12.2-1ubuntu1.1) ...
(base) neeraj@neeraj-personal:~$ sudo apt-get remove --purge alsa-base pulseaudio
Package 'alsa-base' is not installed, so not removed
Package 'pulseaudio' is not installed, so not removed
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
(base) neeraj@neeraj-personal:~$ sudo apt autoremove
0 to upgrade, 0 to newly install, 1 to remove and 0 not to upgrade.
After this operation, 691 kB disk space will be freed.
(Reading database ... 426279 files and directories currently installed.)
Removing libwebrtc-audio-processing1:amd64 (0.3-1) ...
Processing triggers for libc-bin (2.27-3ubuntu1) ...
(base) neeraj@neeraj-personal:~$ sudo apt-get install alsa-base pulseaudio
The following additional packages will be installed:
Suggested packages:
apmd alsa-oss oss-compat pavumeter paman paprefs
The following NEW packages will be installed:
alsa-base libwebrtc-audio-processing1 pulseaudio
0 to upgrade, 3 to newly install, 0 to remove and 0 not to upgrade.
Need to get 1,193 kB of archives.
After this operation, 5,279 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu bionic/main amd64 alsa-base all 1.0.25+dfsg-0ubuntu5 [145 kB]
Get:2 http://archive.ubuntu.com/ubuntu bionic/main amd64 libwebrtc-audio-processing1 amd64 0.3-1 [260 kB]
Get:3 http://archive.ubuntu.com/ubuntu bionic-updates/main amd64 pulseaudio amd64 1:11.1-1ubuntu7.7 [788 kB]
Fetched 1,193 kB in 4s (307 kB/s)
Selecting previously unselected package alsa-base.
(Reading database ... 426276 files and directories currently installed.)
Preparing to unpack .../alsa-base_1.0.25+dfsg-0ubuntu5_all.deb ...
Unpacking alsa-base (1.0.25+dfsg-0ubuntu5) ...
Selecting previously unselected package libwebrtc-audio-processing1:amd64.
Preparing to unpack .../libwebrtc-audio-processing1_0.3-1_amd64.deb ...
Unpacking libwebrtc-audio-processing1:amd64 (0.3-1) ...
Selecting previously unselected package pulseaudio.
Preparing to unpack .../pulseaudio_1%3a11.1-1ubuntu7.7_amd64.deb ...
Unpacking pulseaudio (1:11.1-1ubuntu7.7) ...
Setting up alsa-base (1.0.25+dfsg-0ubuntu5) ...
Setting up libwebrtc-audio-processing1:amd64 (0.3-1) ...
Setting up pulseaudio (1:11.1-1ubuntu7.7) ...
Adding user pulse to group audio
(base) neeraj@neeraj-personal:~$ sudo apt-get -f install && sudo apt-get -y autoremove && sudo apt-get autoclean && sudo apt-get clean && sudo sync && echo 3 | sudo tee /proc/sys/vm/drop_caches
After takin these steps following is the outcome of the pactl:
(base) neeraj@neeraj-personal:~$ pactl list short sinks
1 alsa_output.pci-0000_00_1f.3.analog-stereo module-alsa-card.c s16le 2ch 48000Hz IDLE
Checked for additional drivers as suggested in an answer. Following is the screenshot.
No drivers are listed there.
Attempted to connect using a Bluetooth headset. Headset paired with the laptop but did not connect and hence did not show up in the device list.
Now, after restarting the laptop, following is the situation. But there is no sound.
1 alsa_output.pci-0000_00_1f.3.analog-stereo module-alsa-card.c s16le 2ch 48000Hz RUNNING
Another restart and it shows suspended again
1 alsa_output.pci-0000_00_1f.3.analog-stereo module-alsa-card.c s16le 2ch 48000Hz SUSPENDED
How to proceed to start the sound?
I updated the system from 18.04 to 19.04 and the sound issue resolved. I don't know how.
