Possible Duplicate:
How do I set Windows to boot as the default in the boot loader?
I just installed Ubuntu 11. on my computer but the default is Ubuntu. How do I change it so that Windows 7 is the default?
Adapted from: How do I set Windows to boot as the default in the boot loader?
For Ubuntu 11.x (or higher), with Grub2
Find out what you boot options are called:
sudo update-grub
One of the entries should be 'Windows 7'.
Edit /etc/default/grub to set this as boot default:
sudo gedit /etc/default/grub
change:
    GRUB_DEFAULT=0
to: (for example)
    GRUB_DEFAULT="Windows 7 (loader) (on /dev/sda2)"
Save file, then (again) run:
sudo update-grub
david6
  • 14,528
  • 38
  • 46
Run this in your terminal to open the GRUB configuration file in Gedit Text Edior:
gksudo gedit /boot/grub/grub.cfg
In that file, on line 13, you'll find this:
set default="0"
The number represents the default boot-item in the boot-menu, where the first item is 0. If Windows 7 is number 5 on your boot menu, change "0" to "5". Remember to save the file before you close it.
Apply the changes by running this in the terminal:
sudo update-grub
To always have an easy way to change the default boot-item, change the default in the field to
set default=saved
Update grub using the command above (sudo grub-update), and then you can easily change the default boot item at any time by using the command
sudo grub-set-default
followed by the number of the menu-item you want to set as default.
Esso
  • 1,045
You can also download StartUp-Manager at Ubuntu Software Center, it comes with a GUI and it's simple to use! = )
