I've been deploying Ubuntu (since 12.04) along with other Linux with pxelinux many years. With the Debian-installer, it works just fine. These days I've been trying to deploy 20.04, which also works basically. Only one question, the "user-data" file never been picked up. No matter what I do, I always get all the questions asked from the installer. Here is my environment:
  1. I created a user-data file under /var/www/html/ubuntu/cloud-init of the file server, and its content is as this:
## cloud-config
autoinstall: version: 1 apt: preserve_sources_list: false primary: - arches: [default] uri: [...]/images/ubuntu
identity: {realname: wrsadmin, username: wrsadmin} keyboard: {layout: us, toggle: null, variant: ''} locale: en_US network: ethernets: enp0s3: critical: true dhcp-identifier: mac dhcp4: true nameservers: addresses: [128.224.160.11, 128.224.160.12] search: [wrs.com., corp.ad.wrs.com.] version: 2 ssh: allow-pw: true authorized-keys: [] install-server: true
late-commands: - rm -f /target/etc/resolv.conf - wget -O /target/etc/resolv.conf [...]/ubuntu/resolv.conf - chattr +i /target/etc/resolv.conf
  1. "default" file of pxelinux. As you can see below, when I use the Debian-Installer netboot files, PXE works, and preseed works too. When I use cloud-init format netboot files, PXE works too, the 900MB server live image is loaded successfully. But, the "autoinstall ds=nocloud-net;s=[...]/ubuntu/cloud-init/" is like it doesn't exist.
Debian-installer + preseed:
LABEL Ubuntu 20.04 x64 legacy
  MENU LABEL Ubuntu 20.04 x64 legacy
  TEXT HELP
  ENDTEXT
  KERNEL Linux/Ubuntu2004/linux
  APPEND vga=normal initrd=Linux/Ubuntu2004/initrd.gz locale=en_US.UTF-8 keyboard-configuration/layoutcode=us ipv6.disable=1 url=[...]/ubuntu/preseed/preseed2004.cfg
Cloud-init + user-data
  TEXT HELP
  Ubuntu 20.04 x64
  ENDTEXT
  KERNEL Linux/Ubuntu2004/vmlinuz
  APPEND initrd=Linux/Ubuntu2004/initrd ip=dhcp url=[...]/images/ubuntuExtra/ubuntu2004/ubuntu-20.04-live-server-amd64.iso autoinstall ds=nocloud-net;s=[...]/ubuntu/cloud-init/
Would you please help to diagnose which part I did wrong?
Marco Ceppi
  • 48,827
Wei Du
  • 71
I was able to use these steps to do an autoinstall on a BIOS based VM. They are slightly modified from my UEFI steps. Hopefully they will provide an example to help you figure out your problem. You can tailor them to your environment
Build a tftp server
All the following steps are run as root. These were tested on an Ubuntu 18.04 server.
Install the tftp server, web server, and syslinux files
apt-get -y install tftpd-hpa apache2 pxelinux
Configure apache to serve files from the tftp directory
cat > /etc/apache2/conf-available/tftp.conf <<EOF
<Directory /var/lib/tftpboot>
        Options +FollowSymLinks +Indexes
        Require all granted
</Directory>
Alias /tftp /var/lib/tftpboot
EOF
a2enconf tftp
systemctl restart apache2
Copy the syslinux files to the tftp directory
cp /usr/lib/PXELINUX/gpxelinux.0 /var/lib/tftpboot/pxelinux.0.bios
cp /usr/lib/syslinux/modules/bios/*.c32 /var/lib/tftpboot
Download the live server iso
wget http://old-releases.ubuntu.com/releases/20.04/ubuntu-20.04-live-server-amd64.iso -O /var/lib/tftpboot/ubuntu-20.04-live-server-amd64.iso
Extract the kernel and initramfs from the live server iso
mount /var/lib/tftpboot/ubuntu-20.04-live-server-amd64.iso /mnt/
cp /mnt/casper/vmlinuz /var/lib/tftpboot/
cp /mnt/casper/initrd /var/lib/tftpboot/
umount  /mnt
Configure syslinux
MYIP=$(hostname --ip-address)
mkdir -p /var/lib/tftpboot/pxelinux.cfg
cat > /var/lib/tftpboot/pxelinux.cfg/default <<EOF
DEFAULT vesamenu.c32
TIMEOUT 600
ONTIMEOUT focal-live-install-autoinstall
PROMPT 0
NOESCAPE 1
LABEL focal-live-install MENU DEFAULT MENU label Install focal KERNEL vmlinuz INITRD initrd APPEND root=/dev/ram0 ramdisk_size=1500000 ip=dhcp url=http://${MYIP}/tftp/ubuntu-20.04-live-server-amd64.iso
LABEL focal-live-install-autoinstall MENU DEFAULT MENU label Install focal - autoinstall KERNEL vmlinuz INITRD initrd APPEND root=/dev/ram0 ramdisk_size=1500000 ip=dhcp url=http://${MYIP}/tftp/ubuntu-20.04-live-server-amd64.iso autoinstall ds=nocloud-net;s=http://${MYIP}/tftp/cloud-init-bios/ cloud-config-url=/dev/null
EOF
Configure cloud-init with the autoinstall configuration. I first ran the install manually to get the generated /var/log/installer/autoinstall-user-data file to use as the basis. I then made modifications based on my needs and errors encountered.
mkdir -p /var/lib/tftpboot/cloud-init-bios/
cat > /var/lib/tftpboot/cloud-init-bios/meta-data <<EOF
instance-id: focal-autoinstall
EOF
cat > /var/lib/tftpboot/cloud-init-bios/user-data <<'EOF'
#cloud-config
autoinstall:
  version: 1
  # use interactive-sections to avoid an automatic reboot
  #interactive-sections:
  #  - locale
  apt:
    # even set to no/false, geoip lookup still happens
    #geoip: no
    primary:
    - arches: [amd64, i386]
      uri: http://us.archive.ubuntu.com/ubuntu
    - arches: [default]
      uri: http://ports.ubuntu.com/ubuntu-ports
  # r00tme
  identity: {hostname: focal-autoinstall, password: $6$.c38i4RIqZeF4RtR$hRu2RFep/.6DziHLnRqGOEImb15JT2i.K/F9ojBkK/79zqY30Ll2/xx6QClQfdelLe.ZjpeVYfE8xBBcyLspa/,
    username: ubuntu}
  keyboard: {layout: us, variant: ''}
  locale: en_US.UTF-8
  # interface name will probably be different
  network:
    network:
      version: 2
      ethernets:
        ens192:
          critical: true
          dhcp4: true
  ssh:
    allow-pw: true
    authorized-keys: []
  # this creates an bios_grub partition, /boot partition, and root(/) lvm volume
  storage:
    config:
    - {ptable: gpt, path: /dev/sda, wipe: superblock, preserve: false, name: '', grub_device: true,
      type: disk, id: disk-sda}
    - {device: disk-sda, size: 1048576, flag: bios_grub, number: 1, preserve: false,
      type: partition, id: partition-0}
    - {device: disk-sda, size: 1073741824, wipe: superblock, flag: '', number: 2,
      preserve: false, type: partition, id: partition-1}
    - {fstype: ext4, volume: partition-1, preserve: false, type: format, id: format-0}
    - {device: disk-sda, size: -1, wipe: superblock, flag: '', number: 3,
      preserve: false, type: partition, id: partition-2}
    - name: ubuntu-vg
      devices: [partition-2]
      preserve: false
      type: lvm_volgroup
    - {name: ubuntu-lv, volgroup: lvm_volgroup-0, size: 100%, preserve: false,
      type: lvm_partition, id: lvm_partition-0}
    - {fstype: ext4, volume: lvm_partition-0, preserve: false, type: format, id: format-1}
    - {device: format-1, path: /, type: mount, id: mount-1}
    - {device: format-0, path: /boot, type: mount, id: mount-0}
write_files:
  # override the kernel package
  - path: /run/kernel-meta-package
    content: |
      linux-virtual
    owner: root:root
    permissions: "0644"
  # attempt to also use an answers file by providing a file at the default path.  It did not seem to have any effect
  #- path: /subiquity_config/answers.yaml
  #  content: |
  #    InstallProgress:
  #      reboot: no
  #  owner: root:root
  #  permissions: "0644"
EOF
Configure DHCP
Set the DHCP Options 66,67 according to the documentation for your DHCP server.
Boot your server
At this point, you should be able to boot your UEFI based server and perform a completely automatic install.
When I did this with a UEFI based server (which uses grub instead of syslinux) I had to escape the semicolon in the command line.
Try changing
ds=nocloud-net;s=http://blah/ubuntu/cloud-init/
to
ds=nocloud-net\;s=http://blah/ubuntu/cloud-init/
I found the easiest way to check in the installer environment is to use alt-f2 to get a console and use the command
dmesg | grep 'Command line'
That will show if the full ds argument is being passed or if it only passes up to the ;
There are only three entries generated in /var/log/httpd/access_log (and there is no new entries in /var/log/httpd/error_log):
128.224.180.84 - - [14/May/2020:09:48:45 +0800] "GET /images/ubuntuExtra/ubuntu2004/ubuntu-20.04-live-server-amd64.iso HTTP/1.1" 200 952107008 "-" "Wget"
128.224.180.84 - - [14/May/2020:09:49:35 +0800] "GET /images/ubuntuExtra/ubuntu2004/ubuntu-20.04-live-server-amd64.iso HTTP/1.1" 200 952107008 "-" "Cloud-Init/20.1-10-g71af48df-0ubuntu5"
128.224.180.84 - - [14/May/2020:09:50:06 +0800] "GET /images/ubuntuExtra/ubuntu2004/ubuntu-20.04-live-server-amd64.iso HTTP/1.1" 200 952107008 "-" "Cloud-Init/20.1-10-g71af48df-0ubuntu5"
The first entry shows the installer is loading the live image, which I can understand.
But I don't understand the following two entries. And there is certainly no entry for loading the autoinstall file, which I have no idea why.
Wei Du
  • 71
