I try to install 20.04 server with preseeding on BIOS based device via PXE. I created pxelinux.cfg/default:
DEFAULT menu.c32
PROMPT 5
TIMEOUT 5
ONTIMEOUT ubuntu20
LABEL ubuntu20
  MENU LABEL Ubuntu 20.04
  KERNEL ubuntu20/vmlinuz acpi=off vga=normal nomodeset quiet ---
  INITRD ubuntu20/initrd
  APPEND root=/dev/ram0 ramdisk_size=3000 ip=dhcp url=http://192.168.1.10/ubuntu20/server.iso auto-install/enable=true debconf/priority=critical
preseed/url=http://192.168.1.10/ubuntu20/preseed.cfg --
ISO is downloaded, but installer fails to download preseed file. Casper.log:
server.iso           100% |********************************|  915M  0:00:00 ETA
--2020-07-03 14:06:04--  http://preseed/url=http://192.168.1.10/ubuntu20/preseed.cfg
Resolving preseed (preseed)... failed: Temporary failure in name resolution.
wget: unable to resolve host address 'preseed'
grep: /root/tmp/preseed.cfg: No such file or directory
How to include preseed file properly?
I think you are mixing up the steps from the (now named) legacy installer and the live installer. Both installers use the url argument. The legacy installer url argument is for the preseed file. The live installer url argument is for the iso location
I created example steps of using the pxe booting the live installer at Automated 20.04 Server Installation using PXE and live server image
This is an example pxelinux.cfg/default config for the legacy installer I used for 18.04. The kernel and initrd files come from the netboot archive in http://archive.ubuntu.com/ubuntu/dists/bionic-updates/main/installer-amd64/current/images/netboot/
DEFAULT vesamenu.c32
TIMEOUT 600
ONTIMEOUT bionic-install
PROMPT 0
NOESCAPE 1
MENU TITLE PXE Menu
LABEL bionic-install MENU DEFAULT MENU label Install Bionic KERNEL ubuntu/bionic/amd64/ubuntu-installer/amd64/linux APPEND vga=788 initrd=ubuntu/bionic/amd64/ubuntu-installer/amd64/initrd.gz auto=true priority=critical url=tftp://192.168.1.10/preseed_bionic.cfg netcfg/choose_interface=auto DEBCONF_DEBUG=5 --
This is an example pxelinux.cfg/default config for the live installer I used for 20.04 . This does not use a preseed file, but a new yaml file. The kernel and initrd files come from the live iso image
TIMEOUT 600
ONTIMEOUT focal-live-install-autoinstall
PROMPT 0
NOESCAPE 1
MENU TITLE PXE Menu
LABEL focal-live-install-autoinstall MENU DEFAULT MENU label Install focal - autoinstall KERNEL ubuntu/focal/live/vmlinuz INITRD ubuntu/focal/live/initrd APPEND root=/dev/ram0 ramdisk_size=1500000 ip=dhcp url=http://192.168.1.10/tftp/iso/ubuntu-20.04-live-server-amd64.iso autoinstall ds=nocloud-net;s=http://192.168.1.10/tftp/autoinstall/focal_bios/
