I used a PXE install on a computer with the following relevant parameters in user-data:
  storage:
    layout:
      match:
        ssd: yes
meaning the SSD (machine only contains one) should be formatted and partitioned automatically.
After the installation finishes the partition information is as I expected
sudo partx -s /dev/sda
NR   START       END   SECTORS   SIZE NAME UUID
 1    2048      4095      2048     1M      c22ce821-a730-4ba4-9992-3014acb4c332
 2    4096   2101247   2097152     1G      24379366-30d3-4967-b9d7-31a42ea2043d
 3 2101248 250066943 247965696 118.2G      d15a6cd2-b73e-427b-b7ea-0d99f6c6fce5
Yet free space is only about half what it should be. Also their are weird extra mounts
 sudo lsblk
NAME                      MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
loop0                       7:0    0  29.9M  1 loop /snap/snapd/8790
loop1                       7:1    0  55.3M  1 loop /snap/core18/1885
loop2                       7:2    0  71.5M  1 loop /snap/lxd/16740
sda                         8:0    0 119.2G  0 disk
├─sda1                      8:1    0     1M  0 part
├─sda2                      8:2    0     1G  0 part /boot
└─sda3                      8:3    0 118.2G  0 part
  └─ubuntu--vg-ubuntu--lv 253:0    0  59.1G  0 lvm  /
How can I set the auto installer parameters that I have the whole 118.2G available?
Thanks in advance.
[Workaround]
If you replace name: lvmwith name: directI get the full capacity but then obviousl LVM is not working. The Machine also then does not seem to have a separate boot partition:
sudo lsblk
└─sda2   8:2    0 119.2G  0 part /
I would prefer to have the full capacity available with LVM.
[/Workaround]
[Config with LVM]
pxelinux.cfg:
DEFAULT install
LABEL install
  KERNEL vmlinuz
  INITRD initrd
  APPEND root=/dev/ram0 ramdisk_size=1500000 ip=dhcp url=http://10.2.1.20/efi_focal/ubuntu-20.04.1-live-server-amd64.iso autoinstall net.ifnames=0 biosdevname=0 ip=dhcp ipv6.disa>
user-data:
#cloud-config
autoinstall:
  version: 1
  early-commands:
    - systemctl stop ssh # otherwise packer tries to connect and exceed max attempts
  network:
    network:
      version: 2
      ethernets:
        eth0:
          dhcp4: yes
          dhcp-identifier: mac
          optional: true
        eth1:
          dhcp4: yes
          optional: true
        eth2:
          dhcp4: yes
          optional: true
        eth3:
          dhcp4: yes
          optional: true
        eth4:
          dhcp4: yes
          optional: true
        eth5:
          dhcp4: yes
          optional: true
  locale: en_US
  keyboard:
    layout: de
  apt:
    http_proxy: http://10.2.1.1:8080/
    https_proxy: http://10.2.1.1:8080/
    preserve_sources_list: false
    primary:
      - arches: [amd64]
        uri: "http://archive.ubuntu.com/ubuntu/"
  storage:
    layout:
      match:
        ssd: yes
  ssh:
    install-server: yes
    allow-pw: yes
  identity:
    hostname: decosrv02
    password: Hash of the PW
    username: ipc
  packages:
    - net-tools
    - docker
    - docker-compose
  user-data:
    idisable_root: false
  late-commands:
    - echo 'ubuntu ALL=(ALL) NOPASSWD:ALL' > /target/etc/sudoers.d/ubuntu
    - sed -ie 's/GRUB_CMDLINE_LINUX=.*/GRUB_CMDLINE_LINUX="net.ifnames=0 ipv6.disable=1 biosdevname=0"/' /target/etc/default/grub
    - curtin in-target --target /target update-grub2
    - apt-get update && apt-get upgrade -y
[/Config with LVM]
[resize by hand]
ipc@decosrv02:~$ sudo lvextend -l 100%FREE ubuntu--vg-ubuntu--lv
  Please specify a logical volume path.
ipc@decosrv02:~$ sudo lvextend -l 100%FREE /dev/mapper/ubuntu--vg-ubuntu--lv New size given (15134 extents) not larger than existing size (15135 extents)
ipc@decosrv02:~$ sudo resize2fs /dev/mapper/ubuntu--vg-ubuntu--lv resize2fs 1.45.5 (07-Jan-2020) The filesystem is already 15498240 (4k) blocks long. Nothing to do!
[/resize by hand]
Michael
  • 101
This is a storage configuration I've used. It will create a layout of
  • 1MB bios_grub
  • 1GB /boot partition
  • 100% of remaining space is used by LVM for a root logical volume
Based on your output in the original question I believe you are installing on a BIOS based machine. I took this config section from my full BIOS autoinstall example at https://askubuntu.com/a/1240068/376778
I haven't actually tested configuring storage using the match option. The Disk selection extensions section suggests this should work: https://ubuntu.com/server/docs/install/autoinstall-reference
  storage:
    config:
    - {ptable: gpt, match: {ssd: yes}, wipe: superblock, preserve: false, name: '', grub_device: true,
      type: disk, id: disk-sda}
    - {device: disk-sda, size: 1048576, flag: bios_grub, number: 1, preserve: false,
      type: partition, id: partition-0}
    - {device: disk-sda, size: 1073741824, wipe: superblock, flag: '', number: 2,
      preserve: false, type: partition, id: partition-1}
    - {fstype: ext4, volume: partition-1, preserve: false, type: format, id: format-0}
    - {device: disk-sda, size: -1, wipe: superblock, flag: '', number: 3,
      preserve: false, type: partition, id: partition-2}
    - name: ubuntu-vg
      devices: [partition-2]
      preserve: false
      type: lvm_volgroup
    - {name: ubuntu-lv, volgroup: lvm_volgroup-0, size: 100%, preserve: false,
      type: lvm_partition, id: lvm_partition-0}
    - {fstype: ext4, volume: lvm_partition-0, preserve: false, type: format, id: format-1}
    - {device: format-1, path: /, type: mount, id: mount-1}
    - {device: format-0, path: /boot, type: mount, id: mount-0}
