Thank you for your help with my question previously however the solution has not worked for me.
Steps taken based on solution (apologies my pastebin link expired so i do not have the terminal output any longer):
  • Complete reinstallation of Ubuntu Desktop 18.04.4
  • Update and update pciids
  • 14e4:4727 rev 01 Special Case #1: so i installed linux-firmware
  • This did not work so based on the important note I did:
     sudo apt install firmware-b43-installer
  • This did not work so I then did:
     sudo modprobe -r b43
     sudo modprobe b43
     sudo rfkill unblock all
This did not work so I searched again for 4727 rev 01 which led me to this solution.
msk@delete:~$ sudo gedit /etc/default/crda
** (gedit:3055): WARNING **: 21:34:13.448: Set document metadata failed: Setting attribute metadata::gedit-spell-language not supported
** (gedit:3055): WARNING **: 21:34:13.448: Set document metadata failed: Setting attribute metadata::gedit-encoding not supported
** (gedit:3055): WARNING **: 21:34:13.990: Set document metadata failed: Setting attribute metadata::gedit-spell-language not supported
** (gedit:3055): WARNING **: 21:34:13.990: Set document metadata failed: Setting attribute metadata::gedit-encoding not supported
** (gedit:3055): WARNING **: 21:34:14.148: Set document metadata failed: Setting attribute metadata::gedit-spell-language not supported
** (gedit:3055): WARNING **: 21:34:14.149: Set document metadata failed: Setting attribute metadata::gedit-encoding not supported
** (gedit:3055): WARNING **: 21:34:15.650: Set document metadata failed: Setting attribute metadata::gedit-position not supported
This brought up a document which i edited as suggested.
After that didn't work I came to the documentation here. I believe my case would fall under the Known Issues section. Namely:
Known Issues
  • LP#1010931 14e4:4727 [Dell Vostro 3555] Broadcom BCM4313 5GHz doesn't work but 2.4GHz does
    The root cause is the card only transmits/receives on the single-band 2.4GHz only, so it would never broadcast at 5GHz
Am I correct in thinking that this might not be a resolveable issue?
I do not think this is a hardware issue as for about a year prior to me installing linux onto this laptop I could connect to the wifi fine.
Other info:
msk@delete:~$ lspci -nn -d 14e4:
12:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4313 802.11bgn Wireless Network Adapter [14e4:4727] (rev 01)
