I have a Vostro 3300 (tech sheet).
When I first used it I had to install the driver to connect to WiFi.
Having installed Ubuntu Desktop 18.04.4 I believe I no longer have this driver.
I have seen a similar question here about a Vostro 3460 but I couldn't get the solution to work.
If I download the driver from the dell website as before, is there a way for me to install this driver using Ubuntu?
If anyone has further questions I'm happy to answer
Edit:
msk@delete:~$ lspci -nnk | grep 0280 -A3
12:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4313 802.11bgn Wireless Network Adapter [14e4:4727] (rev 01)
Subsystem: Dell Inspiron M5010 / XPS 8300 [1028:0010]
Kernel driver in use: bcma-pci-bridge
Kernel modules: bcma
Also I think the answer may lie here: https://victorpalau.net/2010/09/09/vostro-3300-and-ubuntu-10-4/
However I am having trouble implementing the solution. However when not using a wired connection I too have noticed that my wirless option seems to have disappeared. I think I'm close.
Edit2:
Here is a full list of what I tried.
msk@delete:~$ sudo apt-get install linux-headers$(uname -r | grep -Po "\-[a-z].*") [sudo] password for msk: Reading package lists... Done Building dependency tree Reading state information... Done The following additional packages will be installed: linux-headers-4.15.0-76 linux-headers-4.15.0-76-generic The following NEW packages will be installed linux-headers-4.15.0-76 linux-headers-4.15.0-76-generic linux-headers-generic 0 to upgrade, 3 to newly install, 0 to remove and 0 not to upgrade. Need to get 12.0 MB of archives. After this operation, 89.1 MB of additional disk space will be used. Do you want to continue? [Y/n] y Get:1 http://security.ubuntu.com/ubuntu bionic-security/main amd64 linux-headers-4.15.0-76 all 4.15.0-76.86 [10.9 MB] Get:2 http://security.ubuntu.com/ubuntu bionic-security/main amd64 linux-headers-4.15.0-76-generic amd64 4.15.0-76.86 [1,106 kB] Err:3 http://security.ubuntu.com/ubuntu bionic-security/main amd64 linux-headers-generic amd64 4.15.0.76.78 404 Not Found [IP: 91.189.88.142 80] Fetched 12.0 MB in 7s (1,829 kB/s) E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/l/linux-meta/linux-headers-generic_4.15.0.76.78_amd64.deb 404 Not Found [IP: 91.189.88.142 80] E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing? msk@delete:~$ sudo apt-get install build-essential dkms Reading package lists... Done Building dependency tree Reading state information... Done Package build-essential is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package dkms is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source E: Package 'build-essential' has no installation candidate E: Package 'dkms' has no installation candidate msk@delete:~$ sudo apt-get install linux-headers-generic build-essential dkms Reading package lists... Done Building dependency tree Reading state information... Done Package build-essential is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source Package dkms is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source E: Package 'build-essential' has no installation candidate E: Package 'dkms' has no installation candidate msk@delete:~$ sudo rmmod brcmsmac msk@delete:~$ sudo rmmod bcma rmmod: ERROR: Module bcma is in use by: b43 msk@delete:~$ sudo modprobe wl modprobe: FATAL: Module wl not found in directory /lib/modules/5.3.0-28-generic msk@delete:~$ /etc/modprobe/blacklist-b43.conf add blacklist brcmsmac blacklist brcmfmac blacklist bcma bash: /etc/modprobe/blacklist-b43.conf: No such file or directory msk@delete:~$ sudo rmmod -f Delete rmmod: ERROR: ../libkmod/libkmod-module.c:793 kmod_module_remove_module() could not remove 'Delete': No such file or directory rmmod: ERROR: could not remove module Delete: No such file or directory msk@delete:~$ sudo rmmod -f dell_laptop msk@delete:~$ sudo rmmod -f delete rmmod: ERROR: ../libkmod/libkmod-module.c:793 kmod_module_remove_module() could not remove 'delete': No such file or directory rmmod: ERROR: could not remove module delete: No such file or directory msk@delete:~$ rfkill list msk@delete:~$ rfkill list
