For ScreenLets application I need to install libpng12-0 package on the Ubuntu 19.10 system.
I know that it is available only for Ubuntu 16.04 LTS.
So I have decided to download this package manually and install it by hand.
On previous Ubuntu versions (such as 18.04 LTS) this trick ends with success, but here on 19.10 it fails in very strange way:
wget http://mirrors.kernel.org/ubuntu/pool/main/libp/libpng/libpng12-0_1.2.54-1ubuntu1.1_amd64.deb
sudo apt-get install ./libpng12-0_1.2.54-1ubuntu1.1_amd64.deb
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/116 kB of archives.
After this operation, 285 kB of additional disk space will be used.
Get:1 /home/user/libpng12-0_1.2.54-1ubuntu1.1_amd64.deb libpng12-0 amd64 1.2.54-1ubuntu1.1 [116 kB]
Selecting previously unselected package libpng12-0:amd64.
(Reading database ... 212864 files and directories currently installed.)
Preparing to unpack .../libpng12-0_1.2.54-1ubuntu1.1_amd64.deb ...
Unpacking libpng12-0:amd64 (1.2.54-1ubuntu1.1) ...
dpkg: error processing archive /home/user/libpng12-0_1.2.54-1ubuntu1.1_amd64.deb (--unpack):
unable to install new version of '/lib/x86_64-linux-gnu/libpng12.so.0': No such file or directory
No apport report written because the error message indicates an issue on the local system
What is wrong here? How can I get libpng12-0 installed on Ubuntu 19.10 system?
Note: the same happens on 19.04, but it is near EOL.
