I wanted to compile mosaic on my ubuntu machine, but while compiling, I did not have right libpng version, so the compilation aborted with error:
error: invalid use of incomplete typedef ‘png_struct’ {aka ‘struct png_struct_def’}
179 | *width = (int)png_ptr->width;
So I install the ritgh pnglib version:
$ wget https://downloads.sourceforge.net/project/libpng/libpng16/older-releases/1.2.21/libpng-1.2.21.tar.gz -O libpng.tar.gz
$ tar -xvf libpng.tar.gz
$ cd libpng-1.2.21
$ sudo bash configure --prefix=/usr/local/libpng
$ sudo make install
which contain the definition for struct png_struct. But now the library is in /usr/local/libpng. So the compilation of the mosaic do not see it (and thus do not have the struct definition and aborts).
the library dir is:
$/usr/local/libpng$ tree .
├── bin
│ ├── libpng12-config
│ └── libpng-config -> libpng12-config
├── include
│ ├── libpng12
│ │ ├── pngconf.h
│ │ └── png.h
│ ├── pngconf.h -> libpng12/pngconf.h
│ └── png.h -> libpng12/png.h
├── lib
│ ├── libpng12.a
│ ├── libpng12.la
│ ├── libpng12.so -> libpng12.so.0.59.0
│ ├── libpng12.so.0 -> libpng12.so.0.59.0
│ ├── libpng12.so.0.59.0
│ ├── libpng.a -> libpng12.a
│ ├── libpng.la -> libpng12.la
│ ├── libpng.so -> libpng12.so
│ ├── libpng.so.3 -> libpng.so.3.59.0
│ ├── libpng.so.3.59.0
│ └── pkgconfig
│ ├── libpng12.pc
│ └── libpng.pc -> libpng12.pc
└── share
└── man
├── man3
│ ├── libpng.3
│ └── libpngpf.3
└── man5
└── png.5
9 directories, 21 files
The question is simple, what directory (e.g. include or lib) should I move elsewhere (e.g. /src/include) in order to make to compilation of mosaic successful (by getting the proper definition it needs)?
