I have Ubuntu 20. I installed libqtcore4:i386 to use packet tracer. When I installed a lot of unmet dependencies appear.
You might want to run 'apt --fix-broken install' to correct these.
libqtgui4:i386 : Depends: libpng12-0:i386 (>= 1.2.13-4) but it is not going to be installed
libqtwebkit4:i386 : Depends: libpng12-0:i386 (>= 1.2.13-4) but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
When I run sudo apt --fix-broken install this error appear.
The following additional packages will be installed:
libpng12-0:i386
The following NEW packages will be installed:
libpng12-0:i386
0 upgraded, 1 newly installed, 0 to remove and 16 not upgraded.
66 not fully installed or removed.
Need to get 0 B/118 kB of archives.
After this operation, 315 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 231507 files and directories currently installed.)
Preparing to unpack .../libpng12-0_1.2.50-1ubuntu2_i386.deb ...
Unpacking libpng12-0:i386 (1.2.50-1ubuntu2) ...
dpkg: error processing archive /var/cache/apt/archives/libpng12-0_1.2.50-1ubuntu
2_i386.deb (--unpack):
unable to install new version of '/usr/lib/i386-linux-gnu/libpng12.so.0': No such file or directory
No apport report written because the error message indicates an issue on the local system
/var/cache/apt/archives/libpng12-0_1.2.50-1ubuntu2_i386.deb
