I previously had Ubuntu 18.04 along with Windows 10, after having many problems I decided to install Ubuntu 19.10, but one of the main problems (boot time) was still happening, I have tried almost everything with no solutions. It's really weird since my laptop is new and shouldn't have any troubles.
systemd-analyze time
Startup finished in 3.449s (firmware) + 48.782s (loader) + 5.522s (kernel) + 52.274s (userspace) = 1min 50.028s
graphical.target reached after 52.206s in userspace
systemd-analyze blame 29.319s plymouth-quit-wait.service 8.752s NetworkManager-wait-online.service 8.734s snapd.service 8.325s dev-sda5.device 8.277s systemd-journal-flush.service 6.499s networkd-dispatcher.service 6.000s ModemManager.service 5.693s udisks2.service 4.703s accounts-daemon.service 4.134s NetworkManager.service 3.867s e2scrub_reap.service 3.645s systemd-fsck@dev-disk-by\x2duuid-86D3\x2dF64F.service 3.387s secureboot-db.service 3.344s grub-common.service 3.257s dev-loop2.device ...
EDIT I:
Things I have tried so far: fresh installs many times, edited grub file with "quiet splash noresume", disabled some processes that were taking a long time, and most of the common solutions that somebody could find on internet.
Results of: cat /proc/swaps && free -m
Filename                Type        Size    Used    Priority
/swapfile               file        947128  0       -2
          total        used        free      shared  buff/cache   available
Mem: 10969 1603 8030 124 1336 8958 Swap: 924 0 924
Result of systemd-analyze critical-chain
graphical.target @52.206s
└─multi-user.target @52.206s
  └─kerneloops.service @31.766s +1.015s
    └─network-online.target @31.601s
      └─NetworkManager-wait-online.service @22.848s +8.752s
        └─NetworkManager.service @18.711s +4.134s
          └─dbus.service @18.704s
            └─basic.target @18.474s
              └─sockets.target @18.474s
                └─snapd.socket @18.310s +163ms
                  └─sysinit.target @18.286s
                    └─apparmor.service @15.427s +2.858s
                      └─local-fs.target @15.423s
                        └─boot-efi.mount @14.946s +477ms
                          └─systemd-fsck@dev-disk-by\x2duuid-86D3\x2dF64F.service @10.828s +3.645s
                            └─dev-disk-by\x2duuid-86D3\x2dF64F.device @10.826s
EDIT II:
Outputs after sudo systemctl disable NetworkManager-wait-online.service
Startup finished in 4.261s (firmware) + 12.044s (loader) + 4.338s (kernel) + 40.317s (userspace) = 1min 962ms
graphical.target reached after 40.276s in userspace
systemd-analyze blame 18.691s plymouth-quit-wait.service 10.686s dev-sda5.device 9.799s snapd.service 9.379s configure-printer@usb-001-002.service 6.580s systemd-journal-flush.service 5.879s udisks2.service 5.620s networkd-dispatcher.service 4.928s ModemManager.service 3.954s NetworkManager.service 3.906s accounts-daemon.service 3.855s e2scrub_reap.service 2.898s apport.service ...
I know nothing about Ubuntu but I need it running properly for many courses. I really hope for someone to help me, thanks.
Lorenz Keel
  • 9,511
As described in this answer:
A considerable amount of your boot time can be saved with the command:
I have had trouble with slow boot on 18.04,19.10 and 20.04. I have found a very simple solution.
My desktop PC is connected to my router by an Ethernet cable. I have a Netgear WifFi dongle but this did not work until a recent update to the linux kernel. It now works. If the Netgear card is plugged in and the system boots you have to wait forever for the Grub menu. If the Netgear card is unplugged it boots quickly. This suggests to me that you have to choose either a wired connection or a wifi connection. Having both enabled causes confusion and delay.
-1
systemd-journal-flush.service : Try to clean the journal logs with
sudo journalctl --rotate
sudo journalctl --vacuum-time=1s
more info here Root drive is running out of disk space. How can I free up space?
cmak.fr
  • 8,976
