As per the subject, Kubuntu takes 1:03 minutes to start, but there is an inconsistency with some data:
andrea@Tehesyan:~$ systemd-analyze time
Startup finished in 4.504s (firmware) + 2.140s (loader) + 5.188s (kernel) + 9.054s (userspace) = 20.888s
graphical.target reached after 9.007s in userspace.
As you can see the boot time should be around 30 seconds, what does the system do in the other time?
andrea@Tehesyan:~$ systemd-analyze blame --no-pager
6.289s NetworkManager-wait-online.service
1.541s snapd.service
996ms snapd.apparmor.service
970ms systemd-resolved.service
949ms systemd-binfmt.service
948ms systemd-timesyncd.service
809ms lm-sensors.service
555ms snapd.seeded.service
275ms apport.service
230ms dev-nvme0n1p3.device
153ms udisks2.service
149ms accounts-daemon.service
148ms cups.service
147ms user@1000.service
134ms systemd-journal-flush.service
114ms plymouth-quit.service
97ms ModemManager.service
94ms ua-timer.service
92ms avahi-daemon.service
92ms bluetooth.service
90ms rsyslog.service
86ms dbus.service
79ms polkit.service
78ms power-profiles-daemon.service
73ms systemd-udev-trigger.service
71ms systemd-udevd.service
71ms smartmontools.service
68ms and.service
63ms virtualbox.service
59ms systemd-logind.service
58ms thermald.service
57ms update-notifier-download.service
51ms gpu-manager.service
49ms systemd-tmpfiles-clean.service
49ms grub-common.service
46ms alsa-restore.service
45ms upower.service
45ms home.mount
40ms boot-efi.mount
36ms keyboard-setup.service
36ms apparmor.service
35ms snap-bare-5.mount
33ms NetworkManager.service
33ms snap-core-14946.mount
32ms e2scrub_reap.service
31ms pure-ftpd.service
31ms snap-core18-2751.mount
30ms systemd-fsck@dev-disk-by\x2duuid-4cc61126\x2d9300\x2d4049\x2d8a21\x2d8efb758016f5.service
30ms snap-core18-2785.mount
28ms snap-core20-1891.mount
26ms snap-core22-634.mount
26ms systemd-modules-load.service
26ms grub-initrd-fallback.service
26ms systemd-fsck@dev-disk-by\x2duuid-A544\x2dD3FB.service
25ms systemd-journald.service
25ms snap-core22-750.mount
24ms snap-gnome\x2d3\x2d38\x2d2004-140.mount
23ms snap-gnome\x2d42\x2d2204-105.mount
22ms snap-gnome\x2d42\x2d2204-111.mount
21ms plymouth-start.service
21ms snapd.socket
21ms snap-gtk2\x2dcommon\x2dthemes-13.mount
20ms snap-gtk\x2dcommon\x2dthemes-1535.mount
20ms colord.service
19ms wpa_supplicant.service
19ms proc-sys-fs-binfmt_misc.mount
19ms snap-snapd-19122.mount
18ms systemd-tmpfiles-setup.service
17ms snap-snapd-19361.mount
17ms systemd-tmpfiles-setup-dev.service
15ms snap-winbox-112.mount
14ms kerneloops.service
13ms systemd-sysusers.service
13ms snap-wine\x2dplatform\x2d5\x2dstable-18.mount
12ms dev-hugepages.mount
12ms dev-mqueue.mount
11ms sys-kernel-debug.mount
11ms sys-kernel-tracing.mount
11ms snap-wine\x2dplatform\x2druntime-348.mount
11ms plymouth-read-write.service
11ms systemd-random-seed.service
9ms snap-wine\x2dplatform\x2druntime-349.mount
9ms systemd-sysctl.service
8ms motd-news.service
8ms systemd-backlight@backlight:intel_backlight.service
7ms user-runtime-dir@1000.service
7ms kmod-static-nodes.service
7ms systemd-remount-fs.service
7ms modprobe@configfs.service
7ms dev-disk-by\x2duuid-7cd25b73\x2df94a\x2d4b4a\x2d965c\x2d703a45eb5556.swap
7ms dev-loop14.device
7ms modprobe@drm.service
7ms dev-loop13.device
7ms dev-loop12.device
7ms dev-loop8.device
7ms dev-loop11.device
6ms dev-loop9.device
6ms modprobe@fuse.service
6ms dev-loop16.device
6ms dev-loop15.device
6ms dev-loop10.device
5ms dev-loop17.device
4ms systemd-update-utmp.service
4ms modprobe@efi_pstore.service
4ms systemd-rfkill.service
4ms setvtrgb.service
3ms systemd-user-sessions.service
3ms systemd-update-utmp-runlevel.service
3ms console-setup.service
2ms sddm.service
2ms sys-fs-fuse-connections.mount
2ms rtkit-daemon.service
1ms sys-kernel-config.mount
1ms ufw.service
again
andrea@Tehesyan:~$ systemd-analyze critical-chain --no-pager
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @9.031s
└─multi-user.target @9.031s
└─virtualbox.service @8.967s +63ms
└─network-online.target @8.919s
└─NetworkManager-wait-online.service @2.628s +6.289s
└─NetworkManager.service @2.592s +33ms
└─dbus.service @2.503s +86ms
└─basic.target @2.492s
└─sockets.target @2.492s
└─snapd.socket @2.470s +21ms
└─sysinit.target @2.468s
└─snapd.apparmor.service @1.471s +996ms
└─apparmor.service @1.432s +36ms
└─local-fs.target @1.431s
└─run-user-1000.mount @4.336s
└─swap.target @563ms
└─dev-disk-by\x2duuid-7cd25b73\x2df94a\x2d4b4a\x2d965c\x2d703a45eb5556.swap @554ms +7ms
└─dev-disk-by\x2duuid-7cd25b73\x2df94a\x2d4b4a\x2d965c\x2d703a45eb5556.device @549ms
again
andrea@Tehesyan:~$ journalctl --boot=0 --priority=3 --no-pager
giu 16 16:31:49 Tehesyan kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.I2C0.TPL1._PR0], AE_ALREADY_EXISTS (20221020/dswload2-326)
giu 16 16:31:49 Tehesyan kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20221020/psobject-220)
giu 16 16:31:49 Tehesyan kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.I2C0.TPL1._PR3], AE_ALREADY_EXISTS (20221020/dswload2-326)
giu 16 16:31:49 Tehesyan kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0], AE_NOT_FOUND (20221020/dswload2-162)
giu 16 16:31:49 Tehesyan kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20221020/psobject-220)
giu 16 16:31:49 Tehesyan kernel: tpm tpm0: [Firmware Bug]: TPM interrupt not working, polling instead
giu 16 16:31:49 Tehesyan systemd-udevd[494]: event_source: Failed to get device name: No such file or directory
giu 16 16:31:51 Tehesyan bluetoothd[807]: src/plugin.c:plugin_init() Failed to init vcp plugin
giu 16 16:31:51 Tehesyan bluetoothd[807]: src/plugin.c:plugin_init() Failed to init mcp plugin
giu 16 16:31:51 Tehesyan bluetoothd[807]: src/plugin.c:plugin_init() Failed to init bap plugin
giu 16 16:31:56 Tehesyan kernel: rtw_8822ce 0000:03:00.0: failed to do dpk calibration
giu 16 16:32:00 Tehesyan bluetoothd[807]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 14:79:DB:8A:3E:DF: Host is down (112)
giu 16 16:32:05 Tehesyan bluetoothd[807]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 10:F0:05:CA:70:FA: Host is down (112)
giu 16 16:32:35 Tehesyan systemd[1129]: Failed to start app-baloo_file-ff4b7f2a20f64e4abb162e3d474e7625.scope - Demone dei file Baloo.
giu 16 16:32:36 Tehesyan hp-systray[1949]: hp-systray[1949]: error: option -s not recognized
giu 16 16:32:40 Tehesyan systemd[1129]: Failed to start app-script\x2dremapping\x2dmouse\x2dkeys-b3f82c270c8046e0b4bd32758d6d46b5.scope - script-remapping-mouse-keys.
giu 16 16:32:40 Tehesyan systemd[1129]: Failed to start app-snap\x2duserd\x2dautostart-5b2d61154fee442aad23110308d429fa.scope - Snap user application autostart helper.
giu 16 16:32:40 Tehesyan systemd[1129]: Failed to start app-spice\x2dvdagent-8817624255bb4aabaffb22400d7d5f9c.scope - Spice vdagent.
giu 16 16:32:40 Tehesyan systemd[1129]: Failed to start app-xbindkeys-6a68845bad8a4b63abd513ce3f205f2d.scope - xbindkeys.
giu 16 16:52:56 Tehesyan kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe B (start=94294 end=94295) time 257 us, min 1071, max 1079, scanline start 1068, end 1089
giu 16 17:16:25 Tehesyan kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe B (start=199919 end=199920) time 273 us, min 1071, max 1079, scanline start 1062, end 1063
giu 16 17:30:07 Tehesyan systemd[1129]: Failed to start app-\x2fhome\x2fandrea\x2fprogrammazione\x2fbash\x2dscripts\x2fscript\x2dremapping\x2dmouse\x2dkeys.sh-59cc7cd375644db098a000315149cb04.scope - /home/andrea/programmazione/bash-scripts/script-remapping-mouse-keys.sh.
again
andrea@Tehesyan:~$ journalctl --boot=0 --priority=4 --no-pager --grep='disk|mount'
giu 16 16:31:49 Tehesyan systemd-udevd[497]: nvme0n1: Process '/usr/bin/unshare -m /usr/bin/snap auto-import --mount=/dev/nvme0n1' failed with exit code 1.
giu 16 16:31:49 Tehesyan systemd-udevd[496]: sda: Process '/usr/bin/unshare -m /usr/bin/snap auto-import --mount=/dev/sda' failed with exit code 1.
giu 16 16:31:49 Tehesyan systemd-udevd[524]: nvme0n1p3: Process '/usr/bin/unshare -m /usr/bin/snap auto-import --mount=/dev/nvme0n1p3' failed with exit code 1.
giu 16 16:31:49 Tehesyan systemd-udevd[523]: nvme0n1p2: Process '/usr/bin/unshare -m /usr/bin/snap auto-import --mount=/dev/nvme0n1p2' failed with exit code 1.
giu 16 16:31:49 Tehesyan systemd-udevd[497]: nvme0n1p1: Process '/usr/bin/unshare -m /usr/bin/snap auto-import --mount=/dev/nvme0n1p1' failed with exit code 1.
giu 16 16:31:49 Tehesyan systemd-udevd[532]: sda1: Process '/usr/bin/unshare -m /usr/bin/snap auto-import --mount=/dev/sda1' failed with exit code 1.
other informations:
Kernel: 6.2.0-20-generic
arch: x86_64 bits:
64 compiler: N/A
Desktop: KDE Plasma v: 5.27.4
Distro: Ubuntu 23.04 (Lunar Lobster)
product: HP 250 15.6 inch G9 Notebook PC
SAMSUNG SOLID STATE DRIVE SSD 256GB M.2 NVMe
The notebook is about a month old, I don't remember very well but it seems to me that at the beginning it didn't take up all this time.
I believe the problem is before the OS loads, at least that's what I assume, unless the data provided by systemd-analyze time is incorrect.
I would like you to help me investigate why the system takes so long to start up, and take countermeasures. Thanks
P.S. The smoke you see in the video is from a cigarette, not from the notebook lol
