I am trying to transfer a file from my Ubuntu Server 18.04 installed in VirtualBox to my local machine, but I can't get it work.
The network in place is NAT, in VirtualBox I have set port forwarding.
*Name*      *Protocol*  *Host IP*   *Host port*     *Guest IP*   *Guest port*
ssh           TCP                    2222                           22
To connect to my server I'm using ssh xander@127.0.0.1 -p 2222. However I'm not able to transfer a file from the VirtualBox instance to my local machine.
scp user@remotehost:/file/to/copy /local/destination doesn't work I have tried several times.
I have tried following this stackoverflow guide for NAT firewall based machines but whenever I ran this command with my credentials ssh ComputerBUser@ComputerB -R 2222:localhost:22 I get Bad port '2222:localhost:22' so I cant do much.
pa4080
  • 30,621
xaander1
  • 219
Within SCP the port must be provided too - note here the port option is capital -P, and this option must be placed at the beginning of the command:
scp -P 2222 xander@127.0.0.1:/file/to/copy /local/destination/
IMO, for such tasks rsync is better, faster and robust (more explanations):
rsync -e 'ssh -p 2222' --progress user@remotehost:/file/to/copy /local/destination/
At all, I would prefer setup bridged connection for the virtual machine, thus it will have its own IP address in my local network
In addition I would advice you to setup ssh key based authentication and .ssh/config file - here is a short list with references about this:
pa4080
  • 30,621
