39
I just upgraded from Ubuntu 19.04 to Ubuntu 19.10. This made that my second internal HDD show up in the launcher bar or Ubuntu Dock, which it did not before.
I read that I should mount it to /mnt instead of /media, but this device was auto-mounted years ago (I believe in Ubuntu 16.04 or so) and I have a lot of symlinks and other references to the path in /media already.
How can I remove the icon from the dock without unmounting it or having to mount it to a different location? I can not even move it to another location on the bar.
pomsky
  • 70,557
foobar
  • 733
Open Terminal and run the following command:
gsettings set org.gnome.shell.extensions.dash-to-dock show-mounts false
pomsky
  • 70,557
13
In /etc/fstab locate the line that mounts your drive and remove x-gvfs-show
This can also be done in the Disks GUI, select the HDD, choose the options gear and select "Edit Mount Options", specify the options you want and uncheck "Show in user interface"
This will allow other removable media, like USB sticks and external HDD to show up, but your "permanent" extra drives to be hidden as "normal"
Chad
  • 251
This works for all ubuntu after 19.04, from @Marijn's answer under comments:
For /etc/fstab if x-gvfs-show option is not listed in your disk, e.g.:
/dev/disk/by-uuid/xxxxxxx /home auto defaults 0 0
You can add option x-gvfs-hide to actively hide it from the dock:
/dev/disk/by-uuid/xxxxxxx /home auto defaults,x-gvfs-hide 0 0
