I have a dell xps 15 9570 laptop with intel and nvidia GPU running ubuntu linux 18.04 and would like to use the nvidia card exclusively for training deep neural networks. I managed to have the X server running on intel following
How to configure igpu for xserver and nvidia gpu for cuda?
it works perfectly when in gdm3 I select to login using the gnome shell (ubuntu Wayland). running nvidia-smi shows that no process is running on the GPU. However now I wanted to try kde with plasma and there the xserver ends up on the nvidia gpu.
(base) ooo: (~) 505> nvidia-smi
Sat Jul 13 14:30:18 2019
| NVIDIA-SMI 430.26       Driver Version: 430.26       CUDA Version: 10.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  GeForce GTX 105...  Off  | 00000000:01:00.0 Off |                  N/A |
| N/A   50C    P5    N/A /  N/A |     66MiB /  4042MiB |      0%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|    0      2073      G   /usr/lib/xorg/Xorg                            66MiB |
I tried to for the X server to use intel adding teh two config files
/etc/X11/xorg.conf.d/01-noautogpu.conf /etc/X11/xorg.conf.d/20-intel.conf
into /etc/X11/xorg.conf.d as explained here
https://gist.github.com/s41m0n/323513c95290c85f7054384ac34c41c5
The result is unfortunately that after login the screen remains black. It seems that the plasmashell itself finds and uses the nvidia gpu.
Any idea how to force plasma to use the intel gpu would be very much appreciated.
A Roebel
  • 451
After discovering the questions and answers here How to configure iGPU for xserver and nvidia GPU for CUDA work, notably the answer of user890178, and studying the syslog I finally found that it is not plasma that does anything specific but the problem is the same for gnome and plasma shell when using Xorg. With Xorg the gpu-manager.service
/lib/systemd/system/gpu-manager.service
is triggered by the display-manager
/etc/systemd/system/display-manager.service.wants/gpu-manager.service
and gpu-manager detects nvidia and writes the file
/usr/share/X11/xorg.conf.d/11-nvidia-prime.conf
which contains
# DO NOT EDIT. AUTOMATICALLY GENERATED BY gpu-manager
Section "OutputClass" Identifier "Nvidia Prime" MatchDriver "nvidia-drm" Driver "nvidia" Option "AllowEmptyInitialConfiguration" Option "IgnoreDisplayDevices" "CRT" Option "PrimaryGPU" "Yes" ModulePath "/x86_64-linux-gnu/nvidia/xorg" EndSection
This file is not used by Wayland and so the nvidia card is not used, but it is used for gnome-shell on ubuntu and plasma. So in fact both will use the nvidia card for Xorg.
The solution is then a variation of the answer of Maksym Ganenko in the same question above which means is replacing /usr/share/X11/xorg.conf.d/11-nvidia-prime.conf by
Section "OutputClass" Identifier "Nvidia Prime" MatchDriver "nvidia-drm" Driver "nvidia" Option "AllowEmptyInitialConfiguration" Option "IgnoreDisplayDevices" "CRT" # Option "PrimaryGPU" "Yes" <<< commented out ModulePath "/x86_64-linux-gnu/nvidia/xorg" EndSection
added
Section "OutputClass" Identifier "intel" MatchDriver "i915" Driver "modesetting" Option "PrimaryGPU" "yes"
EndSection
and additionally to avoid gpu-manager to replace these changes when starting the next session to follow the advice of Oren in question gpu-manager overwrites xorg.conf to protect the file against changes by means of running
chattr +i /usr/share/X11/xorg.conf.d/11-nvidia-prime.conf
I seems that the fact that the screen remained black after the adding the two files I mentioned in the question to /etc/X11/xorg.conf.d is due to the fact that with the files in /usr/share/X11/xorg.conf.d that the config file did contain contradicting information.
Given the comment of GabrielaGarcia that astonishingly made the claim that what I ask cannot work on a laptop, I feel the necessity to provide a prove, that what I asked can work, and that the answer I provided is indeed a means to make it work.
Here the output of lspci proving the existence of two graphics cards
(base) m3088: (~) 505> lspci | egrep "VGA|NVIDIA"
00:02.0 VGA compatible controller: Intel Corporation Device 3e9b
01:00.0 3D controller: NVIDIA Corporation GP107M [GeForce GTX 1050 Ti Mobile] (rev a1)
Here the output of ps aux filtering the Xorg, plasma, and anaconda python running a tensorflow session. This shows that all run happily together, while plasma and Xorg do not use the nvidia card as desired (see nvidia-smi below)
(base) m3088: (~) 511> ps aux  | egrep "Xorg|plasmashell|anaconda"
roebel   13139  0.9  5.1 17315584 819236 pts/1 Sl+  00:23   0:10 /data/anasynth/anaconda3/bin/python /data/anasynth/anaconda3/bin/ipython
roebel   16198  0.0  0.0  21540  1068 pts/5    S+   00:42   0:00 grep -E Xorg|plasmashell|anaconda
roebel   18886  1.5  1.3 628292 210572 tty2    Sl+  juil.14  24:22 /usr/lib/xorg/Xorg vt2 -displayfd 3 -auth /run/user/1000/gdm/Xauthority -background none -noreset -keeptty -verbose 3
roebel   19171  2.0  3.4 6576588 561212 ?      Sl   juil.14  33:16 /usr/bin/plasmashell
Here the output of nvidia-smi proving that Xorg is not using nvidia, but the tensorflow session in anaconda python is suing it.
(base) m3088: (~) 506> nvidia-smi
Tue Jul 16 00:34:51 2019
| N/A   47C    P8    N/A /  N/A |    123MiB /  4042MiB |      0%      Default |
+-----------------------------------------------------------------------------+ | Processes: GPU Memory | | GPU PID Type Process name Usage | |=============================================================================| | 0 13139 C /data/anasynth/anaconda3/bin/python 109MiB | +-----------------------------------------------------------------------------+
I am ready to provide screenshots to show that all this happens on a laptop.
EDIT Update for Ubuntu 22.04
I finally started to use Wayland, with the unfortunate side effect that the previous solution did not work anymore. The gnome-shell was running on the GPU, leading subsequently to some problems with the interface. Following the discussion here I tried uninstalling nvidia wayland support package
sudo apt remove libnvidia-egl-wayland1
and subsequently gnome-shell does now no longer run on the Nvidia GPU keeping the GPU free for DNN training.
A Roebel
  • 451
