I have recently installed the NVIDIA drivers on my Xubuntu 15.10 machine but I had to remove them due to improper multi-monitor setup. Everything went fine, except for the fact that gpu-manager seems to overwrite my xorg.conf file with a wrong version containing NVIDIA stuff.
I know that there is a reported bug related to this, and I tried applying the hotfix suggested there but to no avail; namely, I changed /etc/init/gpu-manager.conf to:
#start on (starting lightdm
#      or starting gdm
#      or starting kdm
#      or starting xdm
#      or starting lxdm)
task
exec gpu-manager --log /var/log/gpu-manager.log
My xorg.config file keeps being overwritten with the NVIDIA stuff.
Any other suggestions? I am also a bit concerned that some people suggested that the hotfix above might freeze the syystem (whatever that means).
adrianp
  • 261
OK, as per this blogpost, adding nogpumanager to GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub solves the issue. Thus, the line in /etc/default/grub should look like:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash nogpumanager"
After you edit the file, don't forget to run:
sudo update-grub
adrianp
  • 261
Look here for all possible solution https://vxlabs.com/2015/02/05/solving-the-ubuntu-14-04-nvidia-346-nvidia-prime-black-screen-issue/#comments
one good solution is
 By doing sudo chattr +i /etc/X11/xorg.conf you can prevent any process from changing the file.
But then I am not sure aticonfig --initial will work
Oren
  • 151
For those who get 640x480 screen or whatever problem and you had touchpad settings in the old overwritten xorg.conf file (those settings are already backed up in a file names similar to xorg.conf.12345678) The solution is: after commenting those lines out in /etc/init/gpu-manager.conf like this:
#      or starting gdm
#      or starting kdm
#      or starting xdm
#      or starting lxdm)
task
All you have to do is to remove /etc/X11/xorg.conf file once then run sudo service lightdm restart and after that you see there is a new xorg.conf generated. You can copy old settings from xorg.conf.12345678 to the end of the new xorg.conf file. And restart lightdm service again.
newpeople
  • 131
