Previous setup:
  • windows 10 + ubuntu 16.04 dual boot with grub on ssd1(/dev/nvme0n1).
Current setup:
  • ssd2(/dev/nvme1n1) contains only windows 10 cloned from above. Boots fine.
  • ssd1(/dev/nvme0n1) contains only ubuntu, all other partitions removed. Can't boot here.
I want to be able to dual boot again and select either windows 10 or ubuntu from the menu. This is what the terminal shows in the live usb:
ubuntu@ubuntu:~$ sudo fdisk -l
Disk /dev/loop0: 1.5 GiB, 1601015808 bytes, 3126984 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/nvme0n1: 238.5 GiB, 256060514304 bytes, 500118192 sectors
Disklabel type: gpt
Disk identifier: F6F46D18-D629-4D34-9F1A-0900B2600555
Device         Start       End   Sectors Size Type
/dev/nvme0n1p1  2048 104859647 104857600  50G Linux filesystem
Disk /dev/nvme1n1: 465.8 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: gpt
Disk identifier: 4C872172-3D07-4489-B670-6FB593A31318
/dev/nvme1n1p1     2048   1026047   1024000   500M EFI System
/dev/nvme1n1p2  1026048   1288191    262144   128M Microsoft reserved
/dev/nvme1n1p3  1288192   3033087   1744896   852M Windows recovery environment
/dev/nvme1n1p4  3033088  23244799  20211712   9.7G Windows recovery environment
/dev/nvme1n1p5 23244800 976773119 953528320 454.7G Microsoft basic data
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: F7921471-F857-4820-9356-237BF02CAD38
/dev/sda1          34     262177     262144   128M Microsoft reserved
/dev/sda2      264192 1919969279 1919705088 915.4G Microsoft basic data
/dev/sda3  1919969280 1953523711   33554432    16G Linux swap
Partition 1 does not start on physical sector boundary.
Disk /dev/sdb: 7.3 GiB, 7813988352 bytes, 15261696 sectors
Disklabel type: dos
Disk identifier: 0xf5e34067
Device     Boot Start      End  Sectors  Size Id Type
/dev/sdb1  *     8064 15124991 15116928  7.2G  c W95 FAT32 (LBA)
ubuntu@ubuntu:~$
lsblk:
ubuntu@ubuntu:~$ lsblk -f -o +PARTLABEL /dev/nvme1n1
NAME        FSTYPE LABEL      UUID                                 MOUNTPOINT PARTLABEL
nvme1n1
├─nvme1n1p4 ntfs   Image      C66E65726E655BE5
├─nvme1n1p2        Microsoft reserved partition
├─nvme1n1p5 ntfs   OS         01D238F37C836540                                Basic data partition
├─nvme1n1p3 ntfs   WINRETOOLS AEFA63D2FA63957D
└─nvme1n1p1 vfat   ESP        9AB9-9DEA                                       EFI system partition
ubuntu@ubuntu:~$ lsblk -f -o +PARTLABEL /dev/nvme0n1
nvme0n1
└─nvme0n1p1 ext4         1e27d729-df08-4d63-ad19-402e4c3340cf /media/ubuntu/1e27d729-df08-4d63-ad19-402e4c3340cf
ubuntu@ubuntu:~$
blkid:
ubuntu@ubuntu:~$ blkid
/dev/nvme0n1p1: UUID="1e27d729-df08-4d63-ad19-402e4c3340cf" TYPE="ext4" PARTUUID="97c73deb-1ad6-4fa9-bc50-7dad24f84a68"
/dev/nvme1n1p1: LABEL="ESP" UUID="9AB9-9DEA" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="ac04e9de-aeb3-4595-9498-7e088a2178f7"
/dev/nvme1n1p3: LABEL="WINRETOOLS" UUID="AEFA63D2FA63957D" TYPE="ntfs" PARTUUID="162446b1-0911-41bf-8b91-6e92609105fe"
/dev/nvme1n1p4: LABEL="Image" UUID="C66E65726E655BE5" TYPE="ntfs" PARTUUID="8d16423b-2a17-45f3-ab56-95652bcb47af"
/dev/nvme1n1p5: LABEL="OS" UUID="01D238F37C836540" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="f8fe17da-3179-4c3e-98b0-ba7d0e8ad7ad"
/dev/sda2: LABEL="Data" UUID="86F26B62F26B5609" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="ff2d059c-108b-4e4a-9ef1-1d5645bf4e70"
/dev/sdb1: LABEL="UUI" UUID="0CDF-DB24" TYPE="vfat" PARTUUID="f5e34067-01"
ubuntu@ubuntu:~$
/etc/fstab:
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
# / was on /dev/nvme0n1p6 during installation
UUID=1e27d729-df08-4d63-ad19-402e4c3340cf /               ext4    errors=remount-ro 0       1
# /boot/efi was on /dev/nvme0n1p1 during installation
#UUID=9AB9-9DEA  /boot/efi       vfat    umask=0077      0       1
# swap was on /dev/sda3 during installation
UUID=74c15561-f026-4824-bc85-32e3ee9b5d90 none            swap    sw              0       0
UUID=9AB9-9DEA  /boot/efi   vfat    defaults    0   1
This is grub.cfg : https://pastebin.com/cL1KFY5c
The best way of cloning Ubuntu from one drive to another, or one partition to another, is with a script that resets UUID's in /boot/grub/grub.cfg and /etc/fstab like this one:
If you simply clone with a tool that doesn't change UUID's you need to use boot-repair as demonstrated here:
After running boot-repair you can get 7 entries for Windows so use this method to remove the extra entries:
With multiple Operating Systems you will get generic names created in grub such as:
  • Ubuntu
  • Windows Boot Manager (on /dev/nvme0n1p2)
  • Windows Boot Manager (on /dev/sda1)
  • Ubuntu 18.04 LTS (18.04) (on /dev/nvme0n1p6)
To get user friendly or more meaningful OS names for yourself use:
Disclaimer I wrote all the above links.
