23
I've been having an error when updating or running any apt command for a week or so. Upgrading to LTS 18.04 hasn't resolved it, nor has removing all old kernels. Space isn't an issue either.
Attempting to reinstall initramfs doesn't work. Error I get is:
   Reading package lists...
Building dependency tree...
Reading state information...
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up linux-image-4.15.0-47-generic (4.15.0-47.50) ...
Setting up initramfs-tools (0.130ubuntu3.7) ...
update-initramfs: deferring update (trigger activated)
Processing triggers for linux-image-4.15.0-47-generic (4.15.0-47.50) ...
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-4.15.0-47-generic
E: /usr/share/initramfs-tools/hooks/fsck failed with return 1.
update-initramfs: failed for /boot/initrd.img-4.15.0-47-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
dpkg: error processing package linux-image-4.15.0-47-generic (--configure):
 installed linux-image-4.15.0-47-generic package post-installation script subprocess returned error exit status 1
Processing triggers for initramfs-tools (0.130ubuntu3.7) ...
dpkg: error processing package initramfs-tools (--configure):
 installed initramfs-tools package post-installation script subprocess returned error exit status 1
 initramfs-tools
Anyone got any ideas as to what I can do?
Thanks.
adieb
  • 331
13 Answers13
29
Running auto-remove and clean worked for my situation.
apt-get auto-remove && apt-get clean && apt-get update && apt-get upgrade
25
Warning: do not do this if your hard drive is encrypted unless you know exactly what you're doing
For me, it was an issue with the initramfs-tools package
I just did:
sudo apt remove initramfs-tools
sudo apt clean
sudo apt install initramfs-tools
Then I no longer received the error
@jameshibbard brought up an important point: if you use either full-drive encryption, or encrypt your initramfs output (squashfs vmlinuz pacakges in /boot) as is a new feature, please be careful as switching out versions of your initramfs-tools seem likely to make your system unbootable.
If you have no idea what that means, chances are your system is not encrypted, unless you remember selecting it during the install process. I've noticed some graphical installers are including it as an option these days, including Ubuntu if I'm remembering correctly.
Do your due diligence.
15
I had this error since more than a year. Now I found a solution.
cd ~
mkdir initramfs
cd initramfs
sudo cp -a /boot .
cd boot
sudo update-initramfs -ut -b .
sudo cp -a * /boot
sudo apt-get autoremove
Explanation: /boot is on a different partition with insufficient space to perform the operation. Solution: do the update on a drive where there is sufficient space and copy back the results.
Harald
  • 151
As pointed out by Harald, the problem was insufficient space on the /boot partition.
His solution didn't work for me, but led me directly to what did:
cd /boot, then ls to look at the versions of the files already there. Then rm each of the files that have multiple versions, making sure to delete all but the newest, then sudo apt update
sudo apt clean
sudo apt-get autoclean
sudo apt-get clean
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
sudo apt-get -f install
sudo dpkg --configure -a
This was the solution for me.
Zanna
  • 72,312
I had this problem too. My /boot partition was full. So, I was getting errors of initframs compilation when trying to run apt-update. My solution was to remove old kernels in order to free up space, following the steps from Lekensteyn in: How do I free up more space in /boot?
This will list all the kernel images and headers currently installed:
~ % kernelver=$(uname -r | sed -r 's/-[a-z]+//')
dpkg -l linux-{image,headers}-"[0-9]*" | awk '/ii/{print $2}' | grep -ve $kernelver
linux-headers-5.4.0-94 linux-headers-5.4.0-94-generic linux-headers-5.4.0-96 linux-headers-5.4.0-96-generic linux-headers-5.4.0-99 linux-headers-5.4.0-99-generic linux-image-5.4.0-94-generic linux-image-5.4.0-96-generic linux-image-5.4.0-99-generic
You can purge the older linux-headers and linux-image packages by using apt-get purge with care (remember, not to delete the packages associated to the kernel you are using), for instance:
sudo apt-get purge linux-image-5.4.0-94 linux-image-5.4.0-96 linux-headers-5.4.0-94 linux-headers-5.4.0-96
This should take care also of the matching generic packages.
Afterwards, I ran
sudo apt-get auto-remove && sudo apt-get clean && sudo apt-get update && sudo apt-get upgrade
and the errors were fixed.
mapazarr
  • 176
A similar question has this solution:
sudo apt-get clean
sudo apt-get update
Additionally ensure this executable exists:
ls -alF /usr/share/initramfs-tools/hooks/fsck
returns this output:
-rwxr-xr-x 1 root root 2468 Sep 18  2018 /usr/share/initramfs-tools/hooks/fsck
Erkko
  • 35
I had this issue on two separate machines today after doing an apt update and apt upgrade except mine was for linux-image-4.15.0-48-generic. (Ubuntu 18.04.2)
My fix was this (reproduced on both machines):
sudo rm /var/lib/dpkg/info/linux-image-4.15.0-48-generic.postinst
sudo apt-get update
Then reinstall the package:
sudo apt install linux-image-4.15.0-48-generic
This will set the package to manually installed and will replace the *.postinst file.
Ben Molloy
I've just had a very similar issue when I did an sudo apt autoremove and it failed attempting to install kernel files for a kernel I don't have. My uname -a shows I'm using kernel version 5.0.0-20 and running ls -al /boot shows only this and the 5.0.0-17 kernel are installed. However, apt suddenly turned up errors and attempted to install files in my /boot for old kernels including 5.0.0-15, 4.18.0-17, 4.13.0-45. Which is weird.
So I figure that somehow they've altered the logic for dkms (or something related to initramfs) and it checks some other locations to see if kernels might be installed and then does updates on those kernels and replaces missing files.
I'm not sure exactly what fixed it but I did:
sudo apt purge *5.0.0-15* *4.18.0-17* *4.13.0-45*
#check carefully that it's not removing anything you need though, this is a hammer to crack a nut
ls -al /lib/modules
# which revealed lots of old module folders that I removed with ...
sudo rm -rf /lib/modules/4.*
# and similarly for the 5.0.0-15 modules
Then I did:
ls -al /usr/src/
# which again showed old source trees that I pruned with
sudo rm -rf sudo rm -rf /usr/src/linux-headers-4.*
Then I did:
locate -e 4.13.0
# which found old kernel files in
ls -al /var/lib/initramfs-tools/
# so I removed with
sudo rm -rf /var/lib/initramfs-tools/4*
I have problems with a very tight /boot folder for historical reasons and so removed old kernel files with:
sudo rm -i /boot/**4*
# and similar for all but my current and next oldest kernels
# -i is interactive mode so you have to answer 'y' to remove
# that's a really useful safety check, 'sudo rm' is a dangerous tool!
Finally I ran:
sudo apt -f install
Which finished as expected and returned the system to the expected state without attempting to install extraneous kernels. I did not test as I went along so can not guarantee which part fixed it, but it was not harmful to clear those old files out AFAICT.
Aside, checking my /var/log/apt/history.log file, this appears to be the beginning of this particular error:
Start-Date: 2019-07-01  17:59:10
Commandline: /usr/bin/unattended-upgrade
Upgrade: linux-tools-common:amd64 (4.15.0-52.56, 4.15.0-54.58)
End-Date: 2019-07-01  17:59:16
Start-Date: 2019-07-01  17:59:22
Install: linux-image-5.0.0-20-generic:amd64 (5.0.0-20.21~18.04.1, automatic), linux-modules-extra-5.0.0-20-generic:amd64 (5.0.0-20.21~18.04.1, automatic), linux-modules-5.0.0-20-generic:amd64 (5.0.0-20.21~18.04.1, automatic)
Upgrade: linux-image-generic-hwe-18.04-edge:amd64 (5.0.0.17.73, 5.0.0.20.76), linux-image-extra-virtual-hwe-18.04-edge:amd64 (5.0.0.17.73, 5.0.0.20.76)
Error: Sub-process /usr/bin/dpkg returned an error code (1)
End-Date: 2019-07-01  18:00:10
But this may be a false flag as for me the limited /boot space can be the cause of the error code (1).
pbhj
  • 3,364
Try purging unused kernels. If problem persists then remove all 'initrd' images with
sudo rm /boot/initrd.img*
then generate new 'initrd' images for all current existing kernels
sudo update-initramfs -c -k all
droptop
  • 101
This was happening to me. Ended up being that /boot was full.
Check boot partition space with df -h
Then free up some space with: How do I free up more space in /boot?
I followed all the advice here and nothing worked. I fixed it by making sure that the boot/efi partition was mounted, which in my case it wasn't. /etc/fstab was not configured correctly due to the partuuid/uuid/lable not matching. Then I updated and upgraded with no errors, followed by updating grub and a reboot.
initramfs error when installing / updating
I continued to have this issue even after removing old kernels. I was dealing with a 250 MB /boot partition which it seems is no longer big enough...
If you have tried everything else, an additional way to free up space on /boot may be to switch the compression algorithm that initramfs is using to create the initrd images.
Open up the following file:
sudo vim /etc/initramfs-tools/initramfs.conf
Check what COMPRESS is set to. In my case it was:
COMPRESS=lz4
The xz algorithm will significantly reduce the size of the initrd.img-xxx image. By simply making the following change, it was reduced by around 50%.
COMPRESS=xz
Will Law
  • 94
