I've been having an error when updating or running any apt command for a week or so. Upgrading to LTS 18.04 hasn't resolved it, nor has removing all old kernels. Space isn't an issue either.
Attempting to reinstall initramfs doesn't work. Error I get is:
Setting up initramfs-tools (0.136ubuntu6.3) ...
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.136ubuntu6.3) ...
update-initramfs: Generating /boot/initrd.img-5.4.0-52-generic
E: /usr/share/initramfs-tools/hooks/plymouth failed with return 1.
update-initramfs: failed for /boot/initrd.img-5.4.0-52-generic with 1.
dpkg: error processing package initramfs-tools (--configure):
installed initramfs-tools package post-installation script subprocess returned error exit status 1
EDIT: Later addition (April 2022) to the question.
This is not for my system, but by my search this was more or less the 1. hit.
initramfs-tools:
Installiert: 0.136ubuntu6.7
Installationskandidat: 0.136ubuntu6.7
Versionstabelle:
*** 0.136ubuntu6.7 500
500 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages
500 http://archive.ubuntu.com/ubuntu focal-updates/main i386 Packages
100 /var/lib/dpkg/status
0.136ubuntu6 500
500 http://archive.ubuntu.com/ubuntu focal/main amd64 Packages
500 http://archive.ubuntu.com/ubuntu focal/main i386 Packages
we draw the package initramfs-tools with wget fresh and try to install it with dpkg also the packages plymouth.
$ sudo dpkg -i initramfs-tools_0.136ubuntu6.7_all.deb
(Lese Datenbank ... 548002 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von initramfs-tools_0.136ubuntu6.7_all.deb ...
Entpacken von initramfs-tools (0.136ubuntu6.7) über (0.136ubuntu6.7) ...
initramfs-tools (0.136ubuntu6.7) wird eingerichtet ...
Trigger für man-db (2.9.1-1) werden verarbeitet ...
Trigger für initramfs-tools (0.136ubuntu6.7) werden verarbeitet ...
update-initramfs: Generating /boot/initrd.img-5.4.0-109-generic
update-initramfs: failed for /boot/initrd.img-5.4.0-109-generic with 1.
dpkg: Fehler beim Bearbeiten des Paketes initramfs-tools (--install):
»installiertes initramfs-tools-Skript des Paketes post-installation«-Unterprozess gab den Fehlerwert 1 zurück
Fehler traten auf beim Bearbeiten von:
initramfs-tools
then we tried to get more info
$ dash -x /usr/share/initramfs-tools/hooks/plymouth
+ set -e
+ OPTION=FRAMEBUFFER
+ PREREQ=
+ . /usr/share/initramfs-tools/hook-functions
+ update-alternatives --query default.plymouth
+ sed -e /^Value:/!d -e s/^Value: \(.*\)/\1/
+ THEME_PATH=/usr/share/plymouth/themes/mint-logo/mint-logo.plymouth
+ basename /usr/share/plymouth/themes/mint-logo/mint-logo.plymouth .plymouth
+ THEME=mint-logo
+ THEMES=/usr/share/plymouth/themes
+ [ -n /usr/share/plymouth/themes/mint-logo/mint-logo.plymouth ]
+ grep ImageDir *= * /usr/share/plymouth/themes/mint-logo/mint-logo.plymouth
+ sed s/ImageDir *= *//
+ IMAGE_PATH=/usr/share/plymouth/themes/mint-logo
+ [ -n /usr/share/plymouth/themes/mint-logo ]
+ [ /usr/share/plymouth/themes/mint-logo/mint-logo.plymouth != /usr/share/plymouth/themes/mint-logo ]
+ IMAGE_NAME=mint-logo
+ mkdir -p //usr/share/plymouth/themes
+ [ -n mint-logo ]
+ [ mint-logo != none ]
+ THEME_NAME=mint-logo
+ THEME=/usr/share/plymouth/themes/mint-logo/mint-logo.plymouth
+ ln -s /usr/share/plymouth/themes/mint-logo/mint-logo.plymouth //usr/share/plymouth/themes/default.plymouth
ln: Die symbolische Verknüpfung '//usr/share/plymouth/themes/default.plymouth' konnte nicht angelegt werden: Die Datei existiert bereits
then I checked it is mint. But it was too late the bounty was set. :(
I checked some links
$ ls -al /usr/share/plymouth/themes/default.plymouth
lrwxrwxrwx 1 root root 55 Apr 27 14:40 /usr/share/plymouth/themes/default.plymouth -> /usr/share/plymouth/themes/mint-logo/mint-logo.plymouth
and
$ update-alternatives --query text.plymouth
Link: /usr/share/plymouth/themes/text.plymouth
Status: auto
Best: /usr/share/plymouth/themes/mint-text/mint-text.plymouth
Value: /usr/share/plymouth/themes/mint-text/mint-text.plymouth
Alternative: /usr/share/plymouth/themes/mint-text/mint-text.plymouth
Priority: 200
Alternative: /usr/share/plymouth/themes/text/text.plymouth
Priority: 40
Alternative: /usr/share/plymouth/themes/ubuntu-text/ubuntu-text.plymouth
Priority: 50
and
$ update-alternatives --query default.plymouth
Link: /usr/share/plymouth/themes/default.plymouth
Status: auto
Best: /usr/share/plymouth/themes/mint-logo/mint-logo.plymouth
Value: /usr/share/plymouth/themes/mint-logo/mint-logo.plymouth
Alternative: /usr/share/plymouth/themes/bgrt/bgrt.plymouth
Priority: 110
Alternative: /usr/share/plymouth/themes/mint-logo-legacy/mint-logo-legacy.plymouth
Priority: 100
Alternative: /usr/share/plymouth/themes/mint-logo/mint-logo.plymouth
Priority: 200
Alternative: /usr/share/plymouth/themes/spinner/spinner.plymouth
Priority: 70
I checked links in /usr/share/plymouth/themes and correct theme:
insgesamt 104
drwxr-xr-x 22 root root 4096 Apr 27 16:33 .
drwxr-xr-x 3 root root 4096 Apr 27 13:38 ..
drwxr-xr-x 2 root root 4096 Apr 27 13:38 bgrt
lrwxrwxrwx 1 root root 40 Aug 28 2019 debian-theme -> ../../desktop-base/active-theme/plymouth #this one I let unlink too
lrwxrwxrwx 1 root root 34 Apr 27 16:33 default.plymouth -> /etc/alternatives/default.plymouth
drwxr-xr-x 2 root root 4096 Apr 27 13:38 details
drwxr-xr-x 2 root root 4096 Apr 27 13:38 fade-in
drwxr-xr-x 2 root root 4096 Mai 12 2021 futureprototype
drwxr-xr-x 2 root root 12288 Apr 27 13:38 glow
drwxr-xr-x 2 root root 4096 Mai 12 2021 joy
drwxr-xr-x 2 root root 4096 Mai 12 2021 lines
drwxr-xr-x 2 root root 4096 Jan 14 15:46 mint-logo
drwxr-xr-x 2 root root 4096 Jan 14 15:46 mint-logo-legacy
drwxr-xr-x 2 root root 4096 Jan 14 15:46 mint-text
drwxr-xr-x 2 root root 4096 Mai 12 2021 moonlight
drwxr-xr-x 2 root root 4096 Apr 27 13:38 script
drwxr-xr-x 2 root root 4096 Mai 12 2021 softwaves
drwxr-xr-x 2 root root 4096 Apr 27 13:38 solar
drwxr-xr-x 2 root root 4096 Mai 12 2021 spacefun
drwxr-xr-x 2 root root 4096 Apr 27 13:38 spinfinity
drwxr-xr-x 2 root root 12288 Apr 27 13:38 spinner
drwxr-xr-x 2 root root 4096 Apr 27 13:38 text
lrwxrwxrwx 1 root root 31 Apr 27 16:33 text.plymouth -> /etc/alternatives/text.plymouth
drwxr-xr-x 2 root root 4096 Apr 27 13:38 tribar
drwxr-xr-x 2 root root 4096 Apr 27 13:38 ubuntu-text
And another try I renamed /usr/share/initramfs-tools/hooks/plymouth and unpacked the plymouth package to replace it:
$ sudo update-initramfs -v -u -k $(uname -r)
the output is too long, it is posted in debug-mode. I do not see errors but maybe I'm wrong.
sudo inxi -SMG
System: Host: xxx Kernel: 5.4.0-109-generic x86_64 bits: 64 Console: tty 1 Distro: Linux Mint 20.2 Uma
Machine: Type: Desktop System: Gigabyte product: Z97X-UD3H v: N/A serial: N/A
Mobo: Gigabyte model: Z97X-UD3H-CF v: x.x serial: N/A UEFI: American Megatrends v: F7 date: 06/17/2014
Graphics: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics driver: i915 v: kernel
Device-2: NVIDIA GP104 [GeForce GTX 1070] driver: nvidia v: 470.103.01
Display: server: X.org 1.20.13 driver: modesetting,nvidia unloaded: fbdev,nouveau,vesa tty: 212x58
Message: Advanced graphics data unavailable in console for root.
Note: nvidia module is correct build and installed in the running kernel. And in journal, I found
kernel: [drm] Initialized i915 1.6.0 20190822 for 0000:00:02.0 on minor 0
Mai 03 08:40:08 xxx kernel: [drm] Cannot find any crtc or sizes
apt-cache policy initramfs-tools
initramfs-tools:
Versionstabelle:
0.136ubuntu6 500
