I use Lubuntu 20.04, which boots from an SSD.
Today I allowed the system to do upgrades, and subsequently got an error message saying that update-initramfs failed. I googled the error message and found this link which suggested the problem could be resolved by freeing some space on /boot and reinstalling a package. I think I made a mistake trying to do both fixes in one procedure.
I did:
sudo apt remove initramfs-tools
sudo apt-get auto-remove
sudo apt-get clean
sudo apt install initramfs-tools
sudo apt-get update
Everything appeared to be fixed until I rebooted the machine. The machine could not reboot automatically, but I entered the boot menu and picked an older kernel. That worked. Inspecting the broken and working boot commands, I believe that I am no longer booting off the SSD (I could also be wrong).
The broken boot option (which used to work) is:
menuentry 'Ubuntu, with Linux 5.4.0-86-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.0-86-generic-advanced-f81f27eb-c1f2-467c-a62b-fdd60b4f0592' {
        recordfail
        load_video
        gfxmode $linux_gfx_mode
        insmod gzio
        if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
        insmod part_gpt
        insmod ext2
        if [ x$feature_platform_search_hint = xy ]; then
          search --no-floppy --fs-uuid --set=root  504e9392-5142-456a-852d-7838c4a522bc
        else
        fi
        echo    'Loading Linux 5.4.0-86-generic ...'
        linux   /vmlinuz-5.4.0-86-generic root=/dev/nvme0n1p3 ro  quiet splash $vt_handoff
... and the working option is:
menuentry 'Ubuntu, with Linux 5.4.0-84-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.0-84-generic-advanced-f81f27eb-c1f2-467c-a62b-fdd60b4f0592' {
        recordfail
        load_video
        insmod gzio
        insmod part_gpt
        insmod ext2
        else
        fi
        echo    'Loading Linux 5.4.0-84-generic ...'
        linux   /vmlinuz-5.4.0-84-generic root=UUID=f81f27eb-c1f2-467c-a62b-fdd60b4f0592 ro  quiet splash $vt_handoff
        echo    'Loading initial ramdisk ...'
        initrd  /initrd.img-5.4.0-84-generic
Is there any way I can repair the damage and get Lubuntu back to booting from the SSD ? I now think that the autoremove operation may have destroyed some vital information on the SSD.
The broken boot option produces this output before crashing:
If I use the working boot option, I now get the following response from df (/boot appears to be on the SSD, so looks like my idea that this option was booting via the hard drive is probably wrong).
df -h
Filesystem      Size  Used Avail Use% Mounted on
udev             16G     0   16G   0% /dev
tmpfs           3.2G  2.1M  3.2G   1% /run
/dev/nvme0n1p3  468G  121G  324G  28% /
tmpfs            16G   92M   16G   1% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs            16G     0   16G   0% /sys/fs/cgroup
tmpfs            16G   11M   16G   1% /tmp
/dev/loop1      128K  128K     0 100% /snap/bare/5
/dev/loop3       62M   62M     0 100% /snap/core20/1081
/dev/loop2       56M   56M     0 100% /snap/core18/2128
/dev/loop4      165M  165M     0 100% /snap/gnome-3-28-1804/161
/dev/loop5      243M  243M     0 100% /snap/gnome-3-38-2004/76
/dev/loop0       56M   56M     0 100% /snap/core18/2074
/dev/loop6       66M   66M     0 100% /snap/gtk-common-themes/1515
/dev/loop7       66M   66M     0 100% /snap/gtk-common-themes/1519
/dev/loop8      699M  699M     0 100% /snap/libreoffice/227
/dev/nvme0n1p2  510M  318M  155M  68% /boot
/dev/nvme0n1p1  532M  5.3M  527M   1% /boot/efi
/dev/loop9      163M  163M     0 100% /snap/gnome-3-28-1804/145
/dev/loop10      33M   33M     0 100% /snap/snapd/13170
/dev/loop11      33M   33M     0 100% /snap/snapd/12883
/dev/loop12     701M  701M     0 100% /snap/libreoffice/229
/dev/loop13     242M  242M     0 100% /snap/gnome-3-38-2004/70
tmpfs           3.2G  8.0K  3.2G   1% /run/user/1000
/dev/sdb1       1.9T 1008G  856G  55% /media/paul/Seagate Backup Plus Drive
My complete grub.cfg is:
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
BEGIN /etc/grub.d/00_header
if [ -s $prefix/grubenv ]; then set have_grubenv=true load_env fi if [ "${initrdfail}" = 2 ]; then set initrdfail= elif [ "${initrdfail}" = 1 ]; then set next_entry="${prev_entry}" set prev_entry= save_env prev_entry if [ "${next_entry}" ]; then set initrdfail=2 fi fi if [ "${next_entry}" ] ; then set default="${next_entry}" set next_entry= save_env next_entry set boot_once=true else set default="0" fi
if [ x"${feature_menuentry_id}" = xy ]; then menuentry_id_option="--id" else menuentry_id_option="" fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then set saved_entry="${prev_saved_entry}" save_env saved_entry set prev_saved_entry= save_env prev_saved_entry set boot_once=true fi
function savedefault { if [ -z "${boot_once}" ]; then saved_entry="${chosen}" save_env saved_entry fi } function initrdfail { if [ -n "${have_grubenv}" ]; then if [ -n "${partuuid}" ]; then if [ -z "${initrdfail}" ]; then set initrdfail=1 if [ -n "${boot_once}" ]; then set prev_entry="${default}" save_env prev_entry fi fi save_env initrdfail fi; fi } function recordfail { set recordfail=1 if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi } function load_video { if [ x$feature_all_video_module = xy ]; then insmod all_video else insmod efi_gop insmod efi_uga insmod ieee1275_fb insmod vbe insmod vga insmod video_bochs insmod video_cirrus fi }
if [ x$feature_default_font_path = xy ] ; then font=unicode else insmod part_gpt insmod ext2 if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root f81f27eb-c1f2-467c-a62b-fdd60b4f0592 else search --no-floppy --fs-uuid --set=root f81f27eb-c1f2-467c-a62b-fdd60b4f0592 fi font="/usr/share/grub/unicode.pf2" fi
if loadfont $font ; then set gfxmode=auto load_video insmod gfxterm set locale_dir=$prefix/locale set lang=en_GB insmod gettext fi terminal_output gfxterm if [ "${recordfail}" = 1 ] ; then set timeout=30 else if [ x$feature_timeout_style = xy ] ; then set timeout_style=hidden set timeout=0
Fallback hidden-timeout code in case the timeout_style feature is
unavailable.
elif sleep --interruptible 0 ; then set timeout=0 fi fi
END /etc/grub.d/00_header
BEGIN /etc/grub.d/05_debian_theme
set menu_color_normal=white/black set menu_color_highlight=black/light-gray
END /etc/grub.d/05_debian_theme
BEGIN /etc/grub.d/10_linux
function gfxmode { set gfxpayload="${1}" if [ "${1}" = "keep" ]; then set vt_handoff=vt.handoff=7 else set vt_handoff= fi } if [ "${recordfail}" != 1 ]; then if [ -e ${prefix}/gfxblacklist.txt ]; then if hwmatch ${prefix}/gfxblacklist.txt 3; then if [ ${match} = 0 ]; then set linux_gfx_mode=keep else set linux_gfx_mode=text fi else set linux_gfx_mode=text fi else set linux_gfx_mode=keep fi else set linux_gfx_mode=text fi export linux_gfx_mode menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-f81f27eb-c1f2-467c-a62b-fdd60b4f0592' { recordfail load_video gfxmode $linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root 504e9392-5142-456a-852d-7838c4a522bc else search --no-floppy --fs-uuid --set=root 504e9392-5142-456a-852d-7838c4a522bc fi linux /vmlinuz-5.4.0-86-generic root=/dev/nvme0n1p3 ro quiet splash $vt_handoff } submenu 'Advanced options for Ubuntu' $menuentry_id_option 'gnulinux-advanced-f81f27eb-c1f2-467c-a62b-fdd60b4f0592' { menuentry 'Ubuntu, with Linux 5.4.0-86-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.0-86-generic-advanced-f81f27eb-c1f2-467c-a62b-fdd60b4f0592' { recordfail load_video gfxmode $linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root 504e9392-5142-456a-852d-7838c4a522bc else search --no-floppy --fs-uuid --set=root 504e9392-5142-456a-852d-7838c4a522bc fi echo 'Loading Linux 5.4.0-86-generic ...' linux /vmlinuz-5.4.0-86-generic root=/dev/nvme0n1p3 ro quiet splash $vt_handoff } menuentry 'Ubuntu, with Linux 5.4.0-86-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.0-86-generic-recovery-f81f27eb-c1f2-467c-a62b-fdd60b4f0592' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root 504e9392-5142-456a-852d-7838c4a522bc else search --no-floppy --fs-uuid --set=root 504e9392-5142-456a-852d-7838c4a522bc fi echo 'Loading Linux 5.4.0-86-generic ...' linux /vmlinuz-5.4.0-86-generic root=/dev/nvme0n1p3 ro recovery nomodeset dis_ucode_ldr } menuentry 'Ubuntu, with Linux 5.4.0-84-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.0-84-generic-advanced-f81f27eb-c1f2-467c-a62b-fdd60b4f0592' { recordfail load_video gfxmode $linux_gfx_mode insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root 504e9392-5142-456a-852d-7838c4a522bc else search --no-floppy --fs-uuid --set=root 504e9392-5142-456a-852d-7838c4a522bc fi echo 'Loading Linux 5.4.0-84-generic ...' linux /vmlinuz-5.4.0-84-generic root=UUID=f81f27eb-c1f2-467c-a62b-fdd60b4f0592 ro quiet splash $vt_handoff echo 'Loading initial ramdisk ...' initrd /initrd.img-5.4.0-84-generic } menuentry 'Ubuntu, with Linux 5.4.0-84-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.0-84-generic-recovery-f81f27eb-c1f2-467c-a62b-fdd60b4f0592' { recordfail load_video insmod gzio if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi insmod part_gpt insmod ext2 if [ x$feature_platform_search_hint = xy ]; then search --no-floppy --fs-uuid --set=root 504e9392-5142-456a-852d-7838c4a522bc else search --no-floppy --fs-uuid --set=root 504e9392-5142-456a-852d-7838c4a522bc fi echo 'Loading Linux 5.4.0-84-generic ...' linux /vmlinuz-5.4.0-84-generic root=UUID=f81f27eb-c1f2-467c-a62b-fdd60b4f0592 ro recovery nomodeset dis_ucode_ldr echo 'Loading initial ramdisk ...' initrd /initrd.img-5.4.0-84-generic } }
END /etc/grub.d/10_linux
BEGIN /etc/grub.d/10_linux_zfs
END /etc/grub.d/10_linux_zfs
BEGIN /etc/grub.d/20_linux_xen
END /etc/grub.d/20_linux_xen
BEGIN /etc/grub.d/20_memtest86+
END /etc/grub.d/20_memtest86+
BEGIN /etc/grub.d/30_os-prober
END /etc/grub.d/30_os-prober
BEGIN /etc/grub.d/30_uefi-firmware
menuentry 'UEFI Firmware Settings' $menuentry_id_option 'uefi-firmware' { fwsetup }
END /etc/grub.d/30_uefi-firmware
BEGIN /etc/grub.d/40_custom
This file provides an easy way to add custom menu entries. Simply type the
menu entries you want to add after this comment. Be careful not to change
the 'exec tail' line above.
END /etc/grub.d/40_custom
BEGIN /etc/grub.d/41_custom
if [ -f ${config_directory}/custom.cfg ]; then source ${config_directory}/custom.cfg elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then source $prefix/custom.cfg; fi
END /etc/grub.d/41_custom
Solved it ! I'll explain how for anyone encountering a similar issue. Two posts helped me solve the problem.
I booted the system using a previous kernel (if I had not had that I would have tried booting from a USB stick).
Firstly I found out how to use journalctl to view errors from the failed boot:
journalctl -b -2 -e
I added output from journalctl to my original post. You may need to change the number in order to view the correct boot. You can find the right number using:
journalctl --list-boots
The post that helped me is here
Secondly, I identified the key problem from the log as:
kernel panic - not syncing vfs unable to mount root fs on unknown-block(0 0)
This was solved by:
sudo update-initramfs -u -k 5.4.0-86-generic
sudo update-grub
Where 5.4.0-86-generic is the name of the kernel that had broken and stopped booting.
The post that helped me is this
