I routinely backup my books to another computer within the same wifi,
rsync -avlu --exclude=".git" ~/Documents/Books beta@192.168.31.90:~/Documents/Books
rsync -avlu --exclude={.git,.DS_Store}" ~/Documents/Books beta@192.168.31.90:~/Documents/Books
Everytime, I should remember the ip address of destination machine.
Tried @local and @localhost but failed.
How could I use a name rather than a series of numbers?
pa4080
  • 30,621
Alice
  • 1,750
For this purpose you need to setup ~/.ssh/config file:
touch ~/.ssh/config
chmod 600 ~/.ssh/config
The content of the file should look as:
Host my-destination-host
    HostName 192.168.31.90
    IdentityFile ~/.ssh/id_rsa
    User beta
    Port 22
Host another-example
    HostName 222.222.22.222
    User another-user
    IdentityFile ~/.ssh/another-path/id_rsa
    Port 2233
    RemoteForward 6900 127.0.0.1:5900
    RemoteForward 3389 192.168.100.115:3389
    Compression yes
    CompressionLevel 6
# etc.
Once the file is saved, you will be able to ssh to beta@192.168.31.90 by the command:
ssh my-destination-host
or for the another example - note the Tab completion is applicable for the Host names:
ssh another-exampTab ↹
Respectively most of the commands that use ssh can use the configuration file. For example rsync:
rsync -avlu --exclude=".git" ~/Documents/Books my-destination-host:~/Documents/Books
References and more examples, where the ~/.ssh/config file is used:
pa4080
  • 30,621
Why not just use the 'dot local' hostname?
rsync -avlu --exclude=".git" ~/Documents/Books beta@my-machine.local:~/Documents/Books
On the receiving machine, go to System Preferences -> Sharing. Next to 'computer name' click 'edit'. Then copy the address. Mine, for instance, is 'terminal-36.local'.
Also consider specifying --rsh=/usr/bin/ssh -o AddressFamily=inet. Resolving .local hostnames to IPv6 has always caused me bother (but perhaps you'll be luckier).
dave
  • 101
