So I started following the instructions on: https://wiki.winehq.org/Ubuntu
So I did:
wget -nc https://dl.winehq.org/wine-builds/Release.key
sudo apt-key add Release.key
sudo apt-add-repository https://dl.winehq.org/wine-builds/ubuntu/
Then after doing an update, I tried to install using:
sudo apt-get install --install-recommends winehq-stable
But I got
Reading package lists... Done
Building dependency tree
winehq-stable : Depends: wine-stable (= 3.0.4~cosmic)
And I can't install wine-stable, as it tells me to install wine-stable-i386, which I also can't install because:
wine-stable-i386:i386 : Depends: libc6:i386 (>= 2.28) but 2.27-3ubuntu1 is to be installed
Recommends: libcapi20-3:i386 but it is not going to be installed
Recommends: libcups2:i386 but it is not going to be installed
Recommends: libglu1-mesa:i386 but it is not going to be installed or
libglu1:i386
Recommends: libgsm1:i386 but it is not going to be installed
Recommends: libgssapi-krb5-2:i386 but it is not going to be installed
Recommends: libkrb5-3:i386 but it is not going to be installed
Recommends: libodbc1:i386 but it is not going to be installed
Recommends: libosmesa6:i386 but it is not going to be installed
Recommends: libsane:i386 or
libsane1:i386 but it is not going to be installed
Recommends: libsdl2-2.0-0:i386 but it is not going to be installed
Recommends: libv4l-0:i386 but it is not going to be installed
Recommends: libxcomposite1:i386 but it is not going to be installed
Recommends: libxcursor1:i386 but it is not going to be installed
Recommends: libxfixes3:i386 but it is not going to be installed
Recommends: libxi6:i386 but it is not going to be installed
Recommends: libxinerama1:i386 but it is not going to be installed
Recommends: libxrandr2:i386 but it is not going to be installed
Recommends: libxrender1:i386 but it is not going to be installed
Recommends: libxslt1.1:i386 but it is not going to be installed
Recommends: libxxf86vm1:i386 but it is not going to be installed
I don't know how to fix this, please help.
I have also tried doing sudo apt-get install -f, but it returns
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Edit: Also did sudo dpkg --add-architecture i386
Edit2: wine-staging works
