after using the tutorial of install wine to download wine:
$ sudo dpkg --add-architecture i386
$ sudo wget -nc -O /usr/share/keyrings/winehq-archive.key https://dl.winehq.org/wine-builds/winehq.key
and then
sudo wget -nc -P /etc/apt/sources.list.d/ https://dl.winehq.org/wine-builds/ubuntu/dists/focal/winehq-focal.sources cause my ubuntu version is 20.04
$ sudo apt update
everything works fine untill the point where I have to download wine stable branch,
sudo apt install --install-recommends winehq-stable
after doing this I keep getting the same error:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: winehq-stable : Depends: wine-stable (= 8.0.0.0~jammy-1) E: Unable to correct problems, you have held broken packages.
Can anyone help me out here? I've tried so many forums and methods but none of them worked out.
lemoana
  • 185
This is your ubuntu version not compatible to wine 8.0 for jammy, you must update from 20.04 to 22.04. It works for me.
Jasper
Also had this issue. Was able to resolve mine after going through the Winehq forum.
  • Step 1: I had to downgrade the package to the official Ubuntu version with: sudo apt install libgd3=2.3.0-2ubuntu2
  • Step 2: I had to run sudo apt install --install-recommends wine-stable-i386:i386
  • Step 3: I tried reinstalling the package again and voila problem solved sudo apt install --install-recommends winehq-stable
Tou can refer to steps above was from the Winehq forum.. https://forum.winehq.org/viewtopic.php?t=37388
SyntX
