I've been following this post : Can't install Wine Ubuntu 18.04
but the solution of installing wine-staging didn't work for me.
Here's the output of my attempt :
sudo apt install wine-staging`
Reading package lists... Done
Building dependency tree
 wine-staging : Depends: wine-staging-amd64 (= 4.0~rc5~cosmic) but it is not going to be installed
                Depends: wine-staging-i386 (= 4.0~rc5~cosmic)
Tried to install wine-staging-amd64 but then, get other dependencies issues :
sudo apt-get install wine-staging-amd64
[sudo] password for gerard:
 wine-staging-amd64 : Depends: libavcodec58 (>= 7:4.0) but it is not installable
                      Depends: libavutil56 (>= 7:4.0) but it is not installable
                      Depends: libvkd3d1 but it is not installable
                      Recommends: libcapi20-3 but it is not going to be installed
                      Recommends: libodbc1 but it is not going to be installed
                      Recommends: libosmesa6 but it is not going to be installed
                      Recommends: libsdl2-2.0-0 but it is not going to be installed
Edit: I deleted all external sources on the Ubuntu Software GUI in the section "Other software", ran upgrade, reboot and followed Elvir instructions. It worked, thanks !
C. Auth
  • 33
  1. Run the following command in the Terminal for adding i386 architecture before installing a 64-bit version of Wine:
$ sudo dpkg --add-architecture i386
  1. Run the following in order to add the WineHQ signing key:
$ wget -qO- https://dl.winehq.org/wine-builds/Release.key | sudo apt-key add -
  1. Now run the following command in order to add the relevant repository from the WineHQ:
$ sudo apt-add-repository 'deb http://dl.winehq.org/wine-builds/ubuntu/ artful main'
This is the most recent and stable release of Wine available. Use the following command to install this version:
sudo apt-get install --install-recommends winehq-stable
Please enter Y when prompted with a choice of y/n for installation. After that, the stable version of Wine will be installed on your system.
Elvir
  • 56
Try this:
apt update
apt dist-upgrade
Eric Mintz
  • 2,536
