18
So I've been experimenting with Ubuntu on and off for a while, but I honestly have no idea what the hell I'm doing. So I have a realtek RTL8812bu WiFi dongle that I'm hoping to get working. I did some research, and came across this driver on GitHub that a couple people across two threads said worked for them:
At the bottom it said there is a new version here. So somewhere it said it was confirmed to work on kernels up to 4.16, so I checked and I'm on 4.15.0. But the problem I'm having, is what am I supposed to do? There is some installation guide at the bottom that is about as clear as mud to me since I don't know much.
Kulfy
  • 18,154
Almost all of the instructions are in the README on the second site you linked. I’ll fill in a few blanks.
With a working internet connection by ethernet, tethering or whatever means possible, open a terminal and do:
sudo apt-get update
sudo apt-get install build-essential dkms git
git clone https://github.com/cilynx/rtl88x2BU_WiFi_linux_v5.2.4.4_26334.20180126_COEX20171012-5044.git
Now, from the README:
cd rtl88x2BU_WiFi_linux_v5.2.4.4_25643.20171212_COEX20171012-5044
VER=$(cat ./version)
sudo rsync -rvhP ./ /usr/src/rtl88x2bu-${VER}
sudo dkms add -m rtl88x2bu -v ${VER}
sudo dkms build -m rtl88x2bu -v ${VER}
sudo dkms install -m rtl88x2bu -v ${VER}
sudo modprobe 88x2bu
Please be aware that the ‘build’ process takes a few moments; please be patient.
Your wireless should now be working.
chili555
  • 61,330
10
I tried several different drivers, but the one I finally got it working was from this repo: https://github.com/morrownr/88x2bu
In short, the steps you should take are:
  1. Test that your dongle actually needs RTL8812BU drivers:
    • In a terminal (Ctrl+Alt+T) run:
      lsusb
      This will give you something like:
      Bus 001 Device 002: ID 2357:0115
    • Google the ID number, e.g. "wiki 2357:0115", and you will find out which Realtek driver you need.
  2. If you indeed need RTL8812BU and you are on Ubuntu 18.04, 20.04, or 20.10, run the following:
    sudo apt-get update
    sudo apt-get install -y dkms git
    mkdir src
    cd src
    git clone https://github.com/morrownr/88x2bu.git
    cd 88x2bu
    sudo ./install-driver.sh
    sudo reboot
mjkvaak
  • 281
You could try the next:
sudo apt-get update
git clone https://github.com/cilynx/rtl88x2BU_WiFi_linux_v5.3.1_27678.20180430_COEX20180427-5959
cd rtl88x2BU_WiFi_linux_v5.3.1_27678.20180430_COEX20180427-5959
VER=$(sed -n 's/\PACKAGE_VERSION="\(.*\)"/\1/p' dkms.conf)
Gryu
  • 8,002
  • 37
  • 53
I have Ubuntu 24.04.1 (Linux 6.8.0-51) and RTL88x2bu [AC1200 Techkey]. I was able to resolve the issue by using the following:
git clone https://github.com/morrownr/88x2bu-20210702
cd 88x2bu-20210702
reboot not required.
