Final edit: Solution is linked above. However the "git clone" link has been updated to "https://github.com/morrownr/88x2bu-20210702" so use that in place.
I have an "QGOO" USB 3.0 dongle which is supposed to work on Linux. It came with a usb stick with drivers. The drivers are zipped in folders, one file of which is a .sh file which I'm reading is supposed to execute the correct commands to install the driver. I've done a ton of searching and I've gotten as far as to right click on these files, and allow it to run as a program. After I do this the cursor spins for several seconds and then nothing. Nothing on reboot. I do not see a terminal after clicking on this .SH files.
I also used the "lsusb" command and confirmed Ubuntu can see the dongle. However it is not lighting up and I have no options regarding wifi. It instantly works and is recognized when plugged into a windows machine.
lsusb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 002: ID 046d:c31c Logitech, Inc. Keyboard K120
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 002: ID 046d:c077 Logitech, Inc. M105 Optical Mouse
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 011 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 010 Device 002: ID 0bda:b812 Realtek Semiconductor Corp. USB3.0 802.11ac 1200M Adapter
Bus 010 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 009 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 008 Device 002: ID 2222:1111 MacAlly Mass storage
Bus 008 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I'm pretty new to ubuntu with only basic knowledge, but I'm generally pretty good on windows machines and trouble shooting. This is a whole other language for me though.
Any help is appreciated.
I have tried:
usb wifi adapter is not working on Ubuntu 20.04.1 LTS
I get errors trying to use the dkms commands toward the end. Something about invalid format.
Same here: How do I install drivers for Realtek RTL8812BU?
I'm not a coder or programmer so I'm very basic at this sort of thing.
The last command of the solution provided does not work:
dave@MediaCenter:~/88x2bu$ ./install-driver.sh
bash: ./install-driver.sh: No such file or directory
dave@MediaCenter:~/88x2bu$ /install-driver.sh
bash: /install-driver.sh: No such file or directory
dave@MediaCenter:~/88x2bu$ install-driver.sh
install-driver.sh: command not found
